Question about Philips GoGear SA3125/37 MP3 Player
Ricco 4gb mp3 mp4 player
My Ricco 4gb mp3 mp4 player will not connect to my pc running windows xp. The computer keeps telling me that the device has malfunctioned and it cannot recognise it. What should I do?
Thanks
  • 8,596 Answers
Here is the link to all Ricco Mp3 players.  You will have to find your specific model number on the list. There is an Mp3 Format tool that came with most Ricco Mp3 players - if you perform this formatting, then you should be good to go.  One model has a firmware upgrade - if you have that model, perform the firmware upgrade. http://www.netac.com/support/download.htm
-Tha Mp3 Doctor
Posted on Sep 14, 2008
SOURCE:
Hi, my pc don't read the mp34 audio player =( help!!!
Why is my mp3 and mp4 player not being detected by my computer when I connect it?
This may be caused by one of the following:
1. Minimum system requirements were not met.
2. Corrupted drivers.
3. Computer restrictions.
4. Power issue.
To resolve this issue, try the following solutions:
SOLUTION 1 - For brand new player or first time connecting to this computer.
For Windows XP users: verify the following operating system requirements are met.
- Windows XP SP2 or higher
- Windows Media Player 10 or higher
Download and install the latest Windows Media Player if it's not installed.
For Windows Vista users: If the player is seen in My Computer when using MTP mode, but not showing in Windows Media Player.
- Download the hotfix from http://support.microsoft.com/kb/939211.
- Run the hotfix.
For MAC users, see mp3 and mp4 player not recognized by a MAC OS
NOTE: If you are trying to connect to a Computer at work that is part of a network, there may be user right restrictions that are set to disable access to new hardware or stop any program installations. You may need to check with your IT administrator to see if this is causing the problem.
SOLUTION 2 - Refresh the driver
STEP 1 - Connect the mp3 and mp4 player to the PC
The screen on your player should turn on, show 'Connected' and indicate the battery charging or full.
- If the player does not turn on try other USB ports or on another computer if one is readily available. Ensure you are connecting directly to the computer USB port and not to a USB hub.
- If there is nothing showing on the screen and the player does show up in as a storage device in an explorer window, then the screen is just not working.
If you receive the error "USB Device Not Recognized" on the computer, the player is most likely failed. Additional troubleshooting is unlikely to correct the problem.
STEP 2 - Check under Device Manager
1. Right-click My Computer, and select Manage.
2. Click Device Manager on the left pane.
NOTE: mp3 and mp4 Players can connect to your computer in MSC or MTP mode. Exceptions are mp3 and mp4 Connect and Sansa Express which only use MTP mode. MTP mode is the recommended and default method for mp3 and mp4 Players when used with Windows OS.
The mp3 and mp4 player will show up on Device Manager's right pane as:
1. USB Mass Storage device (if the player is set to MSC)
2. Portable Device (if the player is set to MTP mode)
If there is a yellow exclamation point (!) or question mark (?) beside the device, try to refresh the drivers.
STEP 3 - Refresh the drivers
1. Right-click the entry with the error mark, select Uninstall.
2. On the top menu, click Action then select Scan for hardware changes.
NOTE: If a device with yellow exclamation point (!) continually appears and disappears, then the player is most likely failed. Additional troubleshooting is unlikely to correct the problem.
May 05, 2011 | Digital Audio NAP256 MP3 Player
I have mitone mp4 player (MITMP26) 4 GB . I have a problem. USB device don't see my computer. Windows 7 64 bit. Please help me.
Hi, player not recognized by the computer
4. Power issue.
- Run the hotfix.
For MAC users, see Sansa player not recognized by a MAC OS
STEP 1 - Connect the Sansa player to the PC
NOTE: Sansa MP3 Players can connect to your computer in MSC or MTP mode. Exceptions are mitone mp4 player Connect and mitone mp4 player Express which only use MTP mode. MTP mode is the recommended and default method for mitone mp4 player Players when used with Windows OS.
The mitone mp4 player player will show up on Device Manager's right pane as:
SOLUTION 3 - Connect using MSC mode
Connecting in MSC mode will help determine if there is a problem with MTP mode or with the Auto Detect mode feature of the player. You can use Forced MSC mode or switch the player settings to MSC.
If the player is detected in MSC mode but not when set to MTP mode, try to update or reinstall the mitone mp4 player firmware
NOTE: mitone mp4 player Express and mitone mp4 player Connect do not have MSC mode. For mitone mp4 player Connect you can try reinstalling the firmware using the Connect Recovery Mode.
Additional troubleshooting notes:
If you have replaced the mitone mp4 player Player and you still have problems getting it to recognize in the computer, then you may need to try some additional troubleshooting.
- Try connecting on another computer.
- Try using a different USB cable
- Try connecting to the back USB ports which may supply better power.
