Question about EliteGroup K7S5A Pro Motherboard
Please Help!!!!!!!! I have a motherboard WinFast model 761GXK8MC-RS but I forgot how to put the power,reset,hdd, and usb wires back on the motherboard where they belong. Please if any body can help me thanks in advance.
  • Luis2924 Aug 17, 2008
    Thank you guys very much. U guys are life savers.
  • 1,114 Answers
Hi - You can download the manual from the link underlined in blue below:
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Posted on Aug 17, 2008
Thanks for the good feedback, it makes it all worthwhile!
Best regards,
Posted on Aug 18, 2008
  • 655 Answers
Hi, Luis
Click here for manual.
Download this manual. There is a detail diagram how to install your motherboard.
Please note the file format is PDF so you need Abrobat Reader to open and see this file.
If any problem or confusion, just ask me I will try to help.
Please post your feed back.
Thanks and Good Luck
The front of your computer is the Front Panel
The area of contact pins on the motherboard, that the Main wires from the Front Panel go to; is the Front Panel header.
What you are asking for is a Front Panel header pinout.
I do not have the exact Front Panel header pinout, for your motherboard.
Tell you what I do have though..........
Looking at the Front Panel header on the Ebay link, for the Winfast 760m02-GX-6LRS; the Front Panel header looks to be below the CMOS battery, and close to the Bottom edge of the motherboard.
(Motherboard installed in computer case)
Black rectangular strip of plastic, with contact pins sticking up.
Also looks to be a GENERAL set-up for all Winfast motherboards.
(COULD be wrong here)
This is what I am referencing off of,
Go to the third photo down. Here you see the Front Panel wires, connected to the Front Panel header; on the motherboard.
(Below round CMOS battery)
Note that the contact pin on the Bottom row, and all the way to the Right; is NOT being used.
(I'm using a 26 inch HDTV as my primary monitor, so it may be easier for me to see)
Now look at this Front Panel header pinout, for another Winfast motherboard,
(Scroll down a little)
PWRLED is for the Power On LED (Light)
PWRSW stands for Power On switch
HD-LED stands for the HarDDrive activity LED (Light)
RESET stands for a Reset switch, IF USED.
Note where it has a Positive ( + ) sign, next to the pin for the PWRLED.
This is the pin the + wire from the Power On LED connects to.
It is the SAME for every LED that connects to the Front Panel header.
Let's number the contact pins, to make the explanation easier;
Starting at the Left side, Top row; going towards the Right;
Pins 2, 4, 6 and 8. There is NO Pin 10.
Starting on the Left side, Bottom row; going towards the Right;
Pins 1, 3, 5, 7, and 9.
Pin 2 is for the Positive wire.
Pin 1 is for the Positive wire
If the LED's are dim, (PWRLED, and HDD LED), OR; the LED's do not light up, switch the wires around.
(Pin 9 is N/C.........Not Connected. This is probably a 5 Volt test point, that was used by the factory)
There is a method you can use though, and find out what the individual contact pins are, in the Front Panel header;
Use an LED with two wires
Computer (Power Supply) plugged into power, go along the top row, and touch two pins at a time, with the two wires of the LED.
Example; Pins 2 and 4, as shown in the pinout.
Did the Power Supply come on?
Go to the next two pins. Try again.
When the Power Supply comes on, you naturally know that is the two contact pins; for the Power On switch.
DO NOT touch them again. In fact connect the Power On switch wires.
Power Supply on, computer running;
Now go back along again;
1) LED light blinks?
You have the HarDDrive activity LED, contact pins.
2) LED light stays on?
You have the Power On LED, contact pins.
3) Computer restarts?
Those are the Reset switch, contact pins.
4) Nothing happens?
May be contact pins for a speaker, or contact pins that are not used.
(Speaker is for hearing BIOS Beep Codes.
You have a Piezo buzzer, to the Left of the CMOS battery; for that)
Post back in a Comment, as to the results.
If possible, I would like to ask upon you; to post the Front Panel header pinout; when you find what it is.
That way when a person in the future also has this same problem; the solution will be posted on the internet, for them to find.
For additional questions please post in a Comment.
Apr 30, 2013 | Leadtek Winfast 760m02-gx-6lrs Socket 754...
hai, i am using winfast motherboard pc and i was remove my cpu all wire so please tell me about how to connect the power switch wire and restart wire
Oct 28, 2012 | Foxconn WinFast K7S741MG Motherboard for...
Case wire two mother board
Here is your front Audio guide:
Here is your USB guide:
And here is your front Panel guide:
Let me know how that works out. The front panel guide is rotated 180 degrees however.
May 02, 2009 | Foxconn 661FX7MF-S Motherboard
Wiring front panel
if you go to this website
You can select motherboards --> socket 754 --> your make of motherboard and then download the manual which will tell you what the pins are for and where abouts they are on the motherboard.
Apr 13, 2009 | Foxconn 760GXK8MB-RS Motherboard
Manual for winfast 768gxk8mc
Have you tried going to *********** board's website? I find that most offer a on-line manual for their products.
Dec 14, 2008 | Computers & Internet
Connection Process
on your atx power supply,there is a 20 pin head wich tou have to put on a 20 pin socket on the motherboard.about the usb and other wiring,study your motherboard carefully and you will see where you will put the usb,power switch,reset switch,hdd led and power led
Nov 11, 2008 | Mercury P4VM800M7 Motherboard
You can go to this link and download the audio driver for *********** board
Hope that helps...........
Jul 17, 2008 | Foxconn 761GXK8MC-RS Motherboard
Power switch
You could try searching for the manual for the motherboard, I have the same problem every time I disconnect a motherboard.
Sometimes it is printed on the motherboard in dead small writing which wire goes where.
Also usually motherboard manufacturers follow the "unofficial" standard io connectors.
PLED = Power LED/Message LED
HDD = Hard Drive LED
RST = Reset Switch
PSW = Power Switch
SPK = Speaker
NC = Not connected (sometimes not even there)
Note quite often the Reset switch is the reverse of everything else! (i.e. on most if the + is on the right the + is on the left for the Reset
The USB ones usually always follow the following standard
And usually one of the NC pins is no pin as some USB cables have that pin blanked out to ensure you connect them the right way. Note also with USB you start with the VCC then you go straight to negative data, then positive, then ground (again the - and + data bits, like the reset are in reverse of normal reading - the are right to left, not left to right!)
Finally if your not sure which cable is + and which is - the - ones are normally either black or white (most of them are white, except the speaker ones which are black - I presume that goes back to the colour scheme of red and black for positive and negative in audio equipment) and the + ones are normally some colour.
Dec 11, 2007 | Abit nForce2 NF7-S2 Motherboard
Trying to put in a new Motherboard
Here is the link to the manual:
Here are the details:
This is located at #7 in the manual which if the CPU is Top-right, then this panel is in the bottom-left. Plug the three little plug on PW RBTN#, where the two wires in the plug lign up on the pins. Put the HDD LED and PLED LED power in the locations above. They aren't working, turn them around, it's pretty harmless.
Enjoy. Rate this a FixYa! please.
Dec 01, 2007 | Foxconn 6150BK8MC-KRSH Motherboard
EliteGroup K7S5A Pro Motherboard Logo
457 people viewed this question
Top EliteGroup Computers & Internet Experts
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
