Question about Philips 62PL9774 62 in. HDTV LCD Television
Picture darker around the edges
Lamp is relatively new. Over time, unit has developed a dark ring towards the outer edge of the picture, all the way around. Another TV repair man told me that there's a mirror inside that probably has dust that's built up on it. I took the lower back cover off and cleaned the lenses that I could see, but he says this mirror is in the upper back section. I've taken all the screws out of the upper back cover, but it's still seems attached by something. I cannot get it off and am afraid of breaking something if I force it. Do I need to take the front cover off to get the back cover off? If so, I'm not sure how. I don't see any screws accessible to take it off. Any help would be greatly appreciated.
  • 1 more comment
  • philhoff Aug 17, 2008
    The dark spot suggestion doesn't make sense in my case because there isn't just a dark spot on the image, there's an even kind of ring around the edges, more into the corners. It's not completely dark, the brightness just fades towards the edges.
  • cmbecker Jan 28, 2009
    I have the exact problem with my tv. It is the exact model.
  • wcsliger Nov 28, 2013
    I know this is an old post but I fixed this on this same model. There is a lense next to the DLP chip that has a film glued to it. The glue on the film is turning brown so you will need to remove it and you picture will be bright again. You will need to refocus your tv when you are done.
    Problem Solver:
  • 10 Answers
It seems to me that with "general" dimming to the most distal areas of the screen, we are dealing with overall bulb failure/intensity, a failure or lack of light receiptivity at the distal areas of the screen due to age or use, or some sort of uniform film build-up somewhere that is mechanically restricting the bulb's intensity. does this sound reasonable?
Posted on Nov 26, 2009
    Genius:
  • 1,847 Answers
This may also be a spot on the bulb itself. Projection TVs use a high powered bulb to project the image. If something got stuck to the bulb, it can cause a dark spot. I would have a qualified technician look at it,
Posted on Aug 17, 2008
  • 1,800 Answers
Okay okay sir
every thing that u ve done till naow is ok
follow me
first chek the connections
if all the connections are cheked try
toend me ur model number its locate here and i will give u the full help of ur product but dont rate my help yet till i tell u that am finished okay??d4d39a7.jpg
IH252 inc monitor bottom half darker than top.
Thin screen LCD monitor brightness controls operate several fluorescent lamps called "backlights" that are positioned behind the LCD display. Typically, they're located around the edges of the screen - sometimes just at the top and bottom, and other times at the left and right edges and others still at all 4 edges.
Fluorescent "backlight" lamp, inverter & connection wiring.
The lamps are miniature versions of those sold in stores. They require a support circuitry called an inverter that convert & boosts the level of DC to AC voltage performing the functions of a ballast in a traditional fluorescent fixture.
The reason a part of your screen remains dark is because one or more of the components in the picture above has failed and will not allow the lamp to shine. Replacement lamps and inverters aren't expensive - but requires patience and the ability to disassemble / assemble the monitor (which is usually harder to do than it appears) and solder. They are available various lengths and color temperatures (you must get a lamp that is identical or it will be noticed). If this is a new monitor - you ought to return it for replacement. If used, consider the cost of purchasing a replacement (new or used) vs. repair.
I hope this helps & good luck!
Jul 29, 2013 | Computers & Internet
HDLP61W151 has dark spot in screen
If it happened gradually I would suspect the lamp--a photo posted here might help.
The other possible cause in a Optical light engine which might be very expensive to replace in this brand.
Typical light engine:
Dec 16, 2012 | Televison & Video
I have a Philips Cineos 55" 55pl9773/17 that has an issue with the picture where it is dark around the border or edges of the screen. Basically, to put it differently, the outside of the screen is...
open up the back of the tv and look to see if any of the capacitors on the power supply or video board are swollen or oozing out stuff....if so replace them and should work
May 04, 2011 | Televison & Video
Picture has become progressively dark 27'' TV JVC AV-27320
disgaussing will not help this problem..i am scared your picture tube problem or try to change the crt socket first it is not cost much
Jul 01, 2009 | Televison & Video
Dark black spots around the edges of LCD TV
this issue is tape from the edge of the panel falling onto the screen.You will have to remove the cabinet and the panel from the bezel(front cabinet).remove the screws from the lcd outer edge. Take of the tape.Be very carfull of the ribbon cable that goes to the lcd controller and to the lcd screen itself. They break easy. If you do , its over. you will need a new panel. to much money and work. best to leave it alone.I have fixed it several times for people with warrentys. It is just anoying but will not hurt your tv.
Aug 28, 2008 | Memorex MLT3221 32 in. LCD TV
Image reduced by dark edges
An adapter tube has to flare out at the end or it will cut the corners off at the wide angle setting. Telephoto should be ok though.
Dec 04, 2007 | Canon PowerShot A620 Digital Camera
Color is not good around outer edges of picture
When the colors are off around the edges on a regular picture tube TV, it usually means that the degaussing thermistor's solder joints have cracked loose. Another possible cause is that a strong magnet, such as in a stereo speaker, was brought very close to the picture tube and has magnetized the tube. Resoldering the solder joints on the degaussing thermistor and demagnetizing the picture tube should put the color back to normal.
Aug 17, 2007 | Toshiba 32AF45 32" TV
Philips 62PL9774 62 in. HDTV LCD Television Logo
218 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
