Question about Nokia N70 Cellular Phone
Camera automatically turns off when opened
My mobile camera goes off when it is turned On after sometime but when mobile is shaked then camera automatically goes ON and then immediately switches off itself.
Could u please help me out for this?
  • 31 Answers
On N70 phone u got camera trigger ( little switch that is seen when battery cover is lifted )
Check it's position and check if damaged, only that part can cause such errors.
If that not help... Check camera voltage control, it need 1.6v i think for N70.
Don't seek further.
It's not software because u say that camera is started by shaking = hardware fault.
br
Posted on Aug 20, 2008
Does not see image, when lens cover is open.
To return to the shooting mode press
shutter release button halfway page 50
of the manual
Link to manual
Dec 23, 2007 | Nikon D40x Digital Camera
Same here
try these:-
  • connect it to pc and on it
  • vaccum the barrel of lens
  • changing mem. card and batt. for 2min.
  • shake it.
  • on and off in different positions
Sep 18, 2009 | Canon PowerShot G5 Digital Camera
I dropped my camera and now when turning camera on the shutter comes out for about 2 seconds then it beeps and then it goes back in, I can view photos but not take any.
The most of cases problems is your camera lense wont come out properly. it's appear to be a electronic problem but it's defenetly a mechanical problem. do do as i say. turn on your camera and after lense came out quickly remove the battery. after that camera lense move out shake it well. shake your camera well. your target should be remove if ther any blocking thing the way your camera lense come out. if this way wont work you have to open your camera and check your mechanism. some time it can be broken lense.
Jul 09, 2009 | Casio Exilim EX-S880 Digital Camera
Camera turns on with a bit of a tremble but shutter locks
I have an 5D with the same problem, It looks like the Anti shake does not initialize properly, The only bypass I found that worked (except for a real repair) is to set the display light timeout for 5 seconds, The standby timout for 1 minute, Turn the camera off, and on again, Wait for 5 sec then the display goes blank, wait for 1 minute then the camera goes in standby, (light from CF card flashed red 1 time) Then touch any button to re-activate the camera and... voila... everything works, including taking normal pictures and the anti-shake !!! So it only takes a minute everytime to startup..
Jun 05, 2009 | Konica Minolta Maxxum 7D / Dynax 7D...
Olympus Stylus 730 shuts off after few seconds. Battery is fully charged, tried a resetting: no change.
To save battery power, the camera automatically goes into sleep mode and the monitor turns off if there is no operation when the camera is turned on (when the lens cover opens and the monitor is on). No picture is taken even if the shutter button is fully pressed in this mode.
Operate the zoom lever or other buttons to restore the camera from sleep mode before taking a picture. If the camera is left for 15 minutes, it automatically turns off (the lens cover closes and the monitor turns off). Press POWER to turn the camera on.
Mar 26, 2009 | Olympus Stylus 730 Digital Camera
Camera goes to sleep too quickly...is there a way to adjust?
To save battery power, the camera automatically goes into sleep mode and the monitor turns off if there is no operation after 3 minutes when the camera is turned on (when the lens cover is open and the monitor is on). No picture is taken even if the shutter button is fully pressed in this mode. Operate the zoom button or other buttons to restore the camera from sleep mode before taking a picture. If the camera is left on for 15 minutes, it automatically turns off (the lens cover closes and the monitor turns off). Press POWER to turn the camera on.
Mar 20, 2009 | Olympus ? 1030SW Digital Camera
Camera problem
that is shake/blur warning and you need to use better batteries if you use cheap batteries I find that the camera will use them really quickly try Energizer Litium for digital cameras you will get about 600 shots out of them
Jan 21, 2008 | Nikon COOLPIX L10 Digital Camera
Lens does not open,camera does not start
From what you describe the problem could be a couple of different things. The focus element inside the lens may have come off its track. Heres how to tell: If the lens shield has closed completely and you can not see down into the lens: *Does any text come up on the LCD before it turns off? Such as "E18" or "E25"? If the lens shield has not closed completely and you can see down into the lens: *When you shake the camera can you see something moving inside the lens? In either of these cases the problem is that the camera cannot move the lens due to the moving parts being jammed. This will require a repair service to go into the camera and reset the dislodged elements. In either of these cases the camera will display an error message on the LCD before it powers off. If it does not do this, let me know and I will give you other possible explanations.
Feb 22, 2007 | Canon PowerShot A520 Digital Camera
Shaking Photography
Here you will find the tips for taking better photos with less camera shaking. Tips 1. Composing and holding the camera with less camera shaking. For clearer images, hold the camera firmly not to cause camera shaking. 1) For maximum stability, hold the camera firmly well over the grip and keep your right elbow lightly pressed against your body. 2) Support the lens or the camera body with your left hand from below. 3) Look into the optical viewfinder as if pressing your forehead to the camera. 4) Do not stand straight, but with one foot stepping forward for taking better balance of your body. 2. Change the composing and holding the camera according to the situation for securer photographing. (Particularly when you take photos using the LCD monitor.) 1) Lean against the wall. 2) Put the camera on a fixed object like a table. 3) Ensure the camera holding by pressing the elbow against the handrail. 4) Use the tripod. 3. Move the zoom control towards wide-angle if your camera has the zoom function. Moving the zoom control towards tele-angle, camera-shaking will easily happen. If your camera has the zoom function, we advise you to take photos by zooming towards wide-angle. 4. Higher shutter speed will produce better images. Slower shutter speed may produce more possible camera-shaking. If your camera has a choice of shutter speeds, we advise you to select higher shutter speed for less camera shaking.
Aug 31, 2005 | Canon PowerShot SD400 / IXUS 50 Digital...
Nokia N70 Cellular Phone Logo
127 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