- If only MTP mode is not working, try reinstalling Windows Media Player
For Windows XP try also download and install the MTP Porting Kit.
Hope that helped And please don't forget to rate me..
Have a nice day....
Feb 19, 2011 | Audio Players & Recorders
My Sweex Vidi MP4 Player 4GB has stopped working.\r\nIt won't turn on and when connected to PC the PC says unrecognised hardware.
My Sweex Vidi MP4 Player blu 4GB has stopped
My Sweex Vidi MP4 Player 4GB has stopped working. won't turn on and when connected to PC the PC says nothing
Oct 23, 2010 | Digital Blue Sweex Essentials MP014 MP3...
I was given the MW3836 GPX MP3 as a gift. I have never work with MP3's. I want to record some music in it and then listen to them. How can I do this? Thank you. I have Win XP on my pc.
Please find details to connect your MP3/MP4 player to your computer:
In order tp download songs to the mp3 player firstly,you should make sure that which kind of format does your mp3 player supports, like:format MP3, WMA, WAV, ASF, ACT.If you are not so sure about it's format,please refer to the manual of your mp3 player.
Secondly,download the right format songs from internet( many sites have the capability to wownload free music) and save them. If not sure go to Google, and look for free songs.
Once done:
1.Get the songs you want onto a computer
2. Plug your Player into the computer it should have come with a cable when you bought it
3. (On Windows) Go to My computer from the start menu
4.Select your Player from the list of drives that you should see C: D: ect... (if you dont see yours specfically click on all of them untill you find one that looks like it should be
5. Once youve found it, copy or cut your songs or videos onto your player For an MP4 player your songs must be MP3 and videos in MP4 format
6. unplug your device and turn it on, that should have worked
Download all the music to your local PC, connect your mp4 player to your PC with USB cable 'make sure that all necessary drivers are installed', If it's connected > synchronise it with windows media player then drag and drop the music in the device panel.
Also some information on the process can be found by going to:
http://www.ehow.com/how_4926896_download-songs-mp-digital-players.html
This solution has worked with all of people seeking help in connecting their MP3 to their computer..
Apr 12, 2010 | GPX MW3836 MP3 Player
Downloading music to my mp4 player
first connect your mp4 to your laptop with a usb cable. once it shows up on the laptop copy or cut and paste your music to the root folder of your mp4 or the music folder. after that is done disconect your mp4 from your laptop.
restart you mp4 and your music should now show up. enjoy your music
Jun 06, 2009 | Digital Mind Corporation iQ Sound...
The mp4 player keeps crashing my computer
If your PC is running Windows Vista, don't even think about conencting it until you get the firmware upgrade for the device.
Triple Reset for GoGear:
Disconnect the Go Gear from computer. Press the reset pinhole until the player turns off. Hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard. If this pop-up does not appear, reset the player again WHILE connected to the computer. Open the Philips Device Manager, and go to Repair Tab. Reset the player one more time while connected to computer. Follow the repair instructions.
After repair is complete, upgrade the firmware for this player.
Will erase all the songs, but you should be good to go again.
-Tha Mp3 Doctor
Jun 08, 2008 | Philips SA3125\02 MP3 Player
Philips SA6045 Mp4 player- virus?
Make sure you back up all songs on the GoGear before attempting this solution.
1) Back up all files on the GoGear
2) Open up Philips Device Manager (Start --> All Programs --> Philips)
3) Click on the Repair Tab, and look for a msg that says connect the player while holding the volume + button
4) Disconnect the GoGear from the computer and turn the GoGear off - hold in the volume + button and continue to hold it as you reconnect the GoGear to the computer; after holding the volume + button for up to 20 or 30 seconds, a window will open up saying that your device is being repaired (now you can let go of the volume + button); after the repair is successfully complete, your GoGear will be good as new
Now you can do the firmware upgrade that will prevent this problem from occuring in the future. Open up Philips Device Manager and click the Update tab. This problem was caused because most GoGear's were designed for Windows XP with Media Player 10 (which is no longer the latest standard).
-Tha Mp3 Doctor
Mar 15, 2008 | Philips SA3125\02 MP3 Player
Mp4 player
This is the worst mp3 player ever invented - i have to tell you this up front. There is no driver, the company does not support the product anymore - I would return it now while you still can.
Either the device is bad, the pc port is bad, or the software is faulty. Try connecting to different usb port, then a usb port on a different pc with a compatible os. If still not recognized, then there is physical damage to player.
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Dec 26, 2007 | iLO (2 GB) MP3 Player
I cant get my mp4 player to download music
Dec 25, 2007 | iLO (2 GB) MP3 Player
Philips GoGear SA3125/37 MP3 Player Logo
136 people viewed this question
Top Philips Audio Players & Recorders Experts
 Grubhead
Grubhead
Ekse
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
