Question about AT&T 5840 5.8GHz Speakerphone/Answering/Caller ID Answering Machine
Battery won't charge - Charging light won't come on.
I thought I needed a new battery, so I replaced the old one and discovered that the battery charging light won't come on with this phone on either of my two base phones or two sattelite phone stations. I have a total of three phones, only one stopped working.
    Genius:
  • 1,847 Answers
Did you chk the charger adapter working fine?
Posted on Aug 17, 2008
  • 157 Answers
Hello sir
  • John Smith
    John Smith Aug 17, 2008
    i think the charger is dead. try one of the other working chargers on the handset and see if it works
  • John Smith
    if the handset doesnt work with one of the other chargers, hen assume that its dead and you will need to send it back under warranty for repair
    Cheers
    Jigsaw
Won t charge new battery
Few options: either the connection is "hazy" (try moving the plug in the hole), battery is fake or battery has been abused and is empty...
Aug 16, 2013 | HP Mini Computers & Internet
Switronix Tl-50 won't turn on
I too have had a problem with mine no longer charging. I talked to the manufacture. Since the cord light is on however my torchlights charging light is not on they said could be the batt or could be a bad wire in the charger. I've been debating whether to send it in for fix or buy a new batt to try first. For yours I would send in for repair. Unfortunately these lights only come with a 1 yr manufacturing warranty so if you've had it over a yr you will end up paying 60-130 was the price range I was quoted depending on the problem.
Mar 03, 2013 | Switronix TorchLED TL-50 Video Light - 75...
Truck is draining charge and not charging battiers
I just went thru same thing with my 2003 f-350 diesel. I hooked up my horse Trailor and drove to Von's parked went in came back out and truck was dead. I tried to jump it didn't work. Then over next two hours two tow truck Drivers hooked up to both batteries full power charge direct to my truck and would not start.
End story required two new batteries alternator and cilanoid discussed above. In other post. Also contributing to the cause was really badly coroded cables they looked good at the connection point but wher discovered to be coroded inside the tubing just above the end connections so bow it has all been replaced and I have had no trouble since. Hope this helps. Tanya
Jan 23, 2013 | 2003 Ford F350 Super Duty DRW SuperCab
Lap top battery charging, LEDs not light but charging battery up to 76 %
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Oct 02, 2012 | Fujitsu Siemens Computers & Internet
Battery charging LEDs not light but charging up to 76 %
Oct 02, 2012 | Dell Latitude X200 Notebook
Black & Decker Cordless Drill will not charge battery
Either the charging adapter is faulty or the battery is worn out.
If the recharageable battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Jun 03, 2012 | Black & Decker Black and Decker 18V...
NEEDING TO CHARGE BATTERY. WHEN WE PLUGGED IT IN, THE LIGHT DID NOT COME ON. WE HAD IT PLUGGED IN ALL DAY LONG AND ONLY A QUARTER OF IT WAS CHARGED. FIRST OF ALL WE THOUGHT THE LIGHT WOULD COME ON TO...
Hi, Sounds like the battery is quite old which means its probably stopped being able to hold a charge which would cause the problems you've described. The solution would be to buy a new battery.
Jun 13, 2011 | Canon EOS Rebel XS 35mm SLR Camera
Hello. At first, the indicator light that shows whether the battery is loading/getting empty etc. failed. As I thought it wasn`t important I continued using the laptop. Then the battery loading adapter...
Most probably this is caused by the battery charging circuit inside your laptop. It looks like it is not charging the battery. If this is the case you won't be able to fix it yourself. You and should send it for repair.
Feb 28, 2011 | Computers & Internet
When I try to charge the battery the light just flashes and the charger does not work.
Hi, I had the same problem!
Had not used my camera for a while so I decided to but my battery on charge, once in the charger the orange light just kept flashing so I left this in "flashing" for a good hour or so.
I removed it and then replaced it, and it was still flashing so I decided to get a new battery (£40!).
I put the new battery on charge over night and it charged great, so I thought I would re-try charging my old one before I sent it away for recycle, and guess what the orange light stopped ON and it was charging!
Not sure what happened here, it was either charge the old for an hour with light flashing and then remove and leave over night and re-try OR insert a good battery to re-set the charger?
But I now have 2 good batteries.
Hope this helps :)
Apr 23, 2008 | Sony Cyber-shot DSC-N1 Digital Camera
AT&T 5840 5.8GHz Speakerphone/Answering/Caller ID Answering Machine Logo
212 people viewed this question
Top AT&T Lands Phones Experts
Paul C.
Are you an AT&T Lands Phone Expert? Answer questions, earn points and help others
