No picture but thereis sound - Televison & Video
  • 2,920 Answers
It sound like the main board may be outthe one that controls the tubes in the tv
Posted on Aug 17, 2008
No sound but when i play a dvd thereis sound
No sound when play a DVD but ok on regular tv?
Dec 18, 2012 | Hitachi Televison & Video
No picture or sound when I plugged in HDMI cables to back of PDP-R04E media receiver
Hi there
I do not know what SKY is,but if it is a kind of a transformer that is connected to the router. I have that because of the ADSL.
I discovered that this transformer has to be "new" in order to plug the HDMI cable in the transformer and the HDMI socket. I hope my English is understandable because this HDMI and scarts are a bitcomplecated to explain but simple inpractice.
all the best
Feb 29, 2012 | Audio Players & Recorders
I am able to get the motion of the video but there
The C182 records audio but does not play it back. To hear your videos, first transfer them to your computer and play them back there.
Jun 01, 2010 | Kodak Easyshare C182 12MP Digital Camera
Gas dryer works, but does not heat
Hello there:
here is a discriptive way of trouble shooting the dryer and it lists the common components that will normally fail if the element has not failed first
Gas Dryer Diagnosticsgasdryerguts.gifThis picture shows the main parts of a gas dryer's burner systemthat can fail. Understanding each component and it's failure mode canreally help diagnose a problem with a gas dryer.
Ignitor failure: The drum turns but the igniter doesn't glow, thereis no clacking sound as the gas valves open and there is no flameignition sound.
Radiant Sensor failure: The drum turns but the igniter doesn't glow,there is no clacking sound as the gas valves open and there is no flameignition sound.
Gas Valve Solenoid failure: The drum turns and the igniter glows andgets turned off but there is no clacking sound as the gas valves openand there is no flame ignition sound.
And another component failure to be aware of, but that's not shown here, is the operating thermostat:
Operating Thermostat failure: The drum turns but the igniter doesn'tglow, the gas valves don't open (there is no clacking sound) and thereis no flame ignition sound.
And here's a picture of other components to ohm out if you're getting no heating at all:
Nov 21, 2009 | Hotpoint Dryers
I have a sony 61HS10 rear projection tv. The small displays work, showing two or more pictures at the same time but when you want to display just one large full screen picture there is sound but no pi
As you told big picture freeze is working ,then there could the problem in the main processors which not to able pick video input signal ...If you would like to attempt a DIY, you will need a service manual to guide you. You can find one here: which also contains the part number incase you need a new part...
Good luck.....
Dec 06, 2008 | Sony KP-53HS30 53" Rear Projection...
Plasma tv has sound but no picture
Check all the cable connections at the back, if you are using an external receiver , then check the Video cable, eventually try a replacement one.
Try leaving the TV set unplugged for a couple of hours, this will drain power completely and, if there is no real fault , this can fix the problem.
If that does not fix it, then thereis an internal fault.
Common faults that cause audio but no picture concern, digital board, controller board, sustain boards, Plasma screen ribbon cables, and plasma display.
Call the number listed on the owner manual to get assistance.
If the warraty is expired no longer than three years, ask the price fod r a warranty extension calling same number in the manual.
Nov 22, 2008 | Televison & Video
Sound is missing
i have a laptop 739au with xp window i want audio driver
Nov 15, 2008 | Compaq Presario 700 470024-192 Notebook
I have a 57 inch zenith hd tv and just recently i started to get a double picture and i was told it wasnt the picture tube what could it be.
No it ie not the picture tube thereis a module inside the tv that needs to be replaced. convergence module it's about $100.00
+ labor
Thank you
Aug 17, 2008 | Televison & Video
RCA Telivision
The beeping sound is caused by the power supply trying to turn the set on then off. Your failure is a bad high voltage transformer and subsequent failure of the horizontal output transistor. Probably not a cost effective repair.
Mar 01, 2008 | Televison & Video
Televison & Video Logo
32 people viewed this question
Top Televison & Video Experts
