Question about Dishwashers
The water in the dishwasher seems to be cold even though it is set at 65 degrees
  • ventest Jan 16, 2009
    I seem to have a simliar problem. How can I tell if it is the heater or stat?
    Scholar:
  • 132 Answers
Sounds like the thermostat is not working
These are normally controlled by a 'bi-metal' sensor -very very cheap.
If you can locate this sensor - you will probably find that you can depress it by hand, and it SHOULD reset itself...
If it does not - then theres your problem - this will cost you very little to replace (DO NOT PAY FOR AN ENGINEER UNLESS YOU REALLY HAVE TO)
Posted on Aug 17, 2008
Why the hot water temperature couldn't reach the set temperature (130 degree) in Amtrol WHS80Z indirect water heater?
I have a couple of thoughts. You may have air in the boiler water circuit at the loop that feeds the tank. You'll have to find the vent in the loop to get it out. Second, the automatic valve that opens for hot water may not be opening fully. Have you felt both the boiler water lines that go in and out of the tank? If the water going in is hot and the line out is very cold you have very little boiler water going through the loop. Make sure the isolation valves on the loop are open. Is your boiler full of water? If the boiler loop lines are hot going in and coming out, the tank is full of rust or debris and no water can get to the fins on the internal tubing to pick up heat. If that's the case there is no repair and its time to get a new tank. Hope this helps good luck.
Nov 04, 2014 | Amtrol WHS-80Z - WHS-80Z 80Gal Hot Wtr...
Tip
I'm having the FH error. I'm am currently having plumbing troubles after leaving...
This advice is for Kenmore Elite and Whirlpool Duet model FRONT LOADERS displaying the “FH” error code.
"F/H" indicates that either you have no water coming into the washer, or very little water.
If you have NO water coming into the wash tub after 30 seconds the error code is displayed. Check the following:
- Inlet water valve may be clogged. Clean inlet screens if necessary.
- Make sure water taps are on.
- Check inlet hoses for kinks or clogs.
If you HAVE water filling the wash tub, and after 8 minutes, 10.5 gallons of water has been detected by the flowmeter, but there has not been a detected a Pressure Switch trip, the inlet valves are turned off and the error code is displayed. Check the following:
- Make sure you don't have a siphoning problem. Click the following link for instructions: http://www.fixya.com/support/r587481-prevent_washer_siphoning
- Verify Drain Pump operation.
- Verify Flowmeter operation.
- Verify the Pressure Switch hoses are intact and connected properly.
To access the Drain Pump - UNPLUG the washer and take the lower panel under the door off by removing the three screws under the bottom edge. HINT: Propping the front feet of the washer up can make access much easier. I use a couple small blocks of wood. With the screws removed, the panel should drop down then come off. If it sticks, tap either side and it should come free. The pump is located directly under the wash tub in the front of the washer. Verify the electrical connections are good and that the pump is running. If not, click on the following link to check the pump for obstructions:
http://www.fixya.com/support/r385845-checking_drain_pump_in_whirlpool_duet
To access the Flowmeter and Pressure Switch – remove the three screws in the top panel along the back of the washer. With the screws removed, the panel should slide back, then, lift off. The flowmeter will be located on the left-hand side of the washer (facing from the front) between the inlet valve and dispenser. It’s a small white plastic device with hoses attached. The pressure switch is located on the right-hand side of the washer in the rear. It is a round plastic device with electrical connections and a hose attached.
There should be a tech sheet directly behind the panel or attached to one of the interior cabinet walls. Please refer to this sheet to learn how to perform diagnostics, how to locate the components mentioned, and the specific measurements required determining if the components are good or bad.
I hope this helpful. Please post back if you can't find the tech sheet and/or need further assistance.
on May 27, 2010 | Kenmore Elite 45986 Front Load Washer
Whirlpool dishwasher beeping
Make sure all hoses are clear, and filters are clean. If they are all ok restart but use different temperature. Still not working, sounds like thermostat may have problem. Call service agent.
Aug 13, 2014 | Whirlpool Dishwashers
How do you set the thermostat above 120 degrees? My dishwasher requires 135 degrees. Thank you.
you shouldn't have to set your heater to 135. dishwashers have a built in heating element for just this purpose.
once you start going over 120 degrees on your water heater, you start creating scalding problems.
130 degree water can cause second degree burns in 30 seconds
140 degree water can cause second degree and even third degree burns in 6 seconds
150 degree water can cause third degree burns in 2 seconds.
be very careful !
Aug 05, 2010 | Rheem Tankless Hot Water Heater...
TAKES A LONG TIME,
Takes a long time to what? If the entire cycle seems to take forever, one suggestion is to make sure your hot water heater is turned up. Most dishwashers requires the water to be a minimum of 120 degrees before the timer will begin. If you are using a Sani-Wash cycle, then the water need to heat up to 165 degrees. The heater can only heat the water 1 degree per minute, so if the water coming in to the dishwasher is only 100 degrees, it will take an additional 65 minutes before it will even start the cycle. You can also make sure you get the water at the sink hot before you start the dishwasher, this will ensure the hottest water is going in (only fills for 90 seconds).
Jul 30, 2010 | KitchenAid KUDR01TJ Dishwasher
The water in our bosh S9F1B dishwasher does not heat up. The programme seems to work ok, just the pots are cold.
check the water coming into.the unit. must be acertain degrees. the heater will only heat up to a certain degrees .ex if you have cold water going to machine the heater may make it warm.
Feb 23, 2010 | Dishwashers
Auto-defrost not working at all
Unless equipped with special equipment most dehumidifiers will produce little if any water under 65-70 degrees. Many state operation down to 50-60 degrees but this was under lab conditions and therefore a marketing tool. The best performance is gained when the air temperature is above 70 degrees. The water you are finding is from melting frost, if you have a humidity problem you should be adding heat to the area to be dried, warm air holds much more moisture than cold and drying is much more effective if you can heat the area to around 80 degrees.
Mar 05, 2017 | Kenmore Dehumidifiers
Avanti N252BG beverage cooler does not get cold enough
Brand new installed avanti beverage cooler. In a basement undercounter so room temp. around 65 degrees. Only gets to around 45 degrees inside even though temp is set to 34 degrees. Most of the time it sits for days without being opened but still not cold. Any suggestions on how to fix this problem?
Mar 26, 2009 | Avanti N252BG Beverage Cooler
Lg dishwasher never heats water
The LG 7811 dishwasher is supposed to even support a cold water (vs. hot water) connection. Then it will heat the water up to 120 degrees upon each fill cycle. This is not optimal and it adds much time to the already long full cycle. When you run the hot water at the kitchen sink until it is hot and then kick off the cycle, is the water hot at the beginning? It should be 120 degrees minimum and well under 140 degrees maximum.
Do you get any error codes on the display? Troubleshooting is possible, but recommend you contact LG service at the number in the user guide asap. Press for fast, free resolution to this problem. Please reply when you have gotten this fixed, explaining what fixed this nice, quiet dishwasher. Good Luck!
PS: When you get it running, do not use ultra-cheap dishwasher soap. Recommend Electrosol powder or cascade. Never use gel or tablets on this water conserving dishwasher.
Feb 02, 2009 | LG 24 in. LDF 7811 Stainless Steel...
Dishwashers Logo
50 people viewed this question
Top Dishwashers Experts
