Question about Sony Ericsson S500i Cellular Phone
Phone got wet, what do i do
My phone got in some water and i was able to take out the batterry right away and let it dry for a few minutes.now it shown that its full charge and also there is no sounds. what can i do/
  • 50 Answers
Strip ur phone and leave near heat for 15 mis clean it with a old brush llike a toohbrush leave it again for 5 mins and put back 2 gether again
Posted on Jan 26, 2009
Phone got wet need to take apart to dry...how?
One method that has worked for many people and water damaged phones, (myself included), is to put the phone in small zip lock bag of rice to dry.
Simply disassemble the back cover, remove the battery, and place the phone in a zip-lock bag filled about half way with white rice. The moisture in the phone from the water should be absorbed by the rice after a few hours. This is best done every evening for a week or so until the phone has completely dried out.
It is best not to wait until the phone has dried on it's own after a few days, because if water evaporates on it's own in the phone, it can leave behind residue on the internals of the circuit board.
Jun 14, 2011 | Pantech Pursuit P9020
Tip
How To Quickly Repair Your Mobile Phone Dropped In Water
Now, there is no need to panic if your mobile phone gets dropped in water or you get stuck up in a bad rain and your clothes as well as your mobile phone gets wet. All you need to do is follow the following three tips that will fix your phone with water damage:-
(A) Act Quickly : straight away get into action and remove every cover and detachable part you possibly can like memory card, the SIM card, battery and back cover, etc. Now use a toilet paper or a thin cloth to blot away any excess water you can see inside of the phone and be sure to get as much as you can. Otherwise, all this water will start evaporating and collecting in hard to reach various places in your phone.
Your phone may work now if it was only submerged for a short period of time.
B) Quick Drying : Grab a hairdryer and start drying your phone paying extra attention to the battery housing as this normally has small holes which allow air (and ironically enough water) into the phone.
warning: Don’t hold the hair dryer too close to the phone. Keep it at a distance whereby if you put your hand in front of the hair dryer it would not burn you. Bringing it closer could damage your phone’s electrical components. If i am sounding serious, try putting a hair dryer up against a sheet of paper for a few seconds. It turns it brown – would you want that happening to the inside of your phone?
If 20-30 minutes of this doesn’t work – go to plan C.
C) Long Term Drying : By putting it in a warm dry place you allow the water to slowly evaporate and escape through the holes in the phone (remove the covers and battery when doing this).
on Mar 03, 2010 | Cell Phones
Tip
How to Fix a Wet Cell Phone
  • Get it out of the water as soon as possible. The plastic covers on cell phones are fairly tight, but water can enter the phone in a short period of time, perhaps only 20 seconds or less. So grab your phone quickly! If you can't get to it in time, your best bet is to remove the battery while it is still under water. Water helps dissipate heat from shorts that can damage the phone, so most damage occurs when the inside of the phone is merely wet and there is a power source. This can go both ways. Being under water is more likely to short the battery to even more sensitive contacts, so be careful.
  • Don't panic. Your phone will probably not be too damaged if you take it out of the water right away.
  • Remove the battery. This is one of the most important steps. Don't take time to think about it; electricity and water do not mix. Cutting power to your phone is a crucial first step in saving it. Many circuits inside the phone will survive immersion in water provided they are not attached to a power source when wet.
  • If you have a GSM career, remove your SIM card. Some or all of your valuable contacts (along with other data) could be stored on your SIM. To some people this could be more worth saving than the phone itself. SIM cards survive water damage well, but some of the following steps are unnecessary i.e. don't heat it. Just pat it dry and leave it aside until you need to connect your phone to your cellular network. (This step does not apply to CDMA carriers such as Verizon, Alltel, US Cellular, Sprint, etc.)
  • Dry your phone. Obviously you need to remove as much of the water as soon as possible, so you can save it from getting into the phone. Shake it out without dropping it, then use a towel or paper towel (ideally trying not to clog the wet paper in the gaps and grooves of the phone) to gently remove as much of the remaining water as possible. Dry the excess moisture by hand.
  • Remove any covers and external connectors to open up as many gaps, slots, and crevices in the phone as possible.
  • Use a vacuum cleaner if possible. Do not use a hair dryer (even on a "cold" mode) to dry out the phone, as this may force moisture further into the small components, deep inside the phone. If moisture is driven deeper inside, corrosion and oxidation may result when minerals from liquids are deposited on the circuitry. Using a hairdryer might be a temporary fix, but this will eventually cause component failure inside the phone. Instead, remove all residual moisture by drawing it away with a vacuum cleaner held over the affected areas for up to 20 minutes in each accessible area. This is the fastest method and can completely dry out your phone and get it working in thirty minutes. Be careful not to hold the vacuum too close to the phone, as a vacuum can create static electricity, which is even worse.
  • Use a substance with a high affinity for water to help draw out moisture. Leave the phone in a bowl or bag of uncooked rice overnight. The rice would absorb any remaining moisture. If available, it is preferable to use desiccant instead. Desiccant will absorb moisture better than rice.
