Question about NetGear RangeMax WPN824 Router
Netgear RandeMax 3500 and comcast problem
I am up and running and I can be connected for a few minutes, and then it just disconnects and connects, and disconnects and reconnects numerous times, it happens over and over again. When I am connected by ethernet there are no problems, it is just the wireless connection. I have tried a few things, but I really am not sure what more to do.
  • jmats_us Aug 18, 2008
    Well...about an hour or so since I got your response, and it has been running absolutely fantastic...I am still a bit pessimistic, but so far, my connections has been unbelievably faster and much better. My connection speed was set to 300MBPS, which is the max for my router...My connection is about 100MBPS and so I set it to 145MBPS and since then...no problems at all!!!!
    My weekend has been a drag, trying to troubleshoot this, and to finally have it working, with just a quick desperate question out there, makes me a very happy person..thanks again...I am crossing my fingers that tommorrow, it will be the same. If not, you may be hearing from me again...for further suggestions...
  • jconnor15 Aug 18, 2008
    My netgear has not been working at all for about 2 weeks, so have thrown it aside. Please help.
    President:
  • 2,961 Answers
Just double check in the router settings and see the connection speed (not internet ISP speed), it may be set at 108MBPS and your reciever may only be able to connect at 54MBPS.
Posted on Aug 17, 2008
Netgear N600 keeps disconnecting from internet
If your router isn't running firmware v 1.0.0.46 then download that from Netgear's website and upgrade the router's firmware.
Jan 28, 2013 | NetGear WNDR3400 N600 Wireless Dual Band...
I got a Netgear wireless router from comcast I did the instructions on the cd, after it was detecting my connection it said that I have a static ip, I talked to comcast and said that is not right that I...
1.call comcast and ask them to put your modem on bridge mode.
2. Once the modem is on bridge mo the internet light will turn OFF
3. connect your comcast modem using the Ethernet cord to the Internet port at the back of your netgear router.
4. connect another ethernet cable from port number 1 from the back of your router and the other end should be connected at the back of your computer.
5. Then go to this website for the instruction to configure your netgear router. it includes screenshots as well for better understanding.
ftp://downloads.netgear.com/files/rp614v3_setup_manual.pdf
Sep 08, 2011 | Computers & Internet
It worked well when I left Florida for Michigan in April. I disconnected the computer, modem, and router when I left and restarted them when I came down a few days ago. Bypassing the router I can connect...
Make the connection back again...
Comcast modem to the yellow slot in router, and your PC to any one of the gray slot in the router....
Now check for the light status in router and tell me what are the light lit up in green and what light are lit up in amber....
Jan 03, 2011 | Belkin F5D7234-4 Router
Pandigital novel ereader is not connecting to Netgear router and home wireless network
try resetting the router by disconnecting the power to it for a few minutes
Dec 29, 2010 | NetGear Computers & Internet
Connection is intermitent. I receive signal and it works fine for 5 minutes. Then the signal continues but I do not get internet access netgear wnr1000
Do you have anything else on the network besides your computer? If you do, it may be a conflicting IP address. I was told by the Comcast tech that the WNR1000 doesn't allow additional routers on the same network. Have to upgrade to a WNR3500 for that. When I disconnected my wireless extender, it fixed the problem.
Aug 05, 2010 | NetGear WNR1000 Router
Is netgear compatible with comcast broadband service
Yes the NetGear router is compatible with Comcast. You'll just connect the one 'computer' output from the Comcast box into the WAN input on the NetGear box, and in the outputs from the Router plug it from there to your computer.
Nov 22, 2009 | NetGear RangeMax WPN824 Wireless Router...
Using home phone causes comcast wireless internet to disconnect
Wireless internet runs at 2.4ghz. Your portable phone is probably also 2.4ghz and is knocking out your internet connection when in use. Look for an 800mhz or 5.8ghz phone as a replacement.
Oct 09, 2009 | Panasonic KX-TG2357 Cordless Phone
Ethernet connection gets disconnected very often
If none of the router jacks give you a solid connection and you maintain one when you directly connect to the modem, it is time to replace the router.
Mar 21, 2009 | NetGear WGR614 Wireless Router
How do I set my Netgear FVL328 to be a switch for my network? I have a Dlink DIR-655 connected to my cable modem. But I don't have enough ports for all of my devices. So I connected the Netgear FVL328...
If I understand, the D-link is a switch but you don't have enough ports so you want to use the Netgear to get additional ports.
The way to do it is to use one of the Netgear Lan ports to connect to one of the D-link ports, then use the remaining Netgear ports for your stuff, leaving the WAN port disconnected.
Personally I would use the Netgear as a firewall and connect the D-link to get the additional ports.
Also, Apparently the Netgear and the cable modem or D-link are both running DHCP servers to assign IP addresses to connected devices that need one assigned. You should turn the DHCP server off in whatever unit is being used in a slave fashion. This is done in the netgear by opening a browser and typing in the IP address for the netgear, which is probably 192.168.1.1, and logging in using username 'admin' and password 'password' unless you changed them.
Mar 15, 2009 | NetGear FVL328 and FA311...
Netgear wireless router installation
Light blinking on Netgear router means that the wireless is "working". Mine did the same thing. I had reset my network to 192.168.2.x instead of the default 192.168.1.x. Since this is usually on a diferent subnet it logically is on a different network and will not connect. From your post it sounds like you know what you are doing. If the config software for the router loaded correctly then there should be an icon in your Network path that shows the router. Double clicking should let you in by default. Set the IP address to your local network and try again.
Nov 26, 2007 | D-Link DI 514 Wireless Router (DI-514)
NetGear RangeMax WPN824 Router Logo
1,035 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
