Question about GE JVM1650 1000 Watts Microwave Oven
GE JVM1650CH01 Microwave Template
I need the top cabinet template for the above mentioned microwave. I can print large format documents to 36". Do you have this for download?
Thanks
Bill M
I have this microwave and it shuts down constantly. I'll never own another GE.
Posted on Nov 09, 2012
  • GE Master
  • 9,086 Answers
You can download GE owner's manuals and installation instructions here.
Posted on Aug 18, 2008
Hi my micro keeps shutting down after a few seconds. Everytime I have to reset the clock and month / yr to try again. It will work after two to three resets and go back to the same.
Posted on Oct 19, 2009
I need a top template for a GE Adora model# HDM1853SJ06
Posted on Oct 14, 2008
I need the top cabinet template for GE microwaveJVM1950DRCC
If you wish to get some details about microwave oven and its working ; check the site linked here. Pull up older posts...
http://electro-medical.blogspot.com/
May 17, 2016 | GE JVM1950DRCC
Over range microwave doesn't fit in the space outlined by the installation template
You missed something while reading the installation directions but that won't fix it. since you already drilled holes in the wall lower the mount down as needed then drill new holes in the mount to match the holes you drilled in the wall. The problem would have been worse if you were off left or right... up and down is easier. Remember you maybe just not dropping the microwave low enough to fit in the slot at the bottom of the wall mount before you tilt the micro up.. check it one more time...including the directions before you re-drill
Sep 26, 2015 | Bosch 30" 500 Series Over-The-Range...
I need the Top Cabinet Template and the Rear Wall Template for GE Microwave Model JVM2070WH02
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Apr 24, 2013 | GE JVM2070 Microwave Oven
Wall template mount for ge profile microwave
You can may be able to order that by looking up parts by your full model number here.
Jan 10, 2010 | GE Profile Over-the-Range Microwave
I am seeking a template for re-installing my 2 year old microwave. Jenn-aire has none of the templates in stock and can't send me a pdf or file so I can print the template myself. I have tried 2 parts...
Since you can't get a paper template for remounting your microwave, I can offer you my tips for doing this, as I've had to reinstall many of my customers microwaves, after they've done a kitchen remodel.
You can use the metal mounting bracket as your "new" template. Just unmount the micro and remove the metal bracket and you can then position it on the wall or under the cabinet where you are looking to mount the microwave. However, before you remove it from the wall, simply measure the distance from the edges at the top and both sides of the bracket, where it is presently mounted and you'll be able to easily remount it in a new location.
If you've already removed it from the wall, not to worry, simply place it on the back of the microwave and measure the distance from the edges of the bracket to the top and both sides of the microwave's canbinet edges. Allow for 3/16" additional distance and you should be able to then remount the bracket at the new location with ease.
Please remember that you want to get the bracket secured into a wall stud so it can hold the weight of the microwave once it's installed and fastened to the bracket. I also recommend that you use wall anchors at the side edges at both the top and bottom corners to help secure the bracket IF there are no wall studs behind the predrilled holes for mounting the bracket to the wall.
If you have trouble using the metal mounting bracket, you can always trace the entire bracket onto a piece of heavy paper or cardboard, but frankly, I find this unecessary and time consuming, since you've already got the mounting bracket right there with all the holes and such.
Also, don't forget to measure the location of the power cord at the top or back of the microwave and remember you'll need to drill a hole in order to be able to pass the cord thru the cabinet. If your microwave has screws at the top front edge that help secure it to the cabinent above it, again, simply measure the distance of these mounting locations from the sides and back of the microwave cabinet and drill holes thru the cabinet, using a drill bit that is twice the diameter of the mounting bolts. You should add washers to these bolts to help prevent the bolts from pulling thru the cabinet bottom.
Mounting a microwave is best done with at least two people, as holding it in place while someone else puts the bolts in it isn't easy to do by yourself. Also, it is much easier to do, when installing it over an existing range, if you move the range out of the way first, so you can stand under the microwave, instead of having to lean over the range while trying to install it. Not to mention the fact that should you drop the microwave, you'll not only damage it, but could destroy your range at the same time.
Hope you find this Very Helpful and best regards!
Oct 23, 2009 | Jenn-Air JMC9158AAS Convection/Microwave...
Need top cabinet template for ge spacesaver microwave-jvm1440whq2
If it;s not there, you can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Jun 06, 2009 | Microwave Ovens
Will the template for JVM1790 be the same as earlier GE models?
Make your own template of the holes in the top of your cabinet and lay it over the new unit and see if they align. As long as your replacing GE with GE it probably will work.
Oct 04, 2017 | GE JVM1790 1000 Watts Convection /...
My GE JVM1600 Series went out.
It will help you, I'm sure.
Dec 10, 2008 | GE JVM2050 Microwave Oven
GE JVM1650 1000 Watts Microwave Oven Logo
3,285 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
