If this is a gas dryer, the rattling noise you hear is usually an indication of the gas valve coils failing on the burner assembly. Your dryer will normally have two of them. One is the main coil, and the other is a pilot position coil. It is recommended that you replace both of them at the same time (usually sold as a set). Searspartsdirect.com carries your parts. Just type in your model number and look under the "Burner Assembly" heading. For comparative shopping, repairclinic.com may also carry your parts. Sometimes at a cheaper price. If this is not a gas dryer, please post back with your model number, so I can assist you better. I hope this helps answer you questions.
SOURCE: Kenmore 70 Series Dryer Model# 110.64742400
check the thermal fuse if it is blown also change the high limit thermal cut-off fuse www.repairclinic.com shows your parts. go there and enter model number. Also check the heat element. to get into it remove the lint filter and the two screws you'll see there then pry the top up at the front corners. And through the back you should find the heat element and blower housing and thermal fuse and high limit fuse and cycling thermostat.
SOURCE: kenmore series 80 electric dryer not drying
Most dryer heat related problems are attributed to poor ventilation. A dryer needs proper air flow in order to dry efficiently. An easy test is to remove the dryer exhaust hose and try drying a load as you normally would. If the air flow leaving the exhaust is forceful and warm, followed by the clothes drying normally, then the problem isn't the dryer. The problem is with the vent ducting. You will need to inspect for kinks or clogs in the hose from the point where it leaves the dryer, all the way to where it exits your home. If the ducting hasn't been cleaned in a while, now might be a good time to do so. Leaving a dryer in a clogged state will eventually cause it to overheat to the point of failure. Not to mention, this creates a fire hazard and a habitat for rodents. Mice love dryer lint.
If the air flow leaving the dryer is weak and cool, you may have an internal clog inside the dryer. Inspect the air blower assembly for clogs or obstructions and clean as necessary. Cleaning the lint screens on dryers isn't always enough. Some lint does get past the screen and can accumulate over time. Periodic inspection and cleaning is recommended. I check mine about every three months.
Another common problem comes from overloading. Placing too many items in the dryer does not allow items to tumble properly and retain moisture. Try smaller loads if this is the case.
If you still have questions, or require additional assistance, please let me know. I hope you find this information helpful.
PS Do not run a dryer with the exhaust hose removed on a long term basis. This will add unwanted heat and humidity to the air in your home and can cause mildew problems. Running it for the purpose of this test is not going to cause problems, however.
SOURCE: sears kenmore dryer 70 series will not dry clothes, unit does not
faulty heater element try replacing it at rear panel bottom left panel behind drum at rear cheap to mend yaself
SOURCE: my kenmore 70 series dryer will not heat upa nd
bad ignitor
or bad solonoids on your gas vale
check your lint filter
and exhaust outside to be clear of cloggs with good airflow while running
SOURCE: have a kenmore 70 series dryer. operates but
I am not a repair professional. I am a 78 year old man who has been making his own repairs for about 50 years. So the machine ID doesn't mean much to me. I came to fixya looking for a schematic for an really old AM/FM radio and just happened to see that more than 4,700 people were asking for help with a washer repair. I recently had a washer repair of my own and at that time I found an excellent video on youtube which showed me how to take my machine apart. This video (direct drive washer repair) made it possible for me to do my own repair. You probably don't have any idea of the wonderful help you can get from youtube videos. Your first stop should be at youtube. Just search for the help you need. You could search for "clothes dryer repair" or "clothes washer repair" or "dishwasher repair". If you are not able to view and/or download the videos, or after you've seen all you want to see, I suggest you go directly to www.applianceaid.com where they have very good step by step trouble shooting and repair information on washers, dryers. and dishwashers as well as other appliances. Another excellent site is www.acmehowto.com If you have a direct drive top load washer and need help taking it apart these youtube videos are wonderful help. I was so impressed with them that when I saw all these people needing help, I wanted to tell them about the videos. If you look at the back of your top load washer and the panel is solid (no small inspection plate to remove, which would indicate you have a v-belt drive) chances are you have a direct drive and this video (direct drive washer repair) is just what you need. After you've seen all the appropiate videos, or if you have a belt drive washer, you will probably still need help in determining what the trouble is and how to fix it. I suggest you go to www.applianceaid.com where they have very good trouble shooting and repair nformation on most washers and dryers, dishwashers and many other household appliances. I think you'll find what you need there. Another excellent site for DIY help is www.acmehowto.com Don't worry about the timer on a washer, they hardly ever go bad. I realize I haven't solved your problem for you, but I hope I have sent you where you can get help to solve the problem. Good luck with it.
clarify, this is my comment: I have the same problem with an 80 ser. dryer...
- Thanks DR. jsrock516 !! I t was making a rattling noise.
While drying my maytag 4000 series gets an F70 error code then stops and I cannot restart the dryer unless I turn it off and on again. Then it stops again. Please help me!!
