Question about Nokia 6630 Cellular Phone
6630 "Not Charging"
I m using 6630
One day , after connecting my charger i got this message flash on ny screen "Not Charging".
I tried with different chargers and diff Batteries , But the problem remains.
Apart for that my cell is workin 99.99% fine.
Kindly plz suggest the possible reason for this behaviour And Its Solution.
read other users solution too but didnt get the result
Thanks in Advance
At the moment i m charging my battery in 6600{my brothers cell}
and replacing it in my cell
  • wildtiger Aug 18, 2008
    I ma using Original BL-5c Battery only
My frind use corect batery that is Nokia BL-5c 3.7V made in hungary
Posted on Aug 17, 2008
SOURCE:
Power Problem
I have the matsunichi 9.7 my email has amessage saying connection problem no emails has come in for 2 days. What can i do to fix the problem
Mar 05, 2014 | Matsunichi Marquis Mp977 Marquispad 9.7"...
Sometimes when i charge my phone it gives me a message saying "charger not supported." then in two days when i try it it works. Is there a way i can fix this faster instead of waiting two days?
It is because of the difference in voltage between different chargers... Also you will be facing similar kind of issues when the charging IC in your phone has become faulty...
Try charging your phone with a different charger and if you are getting the same message again, then the IC might be faulty in your phone...
Or if you are able to charge properly with another charger, then it is definitely an issue with the charger, better buy a different charger...
Feb 22, 2011 | Nokia Cell Phones
I have a Nokia 6630 Second hand phone.Sometimes I have displayed 'Not Charging' when I am using my NOKIA Original Charger. but my charger is working properly.Is it a battery problem or Power IC problem
yes once check ur charger and all pins of that charger and check the phone pin at connnet of the charger if it not works u should change ur chrger or phone pins ok thinks and all the best and please
OR:
Please change Phone In The CHARGING JUMPUR
rate my answers too
Dec 28, 2010 | Nokia 6630 Cellular Phone
Charging not supported
Hi, Possible causes of the phone with message "charger not supported". are, Either the charger is not working properly again or the Charging port where the charger is being plugged to the phone to enable phone to charge is faulty.
You can use a different charger and see if the charger needs to be replaced.i guess that will do.
Have a nice day.
Sep 03, 2010 | Nokia 6300 Cellular Phone
Phone doesnt charge....
Hello ! pls use the right charger for it using a different charger can damage the charging IC of the phone .
The charger for LG could look the same but designed different also the bat can be damaged thats means it won't charge
Get a new Bat then try what have told u
good day .
Aug 31, 2009 | LG Secret ? KF750 Cellular Phone
Battery is not charging nokia
check batt model r it arthorised batt and check charger and batt model no
Jan 23, 2009 | Nokia 6630 Cellular Phone
NOKIA 6630 displays not charging when connect charger
hi dude,
>>> dont remove any thing from u r mobile, first confirm the problem where it is...
>>> first try to put the charge by using other charger... still u r getting same problem means change the charging unit
>>>good luck... thank u....
>>> dont forget to rating the solutions...
Feb 16, 2008 | Nokia 6630 Cellular Phone
Nokia 3250 charging problem
it sounds like a problem with the charging port (where you actually plug the charger into your phone). unfortunately, you may have to replace the phone, as switching batteries or chargers wont solve the problem.
Sep 24, 2007 | Nokia 1100
Nokia 6630 Cellular Phone Logo
182 people viewed this question
Top Nokia Cell Phones Experts
jonathan mariano
jonathan mariano
Ekse
Damen Wong
Damen Wong
