Question about Pioneer Televison & Video
Pioneer multi region DVD player
Does anybody know how to set this DVD to play different region DVDs? Thanks!
Pioneer DV-2012K won't play DVDs from India.
The manual will tell you how to change the zones.
Aug 29, 2017 | Televison & Video
My pioneer Dv310s was playing multi region dvds including 4 and 1 yesterday. Today when i put in a region 1 it told me it was not the right region.. what happened as it was sold as a multi- region. I am...
Depends how the region code hack was performed.
It could be a additional chip was used and either chip has failed or wire come off.
You could try unplugging player from mains for a few minutes and try again.
Is it still under warranty from where you purchased it ? If so you may have to return it.
Please dont forget to vote if you liked my answer
thanks
Feb 11, 2011 | Pioneer DV-310 DVD Player
I bought pioneer muti system dvd
Check your DVD player's color system, most multi system dvd player has to be set(PAL or NTSC) manually, NTSC for American standard. Look for this button could be a mechanical switch at the back or at the menu. Some machine need to reboot after setting. Hope this helps
Mar 04, 2010 | Samsung DVD-V90K Multisystem DVD/VCR
My pioneer dvd player model dv-310 used to be able to play all region dvds. now it just plays all region dvds that have been played in it before, not new ones. how can i fix it?
We used a usb on the DVD and now we can't watch normal DVDs on it. We insert the DVD and the player just rejects it and opens the draw.
Feb 11, 2010 | Pioneer DV-310 DVD Player
Player won't play legally imported DVD's
Hi, guessing you are from the UK? Different countries operate different regions for dvd's for instance the UK dvd players are set up to play region 2 discs, and US dvd players are set up to play region 1 discs.
This is because dvd release dates are different around the world and this stops people buying a dvd in the US and bringing it back to the UK and selling it before its official UK release date for example.
Your choices are either to play the dvds on a PC where often the dvd software will allow you to change region a number of times (be careful though as some players will let you change region say 5 times and then be locked to that region)
Or to get hold of or buy a multi region dvd player which plkays dvd'd regardless of their original region
Hope that makes sense, good luck
Jul 20, 2009 | Electronics - Others
WILL MY DVD PLAY AREA 1 AND AREAV4 DVD'S?
Hi camonk2004,
It's interesting that your DVD player was purchased in Russia but plays Region 1 DVDs. Region 1 is North America. Does your Player also play Russian DVDs (region 5)? If so, then it has probably been modified to play DVDs from multiple regions.
Check the back side of the DVD player - the rear panel should have a Region number on it. If the region number is 1, then try playing a Region 5 DVD. If it reads the DVD, then the modification that was done in Russia will probably allow it to read any DVD. IF the Region 5 DVD won't play (or if it is ejected automatically), then your player's region control os still intact, and it will only play DVDs from the same region as the one listed on the rear panel of the player (or DVDs marked "ALL").
I hope this helps - please let me know if I can be of any further assistance.
Kind Regards,
H2H
Dec 15, 2008 | Pioneer DV-U7 DVD Player
Wrong Regional Disc.
DVDs are ecoded with region codes to indicate what area of the world they are made for. These codes may be 1,2,3, etc depending on which region they are made for.
DVD player read these codes and if the disc region code does not match the region the device is made for, the player will not play the disc.
Region 1 is for USA so most DVDp players made for use in USA require region 1 discs.
Some DVD players called multi region DVD players can be set to play different region DVDs but they are typically more expr=ensive then one region players and the code must be changed each time a different region disc is played.
Aug 27, 2008 | Audiovox D1710 Portable DVD Player with...
Unlocking DVD - Pioneer DV400 k
Hi Jetix,
If the DVD player is capable of playing other regions, you should be able to change the region setting through the menu section. If there isn't an option to change the region settings in the menu, then your DVD player is not able to play other DVDs from other regions.
Sincerely,
Agent Xiong
May 27, 2008 | Televison & Video
Multi region phillips dvd player
Is this a Multi-region Player ?
Some Players are region Set to play Only the region they, are intended For. i.e Region 1 = NTSC( USA ) Region 2 = (PAL ) UK. Region 6 = ( ASIA ) And so on.
If you need a multi-region hack for your player, Post here.
I do charge a Small fee for This service.
Mike @ compurepair.
Feb 29, 2008 | Philips DVP3140
Help
HI,
it depends on whether the drive is multi-region ?
Some drives are region Set, i.e Region 1 ( NTSC-USA )
Region 2 ( UK PAL )
Most Players Are Region Set, To the country they are purchased in, you can sometimes set the player to become, multi-region, via various buttons on the remote or by the front panel.
I offer a service to unlock 99% of DVD Players, to play all or many regions.
We do have a charge for this Service.
Many Thanks mike @ Compurepair.
Feb 27, 2008 | Televison & Video
Televison & Video Logo
117 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
