Question about Comfort-Aire BHD-501 Dehumidifier
Water leaks around the bucket even the bucket is in place-bucket collects a little bit of water
I bought the dehumidifier more than 2 years ago. I was happy about it until today that it leaks around the bucket. I checked everywhere including the bucket placement but still leaking.. any suggestions. thanks
  • Anonymous Sep 13, 2008
    Sorry, I don't know the answer, but I have the same problem. The dehumidifying function works fine, but every once in a while there is a small flood around it, even though the bucket isn't full. We can't even really figure out where the water is coming from, but it seems to collect somewhere in the top of the unit (you can hear it sloshing around up there) without coming down into the bucket.
  • 3 Answers
It sounds like you need to check the drain under the cooling section. It can fill with dust, lint, cat hair, spiders, etc. and prevent water from draining into the bucket. First, unplug the unit. Don't do anything with AC power present. Then, remove the 2 screws under the front panel where the air filter slides up in and pull off the control panel. There are "snap" latches in the plastic near the top that can be (are) hard to undo, so be careful. You might want to have work gloves on because of sharp edges. Prying with a screw driver will cause permanent dents in the plastic. Also, there is a small, sleeved bunch of wires that goes up the left side to the operator buttons and display. Be careful not to damage it and the circuit board it goes to. Set the front panel aside, wire attached. There is no need to disassemble any of that. The drain is a small 3/8" hole in the black plastic floor of the cooling area at the front, right side. It seems to have a fitting for a hose that feeds through to the back of the unit. Clean any foreign material from it and everything else. Test it, with the bucket in place, by pouring some water in, if you want to. Then clean the dust off of everything so it looks new. Don't get the circuit board wet. Re-assemble, being careful with the front panel wire so it is not pinched and does not prevent easy removal/installation of the filter, and it should be OK.
Posted on Sep 22, 2008
Dehumidifier seems to be running fine, but water leaking on floor even with minimal water accumulated in bucket?
Hey friend, thanks for your post!
It sounds like your dehumidifier needs to be professionally cleaned. What could be causing the problem is a buildup on the inside of your dehumidifier where the water drains out and it is causing the water to not drain properly. Additionally, I would check to verify that the drain hole is tightly secured with the plug. I know you stated that the bucket is not leaking but have you removed it to verify? Please comment back if further assist is needed. -Matt
Sep 13, 2014 | Frigidaire FDF50S Dehumidifier
I have a Haier dehumidifier, model DE45A-L and recently it has started leaking water and not collecting in the bucket. When we dump the water out it seems to just come from everywhere in the front. The...
There may have been a failure in the area where water is collected and directed to the bucket but also check to determine whether the bucket is reinstalling correctly after it has been emptied.
Sep 02, 2014 | Dehumidifiers
Dehumidifier leaking
I have a duracraft DD-TEC16E I have had this for 12 months and has been working perfectly until today , I have noticed the water is not all collecting in the tank it's leaking on the floor . Any possible solution please?
Feb 14, 2014 | Dehumidifiers
I purchased A Haier Dehumidifier 2 yrs ago on Aug 20/09( registered online) and it's been great...until today. i walked into the house, and the machine was making a VERY strange,high-pitched noise,...
Dont turn it back on your terminals on the compressor have vented causing all the freon and oil to leak out this is a fire hazzard. This dehumidifier is ready for the trash buy a new one soleus air is a lot better quality. Keep in mind all dehumidifiers are made very cheap so they are affordable and dont have a long life span. Let me know if this helps.
Jul 21, 2011 | Haier DM30EAL Dehumidifier
HI, I bought a AD50USV gold dehumidifier at Canadian Tire 2 years ago. Last weekend when I went down to my basement there was water around the machine on my carpet! It was leaking but I cannot find the...
What has happened is the the tubing that fills the bucket is clogged. To solve this, first turn the unit OFF & Unplug it. Then, remove the water collection bucket and look up inside the bucket holder cavity. You will see either a drain hole or small tubing that drains the water into the bucket. Using an appropriately sized, 18" long, plastic Zip Tie, carefully insert the tip of Zip Tie into the hole or tubing. Continue to push it in until you reach a bend in the tubing. You will need to gingerly work the Zip Tie past this bend, until it either bottoms out or you run out of usable Zip Tie. Then slowly pull the Zip Tie back out while rotating (twisting) it. This will breakup any clogs. As you reach the inserted end of the Zip Tie, be prepared, as some water may follow. Reinstall the bucket, plug the unit in and turn the Master ON/OFF Switch to ON. Set the humidity extraction level to 35% or Maximum if you have a manually controlled unit. Allow the unit to run, while you monitor it for any leakage.
NOTE: If you don't have a Zip Tie, you may use something similar ( i.e.a long pipe cleaner), but NO wire coat hangers
Hope this helped you troubleshoot and solve the problem. Please let me know. Thanks.
Jul 13, 2011 | Whirlpool AD50USS Dehumidifier
Does not collect water in bucket but runs all the time
Does it have a filter?
It may be that the humidity level or temperature in the room where your dehumidifier is located is too low.
When the outdoor temperature is below 50 F, the indoor air will be dry even when the air inside is warm, therefore when it's cold outside the dehumidifier may collect little or no water.
Air conditioners will also remove moisture from the room, even if it's hot and humid outside, resulting in little or no moisture collecting in the dehumidifier bucket.
Some dehumidifiers have a deicer which turns off the compressor but keeps the fan running. When the compressor is off, moisture is not removed from the air. The deicer turns off the compressor when the room temperature is cold.
Some dehumidifiers do not have a deicer. If the room temperature is low enough, ice may form on the evaporator coil. The ice prevents the dehumidifier from removing and collecting water. If ice forms on coils, unplug dehumidifier until ice melts and room temperature rises."
Jun 21, 2011 | Whirlpool AD25BBK Dehumidifier
I acquired used Amcor AHD65 Dehumidifier a couple days ago. I was told that it is just beyond the warranty period. I assume that it is a barely a year old. However, It worked this evening a sort since it...
You may still have some packaging materials left inside the unit. The plastic pan doesn't stay in side the bucket. It's used as a drain pan on the outside. Also, be sure the air intake filter is in place, is clean and there are no packaging materials behind it.
To extract more humidity, after checking all the things mentioned above. Lower the extraction level to 32 to 35%. Lower percentages means extraction of more humidity. (i.e.200% -35% = 5% drop in humidity).
Hope this helps you troubleshoot and solve the problem. Please let me know. Thanks.
Jun 11, 2011 | Amcor AHD65 Dehumidifier
My dehumidifier M3DH30B2A*A-R runs but no longer collects water. It had been set around 25-30 and run very well for two years but then suddenly began running continuously with no effect. There's no...
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
Jun 02, 2011 | Maytag Dehumidifiers
Maytag Dehumidifer still works, but is leaking
Well life span is 3-15 years depends how long and hard you run them. 45 pint is about 1000sqft basment. rule of thumbs bigger better. run less and do a better job. I would start by filling the bucket and place in a dry shower see if you have a crack. cant find a source for the bucket discontinued this might be your problem. Repair cost are about 40-50 and hour!!!! good luck
Nov 01, 2009 | Maytag M7DH45B2A Dehumidifier
Comfort-Aire BHD-501 Dehumidifier Logo
311 people viewed this question
Top Comfort-Aire Dehumidifiers Experts
Mike Squire
Bill Long
Michael Youngman
Michael Youngman
Are you a Comfort-Aire Dehumidifier Expert? Answer questions, earn points and help others
