Question about Hunter 23852 Classic Original Ceiling Fan
Leaking oil How do I stop a Hunter ceiling fan from leaking oil?
  • Jeff Meyer May 11, 2010
    Did you get your Hunter Original ceiling fan repaired or is it still leaking oil? To help you, please double check the model number (on the name plate on the side of the motor housing.)
    Thanks.
  • 423 Answers
SOURCE: Check/add oil to a hunter ceiling fan
If you are asking for instructions on checking and possibly adding oil to a Hunter Original fan. Here are instructions:
Check oil level immediately after filling the reservoir. To check oil, bend an ordinary pipe cleaner into a 1/2" long hook and dip it into the oil reservoir.
If oil touches the end of the pipe cleaner, the fan has ample oil. If it does not touch, add SAE 10 non-detergent oil slowly until it touches the pipe cleaner.
-Hunter Original fans rarely/ never need oil unless they were relocated or tipped. ...Or if the fan was improperly installed.
-Hunter sells an oil refill / oil level check kit with good instructions. They also sell a relocation kit that includes the same kit plus all mounting hardware needed.
Good Luck!
Posted on May 05, 2009
  • 5 Answers
SOURCE: Hunter ceiling fan remote 85095-01 stopped working
if the battery's are good then you broke it and you have to order a new one which you can do by calling the place that you got the fan from tell them what kind of fan you have and let them know that you nead a new remote and they will be able to help you do that.
Posted on Aug 13, 2009
SOURCE: Hunter Douglas Ceiling Fan Does Not Work
have hunter douglas fan glass globe broke cant find repalcemants i have all the serial no do you no wher i can go to find 91/2 globe
Posted on Aug 20, 2009
  • 3 Answers
SOURCE: Hunter ceiling fan remote problem
You will most likely need to replace the receiver with a new one from hunter. The receiver is actually a complete controller and contains the receiver, relays (which you hear clicking) and starting condensors(large capacitors which hold a charge that is "dumped" over the windings to get the motor to start from a dead stop). These appear to be pretty tightly assembled unless you have a desire to start replacing parts "off the board."
Posted on Sep 07, 2009
  • 34 Answers
SOURCE: HUNTER ceiling fan remote works with fan but not light
Unfortunately, you either have a faulty reciever or remote. A replacement will cost $30-$40 at homedepot2.gif. And it doesn't matter which is faulty because you can't purchase them seperately anyhow.
Posted on Sep 10, 2009
Can you oil older ceiling fan
You cannot oil the unit. The bearings are sealed.
Aug 29, 2014 | Hunter Dryers
Hunter fan 27227 remote stopped working
How i fixed my Hunter #28096 remote controlled ceiling fan, started not controlling the light, then later the fan quit also. Start by testing the remote buttons, see this post... Cp9430r Fixya
Jun 22, 2014 | Hunter Ceiling Fan Light Remote Control
Hunter origional leaking oil serial # 336023
Call Hunter to get RGA # to return for repair or find the nearest service center www.hunterfans.com 1-800-715-0393
Jun 14, 2014 | Hunter (25417) Ceiling Fan
A customer of mine has a very nice Hunter original ceiling fan that she never oiled and now the fan just hums and wont spin. Is it possible to repair after no oil damage is done?
Put some oil in and turn blades by hand to lubricate the bearings. If the motor is frozen, then you would have to take it to a service center or send back to Hunter for repair.
Apr 17, 2013 | Hunter 23852 Classic Original Ceiling Fan
Water in fan, now has stopped working. Smelled burnt wiring
You would have to contact Hunter & they will advise you as to where you can take it or where you must send it. 1-888-830-1326
Mar 16, 2013 | Hunter 23852 Classic Original Ceiling Fan
Where can you buy 10w non detergent oil for use in a hunter original ceiling fan
I found Kendall 10w non-detergent oil on Amazon. Unfortunately you have to buy a case of 12 quarts for $50.
Jul 22, 2011 | Hunter (25417) Ceiling Fan
How do I oil my Hunter fan?
You don't. There's no place to oil ANY ceiling fan, not just the Hunter line. All ceiling fans use sealed ball bearings in the motors. They are lubricated for life. If you're experiencing a squealing noise, it would be best to take it down, pack if up and take it back where you bought it. No ceiling fan should squeal, let alone one as expensive as a Hunter.
Apr 22, 2011 | Hunter Dryers
I purchased the hunter outdoor fan about 3 years ago. All three of them are leaking oil. What is the problem?
Might be overfilled on oil. Oil should be only 1/2 " from the top of the reservoir. also check that the reservoir tank is on tight. Note (Left land treads).
Jun 26, 2010 | Hunter 23852 Classic Original Ceiling Fan
New Hunter fans installed, they operate for a period of time and then shutdown. Some time later they can be switched on from the power source. Is there an internally installed thermal device which shuts...
Howdy,
Assuming these ceiling fans are infact the 23827 Hunter Original, did you put the bottle of oil which came with the fan in them? The Hunter original requires this bottle of oil for lubrication. If you had them installed, the installer may have not put the oil in.
with the motor/s off, spin the blades. Do they spin for a long time, or do they come to a stop quickly? If these fans were just installed, the biggest likelyhood is that the bearings are seizing from lack of lubrication.
The oil hole may be on the switch housing, as in this .pdf http://www.hunterfan.com/uploadedFiles/Support/Owner_Manuals/41556.pdf
Or it may be on top of the fan, as in this .pdf http://www.homedepot.com/catalog/pdfimages/52/527f2153-5314-45aa-8cd1-310b94adc671.pdf
Jun 09, 2010 | Hunter 23827 Classic Original White 42"...
I have a hunter ceiling fan (model #20537) which makes noise at low speed. Sounds like ball bearings need oil. Any suggestions?
Check with stores that sold it and see if they will warranty replacement. I think there is a lifetime warranty, thats why you pay the big bucks for the Hunter name.
Aug 02, 2009 | Hunter 20537 / 20538 The Vista Iron...
Hunter 23852 Classic Original Ceiling Fan Logo
364 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
