Haier HPRD12XC5 Air Conditioner Logo
Posted on Jun 01, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
There is red light that is blinking on the power button. None of the controls work, and there is no air blowing.
Anonymous
Level 2:
New Friend:
  • Expert 41 Answers
  • Posted on Jun 01, 2011
Anonymous
Expert
Level 2:
New Friend:
Answers
41
Questions
0
Helped
17489
Points
139
IF YOUR UNIT IS STILL UNDER WARRANTY CONTACT HAIER AT 877 3373639 FOR AN AUTHORIZE SERVICE CENTER NEAR YOU.
IF YOU ARE NO LONGER COVER UNDER WARRANTY YOU COULD TRY THIS THERE IS A DRAIN PORT LOCATED AT THE BOTTOM OF THE UNIT. OPEN IT AND SEE IF ANY WATER COMES OUT. THE WATER COLLECTION TANK COULD BE FULL CAUSING THE UNIT TO SHUT OFF. there is  red light - raypena_8.jpg
My 2hp Panasonic is blinking when turn on and the compressor stop working while the outdoor fan will be blowing cool air.
1. Turn power on.
2. Press the CHECK button on the remote controller
continuously for 5 seconds.
3. "- -" will be displayed on the remote controller display.
Note: Display only for "- -". (No transmitting signal, no
receiving sound and no Power LED blinking.)
4. Press the "TIMER" or button on the remote
controller. The code "H00" (no abnormality) will be
displayed and signal will be transmitted to the main
unit. The power LED lights up. If no abnormality is
stored in the memory, three beeps sound will be
heard.
5. Every press of the button (up or down) will increase
abnormality numbers and transmit abnormality code
signal to the main unit.
6. When the latest abnormality code on the main unit
and code transmitted from the remote controller are
matched, power LED will light up for 30 seconds and
a beep sound (continuously for 4 seconds) will be
heard. If no codes are matched, power LED will light
up for 0.5 seconds and no sound will be heard.
2answers
Keypad doesn work
the red light should only blink when it is running. does the incline work? if nothing works most likely a console issue
LG air conditioner blinking red power light
This is not a split system a/c unit guys. Look at the picture. The blinking light means the air filter may need cleaning. Reset power to turn it off.
4answers
My mother in law just passed away and I inherited back the Sylvania LD320SSX I bought her last year. What is the 5 digit remote code for a Comcast remote? Tried all I could find to no avail.
Comcast uses at least 11 different remote controls. I referred to the manuals listed on their remote control page for instructions on programming the three Comcast-branded remote units:
Comcast Universal Remote (Red OK/Select button)
Sylvania LCD TV codes: 20000, 20035, 20043, 20081, 20593, 21593, 21781
Procedure:
  1. Turn on the TV.
  2. Press the TV button once.
  3. Press and hold the Setup button until the TV button blinks twice, then release Setup.
  4. Enter a five-digit code from the list. If this is done correctly, the TV button will blink twice. If you enter an invalid code, the TV button will produce one long flash and the remote control will exit the program mode.
  5. Aim the remote control at the TV and press the Power button. If you have the correct code, the TV will turn off. If not, repeat steps 2-6 with a different code.
If none of the codes work, you can try the code search procedure:
  1. Turn on the TV.
  2. Press and hold TV. Press and hold Setup until the TV button light blinks twice, then release Setup.
  3. Press 9-9-1. The TV light will blink twice.
  4. Press and release the digit 1. The TV key will blink twice. Press the Power key.
  5. Aim the remote control at the TV. Press CH+ until the TV turns off. You may have to press numerous times until the remote control finds the right code in its library. Stop when the TV turns off.
  6. When the TV turns off, press Setup once to lock in the code set. The TV light will blink twice.
Comcast Universal Remote (Grey OK/Select button)
Sylvania LCD TV codes: 0000, 0035, 0043, 0081, 1781
Procedure:
  1. Turn on the TV.
  4. Enter a four-digit code from the list. If this is done correctly, the TV button will blink twice. If you enter an invalid code, the TV button will produce one long flash and the remote control will exit the program mode.
  1. Turn on the TV.
  4. Aim the remote control at the TV. Slowly Press Power and TV alternately until the TV turns off. You may have to press numerous times until the remote control finds the right code in its library. Stop when the TV turns off.
  5. When the TV turns off, press Setup once to lock in the code set. The TV light will blink twice.
Comcast Digital Transport Adapter (DTA)
Cycle finished. Red light indicating door was locked was on, yet the door easily opened. Now, none of the functions work. I cannot get the 'control on' button to work- none of the other functions light...
Hello & Welcome to FixYa
First try to reset the controls by pressing the END OF CYCLE button and hold it for 15 seconds. If the problem returns then check the door latch switch assembly and blow some air on that so that if dirt is stopping it from working it works again. If the problem returns then replacing the door lock assembly is recommended repair. Please get back to me if you have any other questions.
Kevin
Code for Sky+ remote to work with Toshiba TV AV635DB
Hi there. I have just bought the same television today and I have just found that the remote code 0156 does actually work. The mistake i initially made was not pressing the TV BUTTON after I had held in the SELECT and RED Buttons together, making the light blink twice. So here's what I did:
1. Press the TV button
2. Hold in the Select and Red Button until the red light flashes twice
3. Press the TV button again
4. Enter the code 0156 (The Red light will blink Twice again)
5. Test the controller - Try to change the volume
6. If it works, press SELECT one last time to save the settings.
Hope this helps.
apnit
My mitsubishi 65087 remote stopped working and none of the buttons on the front control panel would work either, including the power button. Couldn't turn set off, so unplugged. When plugged back in, green...
ws65087 or what?
Most of these sets have a self check feature--when power light goes off press and hold both the Menu and Input buttons for 5 seconds and release both--power light should blink a two digit code--like,,,,,,,,2 blinks a pause and 2 blinks---CONFIRM EXACT MODEL NUMBER AND ERROR CODE FOR ME.
Allow for time difference--I am in California.
sd tech
Unable to progam remote
1. turn on device 2. press setup (underneath on/off) till red light stays on the take finger off the button 3. press and quickly release device button (tv,vcr,etc.) the red indicator blinds off once 4. press the on/off button (up to 300 times) until the device is to be controlled turns off the red light blinks off with each button press 5. press and release enter to install code
Top Haier Heating & Cooling Experts
Paul Carew
Arnie Burke
Arnie Burke
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