  • Let the phone sit on absorbent towels, napkin, or other paper. Remember that the goal is to evacuate all the moisture and humidity, not to trap it or add even more. Check the absorbent material every hour for 4 to 6 hours. If moisture is evident, repeat the vacuuming step and desiccant steps.
  • Test your phone. After you have waited a day or so, make sure everything is clean and dry looking and re-attach the battery to the phone and see if it works. If your phone does not work, try plugging it into its charger without the battery. If this works, you need a new battery. If not, try taking your cell phone to an authorized dealer. Sometimes they can fix it. Don't try to hide the fact that it has been wet. There are internal indicators that prove moisture.
  • Take the phone apart If your phone doesn't turn on at all. Try taking it apart. First, make sure that you have ALL the right parts and know exactly where they go. Be sure to put everything back in its proper place once finished. As you're disassembling it, pat each individual part dry with a small towel and use the vacuum cleaner once more on the crevices. If this doesn't work go to the professionals.
  • on Feb 17, 2010 | Cell Phones
    To Whom it May concern. my Samsung Intensity
    If this just happened today the 12th - let it dry out for 4 days - you can try it anytime before that - but even if the phone comes on and works I would let it dry for 4 days. Get insurance right away too. Some phones once wet - have a tag inside the phone that alerts the company it has been wet. Some company's sell insurance that will cover lost or stolen phones but not damaged by water so be cautious when dealing with this problem.
    thanks
    Gary @ Fix Ya
    Jun 28, 2010 | Samsung SCH-U450 Cell Phone
    I recently jumped into a pool with my cell phone in my pocket (SAMSUNG Reality). I realized it 10 minues or so after. Dried the phone. A day later, the phone will turn on when connected to charger...
    When phone gets wet NEVER try to turn it on. Take battery out right away shake water off and put both in bowl of rice for at least 24 hrs. If your not home or don't have rice right away take battery out and get some. We have a bowl of rice on the counter all summer long for those who jump in the pool with phone in their pocket. I have washed them dropped them in the toilet my son jumped in pool with his phone, put it rice for 24 hrs and we were up and running with the exception of the one in the pool, that one cost me new battery on Ebay ($4.95) but phone worked fine, didn't even lose contacts or pictures. But the key is to NOT try to turn it on after its been wet. Water and batteries don't mix.
    Jun 16, 2010 | Samsung Exclaim M550 Cell Phone
    My phone got wet when it was on, and when i turn it on, it vibrated and its screen turned white. Now it doesnt do anything. The water it was in was chlorine and it was immersed for about 5 minutes. I need...
    yes u'll need a new battery.
    remove the battery now and leave the phone in a dry area. and it'll need atleast 24hrs to completly dry. while ur waiting buy a new battery.
    good luck
    Jun 26, 2009 | Samsung Propel Cell Phone
    Got Wet = Blank Screen
    I helped a friend with a similar problem using the solution below, so I am sure it will work unless your phone has shorted out:
    • Remove the battery from the phone immediately -- preferably right after it had gotten wet.
    • Spray the phone liberally through the keypad and inside the battery compartment with a good brand of electronic cleaner such as "CRC QD Electronic Cleaner Quick Drying Formula". It is important for the cleaner to get into the phone to wash out any water and mineral residues as they can cause a short when you put the batteries back into the phone.
    • Allow it to drain and dry, or better, blow dry it with hairdryer set on cold, or turn upside down on your dashboard for a few hours. Do NOT put the batteries back in the phone while it is drying.
    • When your phone is completely dry, put battery back in and turn it on. If it does not come on, put it on the charger. You should see the indicator come on showing "Charging".
    • After a few minutes to a half an hour, try turning your phone on. It should work if nothing has shorted.
    Nov 22, 2008 | Nokia N95 Cellular Phone
    Water in W510
    We used a hair dyer and it cleared the problem within minutes.
    Aug 05, 2008 | Motorola Mobility MOTOKRZR K1 Cellular...
    Motorola v3 razor water damage
    If a phone gets wet, turn it off, get the strongest rubbing alcohol you can find (we have 91% here) and immerse the phone in the alcohol. Let it sit for a minute or two and then take it out and let it dry. The alcohol will either wash away the water or mix with it to make it dry faster so it shouldn't corrode the contacts. This had to be done with the phone still wet from the original spill. Taking it to the vendor, they will look in the BTTY compartment and see that the phone was wet (little paper sensor that changes color if it ever gets wet) and that voids the warranty so you are kind of stuck sorry.
    Nov 19, 2007 | Motorola Mobility RAZR V3
    Phone does not work properly
    Since cellphones have ways of indicating water damage (internally AND externally), warranty service is pretty much out of the question. You can TRY using a blowdryer (on LOW heat) to make sure the insides of the phone are dry, and put the battery back in to see if works. Incidently, the lithium-ion batteries in cellphones are potentially dangerous; anything that might short them out, like physical damage, water inside, could cause them to catch fire and burn like a flare! Also, you don't want to get them too hot, say over 140 degrees F-same result.
    Jun 02, 2006 | LG VX3100
    Sony Ericsson S500i  Cellular Phone Logo
    43 people viewed this question
    Top Sony Ericsson Cell Phones Experts
    Computer Repairing
    Computer Repairing
    Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
