Use of computer ups for lighting purpose
1. can i use ups meant for personal computer to run fan and lights?
2. what is the ac wave pattern produced by computer ups?
  • tkondago Aug 19, 2008
    Thank u very much for the solution given. your solution is very useful.
    Brigadier General:
  • 6,966 Answers
To your concern of using a computer type UPS to power other devices:
  • If the light is incandescent type, yes;
  • If the light is florescent type, depends on the design. Some yes, some no. If the ballast is electronic, yes; if the ballast is inductive, no;
  • on the fan, no.
To my knowledge, most low-end commercial UPS produces a square wave. Only high end (expensive) models produces true Sine wave.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Aug 19, 2008
Where is the VSS is located on a 2004 SRX?
Inside the transmission , pull the pan ! It's the out put speed sensor.
The A/T OSS sensor is a variable reluctance magnetic pickup located in the rear of the transmission case. The sensor is mounted in the case (24) opposite the rear internal gear (560). The rear internal gear is splined to the output shaft assembly (562). The sensor consists of a permanent magnet surrounded by a coil of wire. As the output shaft and rear internal gear rotate, an alternate current (AC) is induced in the coil by the 'teeth' on the rear internal gear as they pass by the magnetic pickup. Therefore, whenever the vehicle is moving, the A/T OSS sensor produces an AC voltage signal proportional to vehicle speed.
At the TCM, the AC signal is electronically converted to a 5 volt square wave pattern. The square wave pattern can then be interpreted as transmission output speed by the TCM through the frequency of square waves in a given time frame. The square waves can be thought of as a representation of the rear internal gear teeth. Therefore, the more teeth or waves that pass by the magnetic pickup in a given time frame, the faster the vehicle is moving. The square wave pattern is compared to a fixed clock signal internal to the TCM to determine transmission output speed. T
Oct 19, 2015 | 2004 Cadillac SRX
A/C and Heater, Drivers side airbag light
For bower fan check:
- Speed controller assembly of blower fan.
- Wiring harness and fuse
- Blower fan.
To solve the air bag light problem retrieve the SRS error codes with the help of diagnostic computer and follow the description.
You can also check the error codes manually as described below.
Procedure:
Read the blinking patterns of the DTCs. As examples, the blinking patterns for the normal system code and DTCs 11 and 31 are shown in the following diagram. The first blinking pattern indicates the first digit DTC. The second blinking pattern occurs after a 1.5-second pause. If there are two or more DTCs, there is a 2.5- second pause between each DTC. After all DTCs are shown, there is a 4.0-second pause, and they are all repeated.
HINT:
• If 2 or more malfunctions are found, the indication begins with the lowest numbered DTC.
Feb 26, 2014 | 2006 Toyota Matrix
Crank and cam censer
You need a scope or a graphing multi-meter to test these sensors. You need to be able to see the wave form pattern to determine if they are working properly. 2 wire sensors are AC signal generators and you should not be testing these unless you know what you are doing as they generate AC current. You can ohm test 2 wire sensors when they are disconnected. Not a reliable way make a positive diagnosis unless they are out of range. In range sensors can still be bad. 3 wire sensors are hall effect type sensors and produce a square wave form. They are not dangerous to test you just need the right equipment and knowledge.
Dec 19, 2013 | 1991 BMW 5 Series
Cp9430r
Fixed Hunter ceiling fan with remote light pin out wiring 9 wire plug search words
Hunter Ceiling Fan with remote, fails to turn on light, fails to turn on fan..remote receiver is Cp9430r
1) Test your remote, Hunter uses Radio Frequency remote, point RF remote one inch from antenna of working AM radio, press each button on remote, each button will produce static sound from AM radio, if no sound..check battery wiring or solder connection on loop antenna of remote. If no sound on one or more buttons, disassemble and wash key pad with dish soap, rinse and fan dry, retest. If still one button no work apply graphite paint to button to rebuild conductivity of button.
2) Cp9430r receiver is below fan and above light. Remove light assembly, check receiver dip switches, mine was #5 On 1~4 Off, check remote control dip switches in 9v battery compartment also set #5 On 1~4 Off, new 9v battery still no Fan reversal "click" sound heard coming from the large Blue fan reversal relay located inside the Cp9430 receiver. All other buttons control transistors and will make no sound even if they are working.
3) Disassemble / unplug 9 wire plug from Cp9430r receiver, place receiver on wooden table, 9 wire plug has two empty pin squares, one empty in the center, the other empty we will call #1 ..counting clockwise #2,#3...#4,#5..#6,#7and finally top center next to empty #1 is #8. Now #8 is 110v hot/black ...& #4 neutral/white.
4) Shock Danger..carefully apply ac volts to pins #8,#4 use tape if needed, locate quad operational amplifier i call it radio receiver chip HA17324 on board, google HA17324 Datasheet, locate leg #14 it is across from leg #1. Locate small yellow ceramic capacitor very near leg #14, use capacitor's neg as neg for voltmeter, test volts at #1,#7,#8 and #14. My #1 was 3.1v, #7 3.2v, #8 3.25v and #14 .01v ...why #14 so low? I monitored each leg while pressing remote control buttons...no changes. **Desperate, I sparked (1/2 second or less) #14 with 3.14v from positive leg of yellow capacitor** and retested all legs, no change except now #14 rests at .02v and jumps to 2.5v~2.8v when any button on the remote is pressed then rests at .02v. Now Lights work, Fan speeds work, Reverse rotation Works :-)
Pin Out on 9 wire plug, #1 Empty pin, #2 Alternates w up/down fan rotation, #3 goes to 5uf fan capacitor other side of cap goes to white/neutral AC Line, #4 AC Line neutral, #5 goes to Triac? speeds? , #6 Alternates up/down fan rotation goes to up/dn blue relay, #7 goes to up/dn blue relay looks to be AC hot looking for fan probably paired with #3 changing sides at up/dn blue relay, #8 AC Line hot in. Why did **sparking** work, smarter people might know, i think a small spark got stuck in the chip and sparking helped the chip release it out. No electrical education, novice. Jer. 51 8,9 and 11
Feb 24, 2012 | Hunter (25417) Ceiling Fan
My samsung microwave oven is not heating up food. It works normally, lights on, food turning on plate, but not heating the food.
