Question about Watches
My clock is four hours behind when it strikes on the hour. How can I correct this.
  • Anonymous Mar 13, 2014
    CLOCK STRIKES ONE TIME MORE THAN THE HOUR SHOWN
    Scholar:
  • 132 Answers
What type of clock is it...
Analogue / Digital
Does it have a calibration ?
What stops you from forwarding the clock by Four Hours ?
Posted on Aug 17, 2008
It's a 3 key chime and strike clock that chimes every 15 min and strikes hours. for last one month it doesn't chime at 12, 3, 6, and 9 position and the hour strike is not synchronous with min hand
More than likely, there are springs that activate the levers for it to chime, or bong, they may have got jammed up, you can open it up, and see if you see anything like that, if not, you will have to take it to your local jewelry store, or watch/clock makers to have them take a look. You never indicated what type of clock (make or model) so I can\'t be certain. Maybe a ships clock? They may want to charge you for a overhaul of the movement, but you can tell them to just "make it work" if it was running fine before (keeping time well) then an overhaul probably isn\'t necessary. It sounds like something may have got jammed.
I hope this helps !
Nov 16, 2013 | Watches
How to adjust a Hermle grandfather clock?
you can try this although it may not work with your movement: set the clock at 9 and then move the hands forward past the 12 position. count the strikes. move the hands backward to the 9 position and then advance forward to the 12 position. count the strikes. did the strikes increase by one? if so, keep doing the same thing until your get 12 strikes when you are on the 12. then you can move forward and set the correct time and have the correct # of strikes.
Jul 25, 2013 | Watches
I have a cuckoo clock . Time is 11 and the cuckoo chimes 8 times . What do I do? It's a non mechanical clock
If the clock is chiming like this it means that the hour hand is out. GENTLY loosen the hands, place the hour hand on the hour that the clock has chimed then fasten the hands in place. Gently move the minute hand clockwise Only, and check each hour that it strikes right. If the cuckoo has a button at the back use that instead. For more information email me at yvonne.finch@gmail.com
Mar 08, 2013 | Watches
I have a quartz president wall clock, I changed the battery and set the time OK but the chime needs setting and I have no instructions as it is a very old clock
These are general quartz wall clock instructions as I dont know enough about what type/style of clock you have.
  • Open the access door to the dial and hands of the clock if required. Some battery-operated clock movements are sealed inside the clock case with a back panel that is screwed in place. To gain access to the hand set knob, remove the back panel screws using the appropriate tipped screwdriver.
  • Turn the minute hand (or turn the hand set knob at the rear of the movement if access is available) carefully counterclockwise or clockwise until the correct time is reached. Keep in mind that using the hand set from the rear would require turning the knob in a clockwise direction in order for the hands to turn counterclockwise.
  • Move the hour hand carefully with your fingers near the center of the hand to the hour that the clock is striking if the striking chime is not counting the correct hour. The hour hand is a friction fit hand and will move without engaging the minute hand.
  • Replace the back panel and tighten the screws with the screwdriver if removal of the back panel was necessary to access the hand set knob.
  • Close the front access door if required.
  • Aug 15, 2010 | Watches
    Have a Galleria Grandfather clock thats chimes are off. How do I get them correct? Bought it at an auction and did not get any information with it. It chimed correctly in the beginning.
    I suspect that the mechanism needs cleaning.
    Take a look inside and if there is the slightest sign of dirt (particularly on the striking mechanism) then it should behave properly after cleaning.
    May 01, 2010 | Watches
    I have an antique clock that requires two places to wind it up. Since Daylight Savings Time went into effect, the clock has gone crazy, chiming the hour on the half hour and chiming three hours ahead. What...
    With only limited information provided about your type of actual antique clock this symptom has to conclude that your clock is a non self correcting style.
    Step one: Ensure clock is striking the hour. during the time of the hour strike quickly move the minute hand to the hour.
    Step two: Move to the half hour allow to strike, move hand to hour allow to strike then move the hour hand to align with the correct count.
    Step three: Stop the clock until the correct time has been achieved and start clock OR strike ever hour and half hour until clock is set to the correct time.
    Hope this tip guides you to a solution for your clock.
    r/ David
    http://antiqueclock.clockstop.com/
    Apr 06, 2010 | Watches
    My new wall clock chimes 2 minutes BEFORE the
    You will need to do a mechanical adjustment to the hand.
    Loosen the hand nut and adjust the hand the tighten.
    Hope this tip helps to solve your problems
    R/
    David
    Mar 19, 2010 | Watches
    I have a forestville wall clock with the pull down weights. when it chimes it is behind in time. example nine oclock chimes seven oclock, it is a made in germany clock but what year i do not know. there...
    Stop the pendulum of the clock exactly at any even hour. Lets say at 6.00. While clock is steady and not working, pull off the minute and hour hands off the pinion, but do not brake them. You have to pull without any twisting action. This will leave pinions exactly in place they were when you stopped the clock. When it is done - push the hour hand back onto the pinion and make sure it is pointing at 4 (not 6, as it was when you stopped the clock). When hour hand is back in place and pointing at 4, push back minute hand as it was when you pulled it off - pointing at 12. Make sure hands will not catch when passing each other (you can bend them slightly if needed). Now swing pendulum to start the clock and adjust time (clockwise only). Never adjust time when clock is chiming. Rate me, plz.
    Feb 02, 2010 | Watches
    I have a Schatz mariner ships bell clock (from 1955-60). Am not sure how to set it, especially for the bell strike...1 website says to move the hour hand, another says NEVER touch hour hand. Can anyone...
    My Father severed his apprentiship at Augusta Schatz in Triberg. Never move the hour hand only move the minute hand, I know it is lond winded but does not un seat the hour hand fixing. But most important NEVER move the hand backwards ONLY forwards as this goes against the workings of the movement.
    Dec 01, 2009 | Watches
    Watches Logo
    323 people viewed this question
    Top Watches Experts
    Ansel Alberto
    Ansel Alberto
    Are you a Watch Expert? Answer questions, earn points and help others
