Question about Sis 6326, (4 MB) Graphic Card
Device manager error
I install windows 2000 and the speakers can not run because of unknown multimedia audio controllar.
  • 594 Answers
That is because you need the drivers for your sound card. what is the make and model of your sound card. and the make and model of your computer?
Posted on Aug 17, 2008
My computer just stop to producing sound from speakers even the welcoming window xp sound,
The audio driver might have been corrupted. You just need to download the appropriate audio driver for your motherboard. Go to the Device Manager and install all missing drivers for "Unknown Devices". Either connect to the internet or use the driver disc which came with your motherboard.
For those who doesn't know how to access Device Manager, please follow the steps below.
For Windows XP:
Start -> Run -> Type devmgmt.msc (in the box) -> Right click Unknown device -> Properties -> Driver tab -> Update driver
For Windows Vista and Windows 7
Start -> Type devmgmt.msc (in the start search box) -> Right click Unknown device -> Properties -> Driver tab -> Update driver
Hope this helps.
Aug 27, 2011 | Dell Dimension 8400 PC Desktop
No audio from PC
You just need to download the appropriate audio driver for your motherboard. Go to the Device Manager and install all missing drivers for "Unknown Devices". Either connect to the internet or use the driver disc which came with the motherboard of the computer.
For Windows XP:
Hope this helps.
Jul 17, 2011 | Computers & Internet
After installing windows 7 the sound drives were not working , no sound
Check Device Manager to for any "unknown devices", your audio device driver might be one of those. Unknown devices usually appears if the device driver (ex. audio driver) is not installed. You can also find an "exclamation point" under "Sound, video and game controllers" if there is conflict on the driver causing no audio to be heard from the unit.
To resolve the issue, you can either use the Drivers installation disc which came with the motherboard or Right-click on the "unknown device" and select "Update driver" button.
For pc users who doesn't know how to check device manager, follow below steps:
Windows XP
- Start > Run > type devmgmt.msc on the box then hit enter key. or you can also
- Start > Right-click My Computer > Properties > Hardware tab > Device Manager
Windows Vista and 7
- Start > type devmgmt.msc on the search box then hit enter key or
- Start > Right-click Computer > System Properties > Device Manager (link at the left pane)
Hope this helps.
Jun 06, 2011 | Computers & Internet
I am not getting any sound
Click Start
Right-mouse click My Computer
Click Properties
Click Hardware
Click Device Manager
Under "sound" devices, is your audio-device correctly installed?
Under "unknown hardware", is there a "multimedia" device?
Are your computer's speakers turned on?
Have you MUTE'd your speakers?
Do your speakers work with some other computer? or with your iPod Touch?
Aug 27, 2010 | Gigabyte GA-945P-S3 Motherboard
I cant get my speakers to work. i dont if it is the software or the speakers its self. how would i be able to check if my default is set to the correct speakers?
Please go to run and enter "devmgmt.msc" you will get device manager. In device manager check any unknown device or yellow exclamation is there or not. If any one is there download the driver and install properly. If it is installed please go to run and enter "Control" that time you will get control panel. In that window you can see sound and audio device . Please check it is working or not. If it is installed check the connection and the speaker.
Aug 07, 2010 | MPC Computers ClientPro All-In-One PC...
No sound (AsRock P4 Combo)
1.
Check the speaker connections - take the plugs out and put them back.
Make sure the speakers get power.
Test the sound with headphones.
If it is a Laptop be sure the speakers are turned on (Usually an Fn function key).
2.
Load a system restore point from a date before the sound problem started.
3.
Has the audio service been started by Windows?
Click Start > Run > type services.msc - then click OK.
In the new window - Scroll down to "Windows Audio", right-click on it and select Properties.
Another new window - set the startup type to Automatic, click Apply and then click Start.
Have a look in "Play control" and any other sound mixer you may have installed to check if the sound is muted.
Go to Control Panel >> Sounds and Audio Devices.
Check to see if your sound card is listed.
If no audio device is detected proceed to step 5.
Be sure the Volume is turned up (at least half way).
The MUTE box should not be checked (go to the advanced window and make sure that nothing is muted).
Select the proper speaker settings under speaker settings advanced tab.
Set the speaker setup settings accordingly.
Is your sound card the default playback device?
Right click the speaker icon next to the clock >> Choose "Adjust Audio Properties".
Click on the Audio tab and select the correct device.
If you make any changes - click Apply, then OK before you close the window.
If you use another type of audio program, please refer to that program's trouble shooter for diagnostics.
Creative Sound Card owners can try this:
Click Start >> Programs >> Creative >> "Sound Card", for example Audigy >> Creative Restore Defaults.
4.
Check to see if the sound card is properly installed in the Device Manager.
Right click My Computer >> Properties >> Hardware Tab >> Device Manager >> in the "View" menu - click "Show hidden devices".
If there are yellow or red "marks" next to the audio, "Microsoft Universal Audio Architecture (UAA) Bus" or an unknown device - install drivers (see step 6).
If Windows does not detect an ONBOARD (Integrated) sound card >> Check to see if it is ENABLED in the BIOS (Setup).
If Windows does not detect a PCI sound card (an Added sound card) >> Shut the computer down, disconnect power. Take the sound card out and put it back again - if possible, use another PCI slot.
5.
Install available Windows updates, including DirectX.
Go to Start >> All Programs >> Windows Update.
6.
Installing drivers:
6a. Install the chipset driver first >> Reboot.
6b. If a "Microsoft Universal Audio Architecture (UAA) Bus" is present in Device manager >> install the driver >> Reboot.
6c. Uninstall old sound drivers:
Check in Add/Remove Programs in the Control Panel for an Audio device driver (i.e. AC97).
Go to the Device Manager and uninstall the driver (Right click on the device >> uninstall).
Install the sound driver >> Reboot.
The drivers to install can be found on a CD that came with the computer/motherboard/sound card.
Jan 12, 2010 | Asrock (P4COMBO) Motherboard
I have no sound coming from my speakers , it s telling me I have no audio output device is installed.Everything is plugged in .
Click Start
Click Control Panel
Click Classic View
Click System
Click the Properties tab
Expand the "audio" branch of the tree.
Do you see an audio-device? Probably not.
Do you see an "Unknown Devices" branch of the tree?
If so, expand that branch, and double-click the "unknown" device.
Click "Reinstall Driver".
If asked whether you want to search the Internet for the software-driver, click "Yes".
Windows will install the drivers for the "audio device".
Nov 08, 2009 | Dell Audio Players & Recorders
No Sound... Multimedia Audio Controller Issue
i have a dell dimension 8100 no audio device the multimedia audio controllers has a yellow question mark ive try fixing but cant
May 09, 2008 | Dell Dimension 8100 PC Desktop
My thinkpad doesnt works!
If you can, upgrade to WinXP (or LINUX) which will make things easier, or else use the re-install disk for your laptop. If you really want Win2000 to work and have lost your original disks, you need to download the appropriate drivers for that machine and install them under Win2000. It is the only way to get things up and running again. Make sure in device manager there are no yellow marks showing error state devices.
Don't use a driver management or automated program to install the drivers; download them one by one from the IBM web site and install and reboot cycle each one separately.
Good luck...
Oct 20, 2007 | IBM ThinkPad A21e 2628 Notebook
Sis 6326, (4 MB) Graphic Card Logo
43 people viewed this question
Top Sis Computers & Internet Experts
ashu k...........
Level 1 Expert
David
David
Alun Cox
Are you a Sis Computer and Internet Expert? Answer questions, earn points and help others
