I have an old JVC AX-11 stereo integrated amplifier that has gone on me . The power indicator is working but thats it . Can a fumbler like me fix it or is it curtains for an old and until now faithful friend that has never let me down in 20 years ?
robotek
  • 1512 Answers
SOURCE: JVC AX-33 Stereo Integrated Amplifier - very little sound!
Hi xaser
Check that someone has not turned on the tape monitor or mute. Both of these may cause the problem. Is there alot of noise with the sound you are getting when you turn it up?
regards
Graeme
Posted on Mar 22, 2008
  • 4234 Answers
SOURCE: help urgently required.....
The click you hear is the power relay. Normally that would be followed by amother click of the speaker relay. In this case, the output section is in protect mode because of a fault detected. This will prevent the speaker relay from turning on the speakers. This amp will require repair. I don't recall your specific model, but if it has discrete transistors, expect a parts cost in the $20 range. If it has a single output amp pac, then the part could be in the $65 range. Add in the local labor rate for the complete repair cost.
Dan
Posted on Apr 02, 2008
SOURCE: No power
Hello
This isn't a solution I'm afraid but we have also suddenly lost all power for the same Hitachi model (have checked the fuses too) and were wondering if you ever found a solution to your problem?
Posted on Aug 18, 2008
SOURCE: NAD 304 power indicator
Change resistors 333 & 334 - 47k-1W
Posted on Jan 04, 2009
SOURCE: JVC AX-66 Integrated Amplifier seems to be muted?
You need to have a jumper between the 4 standalone jacks on the right side of the column of stereo connectors. A stereo RCA cable would work for this.
Posted on Oct 14, 2009
I have a A-X2 JVC stereo integrated amplifier and want to know where I could get a copy of the user manual
Look to the JVC website. Hopefully they will still have it, as JVC has been out of the home audio business for a decade or two.
Jul 04, 2015 | JVC Audio Players & Recorders
I Have a yamaha ax 570 amplifier.
The problem may be due to a change in your aural response rather than the equipment. The high end can sound overemphasized or shrill even
Jun 04, 2013 | Yamaha Ax -570 Natural Sound Stereo...
I am thinking of replacing my now very old JVC AX 330 amplifier with a Marantz PM7003 amplifier and want to know if this is a suitable replacement in terms of power output etc.
You, sir, are a rare adherent to stereo-only electronics. Are you replacing it for cause (showing its age)? The PM7003 is only 2 x 70 watts like the JVC but it also has separable preamp/amps so you COULD upgrade or augment the power output with external amps and still control it all locally.
Of course, any current AVR's do that too and bring digital sources and multichannel audio to the mix for as little as the PM7703 may cost.
Jun 23, 2011 | Audio Players & Recorders
MANUAL JVC AX-90
what is this.....
ðóêîâîäñòâî JVC AX -90
take it to the service center...
Jul 11, 2010 | JVC Audio Players & Recorders
How do i turn my protector light off of my amp?
I'm not really sure how your amp works but i can tell you that if that light is on there is probably something wrong. Check your ground wire. Also it could be your not getting enough power to your amp, or too much
Mar 06, 2010 | JVC KS-AX7300 Car Audio Amplifier
Oct 14, 2009 | JVC Audio Players & Recorders
Unbalanced LEDs> amplification problem, or mere graphic drop out? my newly acquired AX-1 does not show as much power level indication on the left LED. cannot really hear a difference when panning between...
This could be a defect in the metering circuit. In order to verify this, you should measure the output externally.
This is a repeated problem, please see initial proble for the complete solution.
Dan
Apr 12, 2009 | JVC Audio Players & Recorders
This could be a defect in the metering circuit. In order to verify this, you should measure the output externally. Get that external measurement and post the results here. We'll continue from there.
Dan
Apr 12, 2009 | Yamaha DSP-AX1 10-Channel Amplifier
Hi xaser
regards
Graeme
Mar 22, 2008 | Audio Players & Recorders
762 people viewed this question
 Grubhead
Grubhead
