Question about Sub-Zero 601R
Condensation and water in refrigerator
I keep getting lots of condensation -- wet cartons, bottles, jars and shelves -- in my Sub-Zero 36" refrigerator. I've had freon recharged numerous times and a freon leak "spray" sprayed in. The condensation/water is so bad that I get black spots (mold) on the items in the refrigerator. Please help.
    An expert whose answer gotĀ voted for 100 times.
  • 56 Answers
It sounds like you need someone who knows what they are doing out to your house. A tech should find and repair or replace the component that leaks. A second trip should be not be needed. The fact you have mold tells me they have never properly did your repair. Mold will grow only when the cavity gets above 40 degrees for a sustained period of time. use or call 800-222-7820 and explain the situation and get another company to fix it right.
Posted on Dec 06, 2008
Sub zero 650 freeze works fine but refrigerator won't stay real cold. Turned off breaker, condenser is clean. Message to vacuum keeps coming on.
check this videos to see what and how. Can Repair in Orange County CA much cheaper then any other company. Have License and Insured.
Jan 05, 2014 | Sub-Zero Refrigerators
Sub Zero freezer keeps running
What is the model number of your unit?
Oct 21, 2012 | Refrigerators
Frost developing inside the refrigerator on the bottom two shelves
Lets go over the way a sealed system works. There is a highj side and a low side. The low side is the side that passes through the evaporator coils inside the machine. Most times on the freezer side only, but sub zero has independent sealed systems for each side. Once it goes throug the evaporator its then condensed into a liquid state, the high side. This is also the hot side. Well, lower pressures in the low side would logically mean lower temperatures. So for the refridgerator not to freeze more freon is used on it to keep the low side pressure higher than normal, giving the cooling effect verses freezing. So, and here is the bad part, if you are seeing ice build up in the refridgerator side you have a freon leak some where allowing the pressure to be less than required to keep it above freezing. Call a service technician and depending on how the model, sub zero warranty is parts and labor covered for the first 6, and only parts from the 6-12 year.
Apr 29, 2012 | Sub-Zero Refrigerators
My sub zero is great Ive had it 10 years. Just recently it has started to run warm going up to 43 degrees and then drops down to 36 degrees for no reason. What could be happening?
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
Sep 10, 2011 | Sub-Zero Refrigerators
Vacuum condenser keeps flashing
Clean the coils, usually at the bottom of the unit, remove the cover and use a vacuum and a bottle brush and clean away, use a crevice tool on the vac. hose but do not force it between the coils.
Jun 26, 2011 | Sub-Zero 650 / O Bottom Freezer...
Sub Zero 611F "vacuum condenser" warning persists, unit not 100%
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Jun 29, 2009 | Sub-Zero 611 / O Bottom Freezer...
Starting to get a little water on shelves.
Below is a link that will help you solve the problem. Would put it here but is detailed and helpful. Thanks Sea Breeze
May 27, 2009 | Whirlpool ET1FTTXK Top Freezer...
Sub zero bottom freezer access
that unit must be 20 plus years old. There wouldn't be any diferent shelves available for it.
Jan 31, 2009 | Sub-Zero 650 / O Bottom Freezer...
Refrigerators Logo
604 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
Sal De
John Tripp
John Tripp
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
