Question about Nokia 6255i
How to use bluetooth
How to send all phone book contacts via bluetooth in a nokia 6255 mobile cdma phone?
My bluetooth cant turn off
how do i fiks this
Posted on Sep 29, 2008
SOURCE:
No contacts in address book after pairing nokia C5 with Parrot CK3100. I find that my contacts are not available on the handsfree. I have used 2 other phones, with this same device, without a problem.
Your Parrot may need updating to work properly with a phone as new as the C5. but you can try the following,
To send a contact
* From the phone press MENU button and go to CONTACTS
* Select the contact you want to send and chose OPTIONS / SEND BUSINESS CARD / VIA BLUETOOTH / MORE DEVICES
* The phone will search for the available devices
* From the list select the Parrot Product
To send several contacts:
* Select the contact you want to send and choose OPTIONS / MARK/UNMARK / MARK
* Repeat procedure for several contacts
* Open the OPTIONS menu and chose SEND BUSINESS CARD / VIA BLUETOOTH / MORE DEVICES
Oct 01, 2011 | Parrot Hands-Free Car Kit with LCD Display...
How do i send my lg 990 phonebook to a parrot hands free kit
No one idea of the kit.
First, you will have to disconnect (and not delete) the pairing between the kit and the phone (on the kit settings -> paired device and then select and disconnect).
You go to the phone, you select the contact -> bluetooth option send via bluetooth. (if the phone can sending the whole phone book, you have mark or send whole phonebook).
You can send either one by one or the whole phone book. (I'am not sure if the whole phonebook are possible).
But i do not remember also if this phone has an auto synchro of the phone book, unfortunately with more than 1000 mobiles bluetooth difficult to remember.
Mar 12, 2010 | LG KU990 Viewty
I have a Nokia 6120 mobile that is connected to a parrot 3200ls car kit .When I turn to phone book nothing apears .I beleive it should sync the phonebook but it turns off the connection when I try
Try this from Parrot.com, cheers Dan
Performing object push process:
** On the Carkit go to Settings / Contacts Management / Receive Contacts
* For one contact sending:
* On the phone go to MENU / CONTACTS
* Select a contact to send by pressing OPTIONS / SEND BUSINESS CARD / VIA BLUETOOTH
* Select the 3200LS from the list, that will start the file transfer process
* To send all contacts:
* Select OPTIONS / MARK/UNMARK / MARK ALL / OPTIONS / SEND BUSINESS CARD / VIA BLUETOOTH
Nov 19, 2009 | Parrot 3200 Ls Color Handsfree Bluetooth...
Phone Book Transfer Nokia N70 - Blackberry 9000
Syncronization! The Nokia phone will not just easily transfer or sync the contacts to your Black Berry because they are running on 2 different softwares.
In order for you to transfer all the contacts to your Black Berry is through synchronization
The Nokia N70 came with a CD called the Nokia PC Suite. And Black Berry should have a sync software.
What are the things you need:
1. Computer
2. Nokia N70
3. Black Berry phone
4. Nokia PC Suite CD
5. Black Berry sync software
How:
1. Install the Nokia PC suite to the computer.
2. Connect the Nokia N70 to the computer.
3. Export all the Contacts from Nokia N70 to your computer (refer to the manual)
4. Once the contacts are saved in your computer, disconnect the Nokia and connect your Black Berry.
5. Run the sync software of Black Berry and import the Contacts that are saved in the computer going to your Black Berry (refer to the manual of Black berry).
This is hiow to transfer the contacts from one phone to another.
I would also suggest to contact Nokia so that you will have a clearer idea on how to do it.
May 23, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
I have nokia 6255 cdma from reliance set
no u cant..ur mobile is non sim based,,u can take new mobile n transfer to nonsim to sim
Jan 09, 2009 | Panasonic VS6 Cellular Phone
Contact transfer from cdma to gsm mobile phone
You can go into a Sprint Service Center and ask them to use their Cellebrite machine to transfer contacts from CDMA to GSM. If it's a PDA you can always sync your contacts to your computer. You can always Bluetooth contacts from one device to another (LG has its famous "Send all Contacts") as long as both devices have Bluetooth. Quickest and easiest route would be Cellebrite at a Service Center.
Dec 17, 2008 | Nokia 6233 Cellular Phone
Contact transfer from gsm to cdma mobile phone
CDMA phones do not use SIM cards but depending on the phone, most of them will have bluetooth. If not, however, depending on the phone, you can try getting the PC Sync software for the device, and synchronize the contacts to the computer, usually to Microsoft Outlook.
Most CDMA carriers have applications you can download to the phone and computer that will actually let you sync the contacts from outlook to the phone wirelessly (VZW has Wireless Sync which is free www.wirelesssync.vzw.com), or you can try using the PC Sync software for that specific phone to sync back.. If its a Motorola phone, the software costs money (about $39) but other manufacturers provide it for free from their website.
The following links I know work for most GSM phones. Not sure about CDMA versions, but should.
Nokia PC Suite www.tinyurl.com/Y5xxl5
Samsung PC Suite www.tinyurl.com/ywe285
Sony Ericsson PC Suite www.tinyurl.com/yvcdqw
LG ?
Apr 20, 2008 | Nokia 6233 Cellular Phone
Nokia 6255i mini screen light won't go off
how can i get the keypad ights on nolia 6255
Feb 19, 2008 | Nokia 6255i
Nokia 6255i Logo
51 people viewed this question
Top Nokia Cell Phones Experts
jonathan mariano
jonathan mariano
Ekse
