Question about Motorola Mobility RAZR V3
Left Side Hinge Pin for razr V3
Where acn I get a spare hinge pin .?
  • geecheeman Oct 24, 2008
    Has fallen out before, this time I can't .find it. My brother had the same problem
    Problem Solver:
  • 4 Answers
Cellular phone repair stores.
Posted on Aug 19, 2008
Retrieving data, broken screen
The Phone needs a new Keypad flex and most likely a left hinge pin. When the phone is open, the cable runs through the left side of the hinge. It is very common for the hinge pin to become chipped and put a small cut in the Flex Cable.
You can get the parts on ebay. search for motorola v3 keypad flex, and motorola v3 hinge, or knuckle.
May 04, 2009 | Cell Phones
How to Reverse Your Refrigerator Door (Most units)
1. Remove the toe grille.
2. Remove top hinge cover if available. Trace around the hinge with a soft lead pencil. This makes the re-installation easier. Remove top hinge and lift door off the center hinge pin, and set the door aside.
3. Unscrew the center hinge pin using an adjustable wrench and save for reassembly. Ensure that the plastic washer stays on hinge pin.
4. Lift the refrigerator door off of the bottom hinge and set aside.
5. Remove center hinge and shim by removing inside screw and loosening two outside screws enough to allow hinge and shim to slide out. Tighten screws.
6. Loosen two outside screws on opposite side of refrigerator, remove inside screw and install center hinge.
7. Remove two screws on bottom hinge with 3/8" socket wrench.
8. Install bottom hinge on opposite side with the two screws removed from Step 7.
9. Unscrew the bottom hinge pin using adjustable wrench. Move hinge pin to other hold in hinge and tighten with adjustable wrench.
10. Reverse door handles.
11. Move freezer and refrigerator door stops to opposite side. Before starting screws, use an awl to puncture the foam.
12. Position refrigerator door onto bottom hinge pin and screw center hinge pin through center hinge into the top of the door. Close refrigerator door to help align hinge hole.
13. Tighten center hinge pin with adjustable wrench.
14. Remove cabinet and hinge hold plugs and move to opposite side.
15. Lower freezer door onto center hinge pin (if you have a separate freezer door).
16. Close freezer door. Have an assistant lift up on opposite side of the door while tightening screws to install top hinge.
17. Flip top grille and reinstall.
18. Plug in electrical power cord and turn refrigerator temperature control to center position. Adjust setting as needed.
on Oct 19, 2011 | Frigidaire Refrigerators
Phone is working but Screen doesn't work its blank
I have a similar issue...left side hinge pin came out...found it in my pocket and attempted to put it in place and then the screen went luck...but I was able to take the motorola phone toola and retrieve the data, names, etc and move to another motorrola phone I have. A few days later I found a small wire clip thing that must ground or contact something in the luck yet fixing it. Help
Oct 12, 2008 | Motorola Mobility RAZR V3
"Bolt" replacement on Razor Phone
Be very carefull with the phone. The main cable runs through that left side.
Look on Ebay for a Left hinge pin for the V3. Also knows as the left knuckle.
Make sure you look for the V3. Not Razr.
If your speaker goes out, or you lose display before you get the Knuckle, you need to get a keypad flex also.
If not, get the Knuckle, and it just slides in. MAKE SURE before you pop it in that there are no pieces of the old one in there and that you don't pinch that cable.
I can fix it for you if you send it to our business, but if you're careful, you shouldn't have a problem.
Jul 31, 2008 | Motorola Mobility RAZR V3
Loose hinge razr v3
this link shud give you enough guidance
All the best.
Hope this works for you
Have a nice day!
Jul 01, 2008 | Motorola Mobility RAZR V3i Cellular Phone
Loose hinge
the best solution to this is to bring your phone to a certified service center as it is already a hardware problem. all the best!
Feb 03, 2008 | Motorola Mobility RAZR V3
Missing Hinge Pin
eBay! You can find all parts there.
Nov 29, 2007 | Motorola Mobility RAZR V3
hi, Check if the external display working fine, also try to unfold slowly and see if anything comes to the display,coz this is normally the problem with display change over switch. all the best sreejith
Jul 14, 2007 | Motorola Mobility RAZR V3
Motorola razr v3: hinge on left side fell out
I know what you r talking about because the hinge on my phone is loos, it didn't fall off yet. I have the blue razr but it's with t-mobile and it's unlocked so they wont fix it. T-Mobile is very helpful but u should call moterola and they will fix it 4 u. And if they give u a hard time talk to the manager.
Jun 15, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
135 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
