Question about Food Mixers
Control circuit board
Hi, I have a oster electronic touch control kitchen center 16 speed. I need a replacement control circuit board. Also the wiring diagram for the circuit board to place the wiring harness back on it. Thanks, George
geo.nitzschke@sbcglobal.net
5 Suggested Answers
geox29
  • 65 Answers
SOURCE: Oster kitchen center driver removal
http://www.oster.com/CustService.aspx
The customer service will help you to find the right answer to your question.The do also have technical repair center or they will tell you how to return the item for replacement.i used before and they work good
Posted on Jun 18, 2008
greenspan
  • 1734 Answers
SOURCE: Oster Kitchen Center won't hold a steady speed
Here is a Oster Kitchen Center service manual for download.
Posted on Nov 11, 2009
  • 223 Answers
SOURCE: my unit is an 10-speed Oster Regency controlled
I've got one of those, it's a pretty nice system.
What was the problem you're having?
lp
Posted on Dec 26, 2010
trial2962
  • 107 Answers
SOURCE: 10 speed - 12 speed arms
Arms from 10 speed OKC and 12 speed OKC are identical. The arm from 10 speed OKC fits to 12 speed OKC.
Posted on Sep 04, 2011
Was working few years but doesn't start at all.It being a month without using it, then trying to turn it on but nothing.No issues before. Watched DIY videos just replaced its Phase board, nothing
You really need to get a Multi meter and follow the power, you have replaced the phase board so we can probably discount it being that.
First check that the switch contacts behind the black control board are really touching when you move the speed control lever to turn the mixer on.
Next the cable, do you have continuity from the wall plug to the control board on phase & neutral, (Check green earth wire as well for the sake of safety) that will be the black wire and the white wire on the 2 lower plug in contacts on the black control board at the back.
Next remove the carbon brushes, do they have reasonable length and most importantly are they fitted correctly with the corner key aligned with the blocker at the bottom of the brush holder.
Next with brushes out check for field winding continuity. On the other side of that black control board to where the power comes in there will be a red wire and a white wire that disappear into the motor housing. One of the wires will have a circuit to one of the brass brush holders and the other wire will have a circuit to the other brush holder. The resistance of both of those circuits should be pretty much identical.
After you have done those tests you should begin to have a clue as to where the problem lies.
Feb 17, 2015 | KitchenAid KSM90 Ultra Power Series Stand...
Is this a Kitchen Aid? Is it possible to buy this circuit board from somewhere?
This is a kitchen aid. BUT!!!! it is an international model that was sold in countries with 220 volts. Look underneath the mixer for a white tag it should have a model number and a serial number, if you can get us those numbers then we can help with the parts. Hope this helps.
Nov 05, 2014 | Food Mixers
My kitchenaid mixer run on high at all times
If your mixer only runs on high speed there are 3 things that can cause that. The first thing to check will be the speed control plate, Remove the trim and end cover on the mixer, the first thing you should see is the speed control plate, this has 3 screws on it, try adjusting the top two screws 1/4 turn, this should slow the mixer down, do not over tighten. Also check to see if the control plate spring is unhooked. If the spring is unhooked, attach to bottom of the control plate, and squeeze the spring end.
If this does not fix your mixer, check the wiring of the mixer, you can locate a wiring diagram on the last page of the service manual.
If the speed control plate is adjusted correctly and all the wiring is correct it will be your speed control phase board. You can test the speed control phase board to see if it is shorted. With the line cord disconnected, pull the t-b ar contacts to open, and insert a piece of paper between them so they cannot close. Reapply power-the mixer should just run or buzz trying to run. If it operates at full speed, teh phase control board is defective and needs to be replaced.
Here is a link to the service manual: http://lib.store.yahoo.net/lib/mendingshed/kitchenaidservicemanual.pdf
This will aid you in taking the mixer apart, troubleshooting and putting it back together, remember the wiring diagram is the very last page.
Thank you,
Colleen
Customer Service
MendingShed.com
800-339-9297
Jan 07, 2013 | KitchenAid K5SS Mixer Speed Control Plate...
Found the answer on the internet. THanks.
Nov 22, 2008 | Food Mixers
Instruction manual for oster kitchen center
how do iget the driver gear off
Sep 03, 2008 | Food Mixers
Jun 12, 2008 | Oster Food Mixers
My wifes Oster Kitchen Center slowed down and I think finally stopped. I say I think it did because I took it apart two years ago and am finally finding the time to get it back together. I cleaned it, checked the brushes on the motor(all of this is in the base unit with the control buttons on it. The upper blender/beater arm has no electrics in it.) The brushes were coated with some kind of dried crusty stuff which was keeping them from contacting the motor.I put it back together and tried it but it only hummed and did not move.
I took it apart again, this time everything came out. Motor, electric wiring plus the metal gearbox attached to the motor which drives the blender and the upper arm. I took the transmission apart (it's attached to the motor in the base unit) and found the gears in it were so gummed up with who knows what. Probably everything that leaked out of the blender.
You see, what happens is that the seal between the blender black base and the glass jar started to leak after a few years but we don't notice it. Maybe we did but we cleaned it and we thought it was all good. But the liquid can leak down into the bottom unit around the drive teeth and that little square drive that the blender locks onto. And then it goes into the gearbox and the motor. So it is a major job to clean it. Since I don't have a manual for disassembling the lower base unit, I'm just putting it back together. I cleaned all the gunk out, put some grease on the gears and the gearbox is working better but I fear not perfect. It is 30 years old!! So unless you take it apart yourself or find an appliance repair shop (is there such a place anymore?) it might not be worth the effort. But it is do-able. How long have you got?
Mar 01, 2008 | Food Mixers
Food Mixers Logo
149 people viewed this question
Top Food Mixers Experts
Oscar Netto
Oscar Netto
Are you a Food Mixer Expert? Answer questions, earn points and help others
