Question about Asrock 775i65GV Motherboard
My computer is not working
I have been using my asrock motherboard for just 2 years now. I'm having problem with it because POST does not operate. I have check other possible problems but it seems that the problem is in the motherboard. What could possibly be the reason why POST does not run?
  • Anonymous Aug 21, 2008
    I'd like to ask if static electricity can affect the motherboard and cause the computer to hang up or fail to booth?
  • Anonymous Dec 04, 2008
    my asrock 775vm800 mother board with my pc some time be shutdown so last week i will remove my pc all parts and i clean when i fix it after i turn on my pc now my problem is when i turn on have 3 beep code its like beep beep beep i replace my DDR ram also but my pc stil same and not starting my monitor also pls help me i dont no what i want to do thank you
My Asrock mother board doesn't work. When I switch on my computer it shows nothing.
A technical person told me " Your Asrock mother board has burnt out". I want to know hoow to repair my Asrok mother board.
Thankyou.
Posted on Oct 03, 2008
  • 3,051 Answers
Have u tried to boot into bios switch it over to optimal settrings or default settings and save and try to reboot
Posted on Aug 17, 2008
Memory pc3200 ddr 400
With many mobos (motherboards) you must place a single stick in a certain slot in order for the mobo to post. In my Asrock it is the #2 slot for a single stick. If I put it in the other slot the computer will not post. Try moving your stick to the other slot and reboot.
Oct 12, 2013 | Asrock Computers & Internet
Asrock conroe b65gv motherboard only working cpu fan.....
First thing to check with a desktop computer problem is the Power Supply.
This I state a lot.
In reality there's a flaw.........
In reality a person should visual check for bad capacitors on the motherboard, then move to the Power Supply.
The AsRock Conroe865GV uses nothing but Electrolytic Capacitors.
(Radial Aluminum Electrolytic Capacitors to be exact)
Doesn't use any Solid Polymer Capacitors.
These are known to be a 'weak link' on a motherboard.
http://capacitorlab.com/visible-failures/index.htm
http://www.youtube.com/watch?v=Lut7MX5Dd_A
Capacitors are used as Filters, and Voltage Regulators, on the motherboard.
The ones used as voltage regulators are in the Motherboard Voltage Regulator Circuit,
http://www.hardwaresecrets.com/article/616
Just thought you might like to know
Since you indicate the CPU fan is spinning, I assume you know the computer isn't supposed to be dirty inside.
If you don't............we need to have a long talk..........
With a Power Supply having a weak voltage power rail, you may see LED's light, and maybe fan's spin, but there won't be enough power to turn the CPU (Processor) on.
1) If ALL of the LED's were on at once, they would use less than 1 Watt of power.
2) EACH fan uses 2 to 3 Watts of power.
3) A typical CPU (Processor) can use 51 to 130 Watts. Just depends on what CPU it is.
AsRock Conroe865GV?
http://www.asrock.com/MB/overview.asp?Model=ConRoe865GV
The motherboard chipset is an Intel 865GV chipset,
http://en.wikipedia.org/wiki/List_of_intel_chipsets#Pentium_4_chipsets
Can support Intel Pentium 4 HT, models 620 through 672; for ->one.
They can use Up To 115 Watts,
http://en.wikipedia.org/wiki/List_of_Intel_Pentium_4_microprocessors#Prescott_2M_.2890.C2.A0nm.29
[ AsRock Support states the Conroe865GV will support Intel Core 2 processors, but I don't believe it.
It isn't until you get to the Intel 945G, that Core2 support is picked up.
Just my 2 cents ]
High voltage AC electricity comes into the Power Supply, and is contained in it's metal case.
The AC voltage is converted into low DC Voltages.
3.3 Volts DC, 5 Volts DC, and 12 Volts DC.
In comparison two D cell flashlight batteries produce 3 Volts DC.
A multimeter is used to check the three voltages.
Need guidance with this post back in a Comment.
[An economical multimeter around here, can be purchased for around $5 to $12.
Available in a lot of stores. I have seen them on checkout aisle racks, of major discount stores ]
OR;
Use a KNOWN to be good, Compatible power supply for a test unit.
May be a working computer that is not being used, that you can Temporarily borrow it's power supply.
Let's start the diagnosis from here..........
Post back in a Comment
Regards,
joecoolvette
Apr 18, 2013 | Computers & Internet
Asrock 4core1600p35-wifi+ lan port not working
Driver: Small piece of software that allows the Operating System to communicate with a device
http://www.asrock.com/mb/download.asp?Model=4Core1600P35-WiFi&o=Vista
Have you downloaded AND installed, the Realtek LAN driver?
If so tell me the procedure you used.
If that still doesn't do it use an Ethernet Card in an open expansion slot;
PCI
or
PCI-Express x1.
Post back in a Comment if you need guidance in downloading and installing the LAN driver.
Also for any additional questions.
Regards,
joecoolvette
Mar 03, 2013 | Asrock 4Core1600P35-WiFi Motherboard
I have a ASRock CONROE1333-DVI/H R2 motherboard and i wanted to know if i could use a graphics card that requires a pci express 2.0 slot
Absolutely!
