Question about Sansui DTV2760 27" TV
Tv is not wrking
Could u pls help me bcs my tv is not wrking
  • 2,071 Answers
First, locate the horizontal output transistor. This is found very close to, or next to, the horizontal output transformer (also known as the flyback). The flyback should be on an aluminum heat sink, or on the side of the metal chassis. Disconnect or unsolder two of the three legs of the transistor. Measure it with your meter, or plug in the set with the light bulb attached across the fuse.
If the transistor is shorted, or the light bulb doesn’t glow bright anymore, replace the transistor and plug back in. If the light bulb glows bright again, you must replace both the flyback and horizontal output transistor simultaneously. In some cases this will fix the set, but sometimes there are multiple problems with a set.
Go to where the flyback is, and start measuring the diodes and capacitors on the flyback itself. If you don't find any shorts there, it could be a shorted vertical output IC, a shorted sound IC, a shorted disc capacitor in the Hi Voltage/sweep circuit, or in rare cases, a shorted capacitor or tuner.Feel free to ask and post whatever the result of your troubleshooting..
Hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE
Posted on Aug 21, 2008
SOURCE:
Scrolling quickly through albums on an ipod connected to a Pioneer BCS 717
i brought an mp3 player and i need to know how text on this stupid thing
Jul 03, 2013 | Apple iPod nano
1999 honda odyssey, drl not working and one headlight not working
i'm mention abuot my starter wont start even i replace my batery its no power light ang radio is wrking thanks pls reply
Apr 03, 2013 | 1999 Honda Odyssey
Whatsapp for nokia N72
is it possible to download whatsapp on nokia N72?if yes pls how can i install it.
Nov 11, 2011 | Nokia N72 Cellular Phone
Looking for user manual fot a charactor genetor
The manuals you require is:
http://www.bcs.tv/pdf/model/18206/18206.pdf
Hope this helps,
Chris
Mar 01, 2011 | Panasonic WJ-KB50 Keyboard
I could not use msg service bcs the msg i send that can not reflect in msg box,neither the msg i received that can't be read.at the same time if i enter chat room,after click any particular room i can not...
This is cause by some plugin error.
may be you can not see messages even after reinstalling yahoo messenger.
so...here is the easy way to solve this problem.
1- create a "NEW USER ACCOUNT" from 'control panel>user account for yourself and restart your computer.
2- login to the new user account and go to control panel> user accounts, and then delete ur old user account ( u may want to save your personal folder and files when prompt)( if you want to save your internet explorer favourites , do it manually )
3- just connect your internet and enjoy yahoo messenger.
Dec 21, 2010 | Yahoo Messenger
I am a LAN user and i am using proxy setting for internet access
The reason for proxy setting not to change is that there is some security software that is blocking the changes that is done on the computer
if you want to permanently set the proxy, tr to boot to safe mode and then set the proxy unchecked and rebooot to normal mode..
If this still does not solve the problem then there is a registry fix for it
Jun 18, 2009 | Microsoft Internet Explorer 7
Acer 7520 XP unstable usb ports
paul if so thn that product will not be launched in market.
urs is giving problem bcs of two reasons.
1. pls unnstall the USB drivers from Driver manager and then do wht i suggest.
,i think the most likely reason is bcs u havnt install the correct drivers installed for USB, pls find drivers, or download it and reinstall drivers. then restart it , the solution u will be see and infact if ur USB then also this is the soultion for that.
2. the last and leastt possible cause is ur HW problem. pls visit nearest lappy shop if 1st method doesnt work.
Mar 25, 2009 | Acer Computers & Internet
-cq60-104tu-laptop sound problem
Are you sure you are pushing the headphone plug in all the way?
Sometimes if it is out just a little you will get sound out of both devices. You might want to try a different headset and see if you get the same result
Dec 19, 2008 | Compaq Presario Notebook
Different Weights
201.4 bcs 205.4 not correct weight its depend on u r standing position and when give weigt on u r legs then weight change and u r 201.4 bcs is correct bcs weight depend on u r happness or tension and blood speed and plz reply
Oct 23, 2008 | Homedics Sc 535 Trifitness Healthstation...
Sansui DTV2760 27" TV Logo
Top Sansui Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
