Question about GE JVM1650 1000 Watts Microwave Oven
Microwave fan not running - GE JVM1650 1000 Watts Microwave Oven
  • William Miller
    William Miller May 11, 2010
    Do you mean the internal cooling fan or the exhaust / vent / hood fan?
    Have you had trouble with the stove top lights recently?
    Also, please reply back with your brand and model number so we can help you.
  • 431 Answers
The stirrer blade has a belt to run the fan located on top
Posted on Aug 16, 2010
  • 456 Answers
99% of the time i have encountered this problem you need to replace the motor that the fan rotors sit on. other than that one i have encountered had a sensor attatched to the circuit leading to the motor
Posted on May 21, 2009
Why is the microwave running without being turned on?
These above range microwaves "hoods" automatically turn on a cooling fan even when the microwave is not in use. If you read the manuals you will see warnings about the fans automatically starting. Even when the microwave is not in use opening the door likely interrupts the power to the automatic cooling fan.
Jul 29, 2014 | Whirlpool GH7155XHS Microwave Oven
When running the noise sounds like the fan is not working correctly.
when microwave is running the fan sounds like it is grinding
Feb 03, 2013 | GE JVM3670 Microwave Oven
Making a sound (I think from the fan) when operating
If it is only when he exhaust fan is on, something is in the fan. Remove the grill and investigate. If it is from the Magnatron fan you will have to remove the front panel.
May 19, 2010 | Whirlpool GH5176XPS Microwave Oven
Sometimes the microwave shuts off (and will not restart) during a cycle--as if it internally overheats. After a period of time, it will again operate properly
It is overheating, but what I need to know does the fan work when microwave is running and at some point the fan cuts off even with the microwave still running? if so it may be that the fan is kicking out and then microwave runs and gets hot.
Aug 24, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Fan doesn't work on my RMW1199 RCA MICROWAVE OVEN
The oven is overheating due to a faulty cooling fan. Foirst check it is not fouling anything if not you will need to get a replacement fan motor
Mar 23, 2009 | RCA RMW729 Microwave Oven
GE JVM1870 Spacemaker Microwave Fan Malfunctioning when Cooking
There are two different fans in this model, as with almost all over the range microwaves.
One is the hood vent exhaust fan, which you can turn on and off at will, and which should always be on when cooking on the stove top.
This fan does not automatically come on when you cook with the microwave.
The fan which should always be on (automatically) when you are microwaving is the internal magnetron cooling fan.
If the cooling fan fails, the magnetron can overheat and the thermal cutout (TCO) / thermostat will open, killing the power to the oven. Ideally, this protects the magnetron from being destroyed.
If the thermal device is a thermostat, it will reset when it cools down, and the oven will work.
If the thermal device is a true thermal fuse, it is a one-time device and if it blows, it will have to be replaced.
If your cooling fan is bad, it needs to be replaced before using the microwave.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
Sep 16, 2008 | GE JVM1870 Microwave Oven
Goldstar microwave exhaust fan will not turn off
We had this happen to us tonight. We unplugged the microwave oven for 15 seconds and then plugged it in, but it the fan was still running. We then unplugged it for 30 minutes and the fan worked properly when we plugged it in again.
Jan 09, 2008 | Microwave Ovens
Ge Spacemaker XL 1800
Jan 06, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Exhaust fan
the fan may be clean, may be fan bush struck thats why fan running not properly, check the internally inside the microwave oven , you should carefull inside micro wave oven very high voltage .
Aug 05, 2007 | Maytag MMV1153A Microwave Oven
GE JVM1650 1000 Watts Microwave Oven Logo
57 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
