Question about Cameras
Attention Fixya site I have a Canon Camcorder 750i Unit does not display in record mode either with screen closed for eye piece vision or screen vision fully open. This applies to either when record or pause are envoked. In a playback mode displays show a blue screen for an unrecorded area of a tape and change to a dark grey screen when it reaches a recorded section same as what was displayed shows whilst recording. Pre-recorded tapes when camcorder did not have the problem can be played back with no visual or audio problems. Please advise
  • 10,594 Answers
Symptoms in your Canon camera shows problem with CCD Image Sensor. Canon website has advisory for this issue. Please click above link and see it. I couldn't find your model for Free of Cost repair list but you can ask Canon about your camera. Hope this info will help you.
Posted on Aug 17, 2008
Rca540 camcorder will not show tape in eye pc unit runs but no picture in view finder
Is there a eletrical board that controls the opening & closing of the lens in front of the camcorder?
Aug 29, 2012 | RCA Pro Edit Camcorder Model Cc540
The screen and eye piece does not show pic while recording the microphone does work only shows display
This is usually caused by a defective CCD image sensor and can be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Jan 28, 2011 | Canon ZR90 Mini DV Digital Camcorder
My canon zr85 mini dv camcorder the screen is black when on record even if the side screen is close the eye unit is also black.
It is known problem of ccd imager chip failure in Canon ZR85 camera and ccd imager chip will be replaced to fix the issue.
Local camera repair shop will help you to replace ccd imager chip because solder work is involve.
Thanks.
Jul 21, 2010 | Canon ZR85 Mini DV Digital Camcorder
Viewfinder and LCD screen only show black and record black
If camcorder shows old recorded tapes picture with correct colors in LCD but does not show live view in camera mode to record new movie then its ccd imager chip failure.
And if camcoder shows live view and old recorded tapes in its eye piece view finder but does not show any thing in LCD the its problem of broekn/ cracked flexible wire between lcd board and main board of camcorder.
Let me know your finding with bit detail to provide you solution/ helpful info.
Nov 18, 2009 | Sony Handycam DCR-HC30 Mini DV Digital...
Blank screen when recording
In some cases when recording on a camer the display is run through the eye piece on some models there are switches or settings in your menu .. you can try that
Mar 24, 2009 | Canon Elura 60 Mini DV Digital Camcorder
Camera mode video not working
This could be as simple as the iris stuck closed or more expensive (ccd defective). Without taking the camera apart, it will be difficult to say with any confidence. Have you looked around to see what a repair estimate will cost? Perhaps you can get a detailed estimate from a local shop. We may be able to walk you through the repair?
Dan
Jun 12, 2008 | Sony Handycam DCR-TR7000 Digital Camcorder
Format a cd
First some explanations:
The Canon DC210 will only take 'minus' format DVDs (DVD-R, DVD-R DL and DVD-RW). Only the DVD-RW must be formatted (initialised) before use. During initialisation you'' be asked whether you want to initialise the disc in VIDO mode or in VR mode.
VIDEO mode: Once finalised discs recorded in VIDEO mode can be played back in most common DVD players, offering the best compatibility. However, recordings cannot be edited (deleted, rearranged etc) on the camcorder.
VR mode: You can easily edit the recordings on the camcorder. However, discs recorded in VR mode can only be played back with DVD players that are compatible with DVD-RW discs in VR mode.
My preference is Video mode - I can then play the disc on a DVD player and edit it on a PC.
Now, to initialise a DVD-RW
1. Press the 'FUNC.' key
2. Use the joystick to select 'MENU' - it's in the bottom left corner of the screen
3. Use the joystick to select 'DISC OPERATIONS'
4. Use the joystick to select 'DISC INITIALIZE'
5. Use the joystick to select either 'VIDEO' or 'VR' mode
6. Use the joystick to select 'YES' to confirm your choice
7. Use the joystick to select 'YES' to start initialising the disc
Close the menu only after the screen display returns to the 'DISC OPERATIONS' menu.
Don't forget to rate this solution once you've tried it !
May 11, 2008 | Canon DC210 DVD Camcorder
Cannon 750i mini digital camcorder
I am unable to record a video or take a picture with my MV750i Mini DV. I allways get a black screen.
Could I have any help?
Joaquim
Apr 15, 2008 | Canon MV750i Mini DV Digital Camcorder
Sony handycam camcorder lcd screen white and no displays
For the "all white screen" in daylight problem, check to make sure the "Nightshot Plus" slider switch is set on "off."
Jan 05, 2008 | Video Cameras
Camcorder recording problem
if 600 sgd is labor only - around 400 usd - you might consider cost of trading up to a newer model ( check ebay for second camera , while you wait for . . . warranty repairs ) ;
Aug 23, 2007 | Canon DC20 DVD Camcorder
Cameras Logo
83 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
