Question about Electrolux Kitchen Ranges
Hi there, we have an eletrolux premier electric oven, which has stopped working. The hobs work fine as does the fan that spins in the oven but no heat. Is there a likely cause? Thank you
  • 22 Answers
Likely cause is the bake element
Posted on Aug 17, 2008
6ya staff
SOURCE:
Hobs all working oven not working
Hob stopped working, oven still fine on electric cooker, any ideas ...
forums.moneysavingexpert.com/showthread.p...
MoneySavingExpert.comDec 25, 2010 - From this point, we'll assume that you are happy to receive all .... have a "problem" that covers the hob not working but the oven doing so. Gas Hob Ignition Not Working!
May 22, 2007
Oven not heating - Please help
Oct 14, 2006
Oven won't get hot - help please
Aug 24, 2006
More results from forums.moneysavingexpert.com
How to Diagnose a Fault With an Electric Hob ' eSpares
www.espares.co.uk > Advice Centre
Jan 01, 2016 | Logik LFTC60W12 White 60 cm Electric...
I have a belling 335 and both the oven and rear left hob ring have stopped working. what is likely to be the problem?
The thermal fuse inside rear is faulty. The grill also has it's own thermal fuse so make sure you change the correct one.
Sep 06, 2012 | Belling 335 Electric Kitchen Range
MY STOVES COOKER'S OVEN AND GRILL HAS STOPPED WORKING?THE HOB IS WORKING FINE.
The hob is normally totally independent of the oven. What is actually working or not working on the oven? i.e. does the grill still work, is the clock OK and can you set it, or is everything totally dead?
Oct 16, 2010 | Stoves 720EF Electric Double Oven
My Delongi dsf905 oven stopped working
FIRST CHECK THE FUSE IN YOUR PLUG IF OK THEN IT MIGHT BE THE TERMOSTAT IS FAULTY CHECK THE ELEMENT IS NOT BURNT OUT IF SO REMOVE AND BRING TO A ELECTRIC AND PLUMMERS SUPPLY STORE FOR REPLACEMENT.
Nov 29, 2009 | Ovens
My hob is working but there was a bang in the oven and nothing is working inside the oven but the hobs are working fine. Many thanks for any help
If it is a fan assisted oven, and the fan is working o/k, then I would suggest that you fit a new oven element, if the fan is not working, then you are going to have to investigate further.
Please rate my solution.
Thanks.
Nov 08, 2009 | Belling XOU270 / XOU271 Electric Single...
PRIMA FAN ASSISTED COOKER - FAN WORKING BUT NO HEAT?
Hi.
You will need to check the oven element, it probably needs replacing.
Thanks.
Apr 27, 2009 | Bosch HBL 5032 Electric Single Oven
STOVES fan oven - inlet fan on regardless HOB GRILL or OVEN
It is correct. The exhaust fan comes on to exhaust any heat.
The oven fan is for more even baking.
Apr 22, 2009 | Stoves Premier 600EMa Electric Single Oven
Neff B1432 oven element and fan not working
If the element has failed again in such a short time , then I would suspect that the fan is the culprit.
If the fan is not working, then the element overheats, and burns itself out.
The fact that the fan spins freely, proves nothing, as the fan can be still faulty.
The only way to prove if the fan is faulty, is to remove the oven from the housing, and remove the rear outer panel of oven,.test with a meter set to ac mains and test the fan motor terminals to see if there is power there when oven is set to heat, disconnect the element first. ,if there is ,and the fan is not running then the motor is faulty..
If there is no voltage there, then problem is elsewhere, and you will have to investigate furher.
Plz rate my solution.
Thanks.
Jan 12, 2009 | Neff B1432 Single circotherm plus Electric...
Kitchen Ranges Logo
190 people viewed this question
Top Electrolux Kitchen Ranges Experts
Archie Ferrarini
Archie Ferrarini
Marvin
Marvin
Eric Rotmil
Eric Rotmil
Are you an Electrolux Kitchen Range Expert? Answer questions, earn points and help others