if your microwave does everything you have described , and you can hear the cooling fan running as well after you press the start button , you probably have a faulty wave guide. The wave guide is also called a Magnetron Tube. It is the main part of the microwave which produces the microwave energy . If this part is not functioning it is best to replace the entire unit, rather than have it repaired .
Oct 03, 2010 | Samsung Microwave Ovens
Emachine total black , this are on fan
LED lights are on? Fans spin? I suggest you have a bad Power Supply.
1) eMachines are noted to have low quality Power Supply's.
Saves eMachines money so they can sell budget computers.
2) A bad Power Supply is one of the leading causes of computer failure. I have, (Had actually), a shop half full of computers with this 'ailment'.
Some caused by the owners never cleaned out the inside of their computer, nor the inside of the Power Supply, with a can of compressed air for computers on a regular basis as needed.
3 to 5 years without cleaning the inside of their computer.
Mice could have made nests inside easily, with the 'Gunk' that was there. A bald eagle could have too. Rant off.
Others, caused by the computer manufacturer used a low quality Power Supply.
Low quality components used inside.
One of the major components that fails, is caused by a particular Electrolytic Capacitor that is used.
http://en.wikipedia.org/wiki/Capacitor_plague
3) Power Supply's used in PC's are a type of SMPS.
(Personal Computer. Statement holds true no matter what type of personal computer it is)
[ SMPS = Switched-Mode Power Supply
PSU = Power Supply Unit
All terms relate to a Power Supply used in a PC ]
A bad Power Supply will have a weak voltage power rail.
There are three major power rails used in the ATX form factor Power Supply, for an eMachines T6420 desktop computer.
A) The 3.3 Volt power rail (DC)
B) The 5 Volt power rail (DC)
C) The 12 Volt power rail (DC)
(Two D cell flashlight batteries produce 3 Volts DC)
A Power Supply with a weak voltage power rail, may have enough power to light LED lights, and spin fans, (or spin a few times, ans stop), but won't have enough power to turn the Processor on.
1) ALL the LED lights combined use less than 1 Watt of power
2) EACH fan uses 2 to 3 Watts
3) A typical Processor can use 51 to 125 Watts.
Depends on what Processor it is.
eMachines T6420?
Uses an AMD Athlon 64 3400+, processor.
(Socket 939)
[The motherboard used is an MSI ms-7207
Also known as K8NGM2-L ]
http://www.emachines.com/support/product_support.html?cat=Desktops&subcat=T%20Series&model=T6420
This Processor can use Up To 89 Watts.
http://en.wikipedia.org/wiki/List_of_amd_athlon_64_processors#.22Newcastle.22_.28CG.2C_130_nm.29
No Processor running, No computer.
No computer = No Video Signal
Suggest using a KNOWN to be Good, Compatible power supply, for a test unit, if available.
Should be the ATX form factor.
Approximately 6 inches Long, (15.24cm), 6 inches Wide, (15.24cm), and 3-1/2 inches Tall. (8.89cm)
250 Watts.
Correct amount of power cables, and the correct type.
Sep 20, 2010 | E-Machines T6420 PC Desktop
I have a Toshiba 1415 S173 laptop I'm working on for a friend. On AC power, plugged in light comes on, stays green. Battery light will glow amber/yellow while charging, and then glow green when it is...
Hi
Once before I had a similar Toshiba come into the shop. Try turning the unit on without the battery installed and on the good Toshiba charger. The computer batteries have a minimal current level and once power has gone below this level they will cause all kinds of problems. If the Toshiba now works, you're home free - just replace the battery. If it doesn't work then it will have to see a reputable repair person who can troubleshoot chip issues. I've seen these clone power supplies do all kinds of things to computers.
Mar 13, 2010 | Toshiba Satellite 15" Flat Panel LCD...
1994 c280
The 2 AC fsnd turns on when the Engine temperarure hot. It receives the signal from ECU throught the Engin temperature sensor ( Coolant). Your case happens since the Engine Temp sensor went bad. At beginning the temp sensor can not produce any resistance just like open then ECU thinking engine hot turns on the Fan. When your engine ia about 85, it is a normal temp then the sensor could produce some resistance matching the look up tabel for the ECU, then the ECU turn off the Fan. Some pepople has it run all the way since the wire contact to the sensor was off. Replace the Engin Temp sensor to take care of the problem.
You have 2 temp sensors on top engine, one for your temp read out, one for the fan purpose. If you don't know which one, wait for your temp at 85 and the fan is stopping, then unplug one, imediately the fan goes on, that the one. Good luck.
Jul 05, 2009 | 1994 Mercedes-Benz C-Class
Roland Spd-s pad #1 change to different patches when hit
I think there is an option in the setup menu that makes the pad do this.... i remember reading it in the manual. sorry cant help more than that...
Aug 08, 2008 | Roland Spd-S Sampling Percussion Pad...
Computers & Internet Logo
596 people viewed this question
David Payne
David Payne