The AsRock Conroe1333-DVI/H R2 mobo uses PCI-Express 1.1 technology. It's in the Intel 945G motherboard chipset.
http://www.asrock.com/mb/overview.asp?Model=CONROE1333-DVI/H
http://en.wikipedia.org/wiki/List_of_intel_chipsets#Pentium_4.2FPentium_D.2FPentium_EE_chipsets
Scroll down to bottom of chart. 945G made in 2005.
http://en.wikipedia.org/wiki/PCI_Express
Scroll down to History and revisions.
PCI Express 2.0 -> 15 January 2007
A graphics card based on the PCI Express 2.0 technology, will work on a motherboard based on the PCI express 1.1 technology.
Why?
Because PCI Express 2.0 technology is Backward Compatible, with PCI Express 1.1 technology.
You just won't get the full capability of the PCI Express 2.0 graphics card.
Will you notice? NO
PCI Express 1.0a, and PCI Express 1.1, operate with a per-lane data rate of 250MegaBytes per Second. (250MB/s)
Transfer rate of 2.5Gigabits per Second. (2.5Gb/s)
PCI Express 2.0 operates with a 500MB/s per-lane data rate.
Transfer rate of 5.0Gb/s.
Make SURE you have Windows running, then install the software for the graphic card -> F-I-R-S-T, then physically install the graphics card.
(Computer unplugged from power, Anti-Static Precautions -> FOLLOWED)
The computer will not use the graphics cards software, UNTIL the graphics card is installed.
It will keep on using the integrated graphics on the motherboard, until the graphics card is installed.
Means get the motherboard going first, use it's integrated graphics.
Install software for graphics card, and then Physically install the graphics card.
(Don't forget to attach the monitor cable to the graphics card, lol!)
For additional questions please post in a Comment.
Regards,
joecoolvette
Sep 08, 2012 | Computers & Internet
SOUND CARD NOT WORKING FOR ASROCK G31M-S
Usually this kind of problem is due to error or missing audio drivers, so let's start from this point. Depending on the operating system you use, you can download the proper audio drivers from this official link.
Post me back any news. In case of a problem or clarification or further details needed, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Jul 10, 2011 | Asrock G31M-S Motherboard
No boot and beeps
The exact fault code indicates RAM or a problem accessing the RAM.
Check that you are using recommended/Approved RAM as ASUS and ASROCK (the budget arm of ASUS) are notoriously fussy with RAM.
If it all checks out then your northbridge could be dead and it will probably be scrap.
Feb 21, 2009 | Asrock K7S8XE Motherboard
HOW TO CHECK ASROCK MOTHERBOARD WARRENTY
»For Authorized Distributors Only: (Email: rma@asrockamerica.com)
»End users or indirect customer:
Thank you for choosing ASRock Motherboard. Due to the unique configuration of each computer, we recommend you to contact your dealer for technical support. If you would like contact us for technical support. Please send us an email support@asrockamerica.comand give us a detail discription of the problem alone with the following information.
  • CPU/Processor (Brand,Speed, FSB,Cache Size)
  • Memory (Speed, Capacity, Brand)
  • Video Card (Brand, Model, Memory size)
  • Operating System (Loaded service pack and driver)
  • Hard Drive (Brand, Model, Capacity)
  • Other Device (Brand, Model) * If necessary
*Additional system configuration information may require.
ASRock provide 1 year warranty service to Authorized Distrubitor ONLY, users should refer to the retailer or original vender RMA & Refund policy. For non Direct Customers, there is a $35.00 service charge + shipping for each item.
BIOS $15.00 + shipping
ASRock CD $5.00 + shipping
ASRock I/O Panel $5.00 + shipping
»ASRock Service Center (Brasil)
R: Andre Ampere, 153 -17 andar - SI173
Brookin Novo - Cep 0462-080
Tel/Fax: 55 11 5105-3137RMA Service: Email: rmabr@asrockamerica.com
http://www.asrock.com/support/index.asp?c=RMA
Dec 31, 2008 | Asrock 775i65G Motherboard
BIOS is more than two years old.
Hi karl, please click on the link provided below.
http://www.asrock.com/mb/download.asp?Model=P4i45D%20R3.0&s=
Scroll to the bottom of the page. These two bios updates are the last updates posted by Asrock. All drivers are free.
Asrock's main web link for the P4i45D motherboard.
http://www.asrock.com/mb/overview.asp?Model=P4i45D%20R3.0&s=
If you find this information answered you're posted question, please vote this as a fix.
Have more questions, feel free to post it here or click the Ask Me button under my user ID.
Mike
May 19, 2008 | Asrock P4I45D Motherboard
Motherboard is dead!
Here is a new board. http://3btech.net/asp4so47880p.html but you have 90 days to set it up & test it.
To answer you're question. (Yes it will fit). Both boards are Micro ATX.
Here are links for both boards showing their specifications.
Asrock P4i65G
http://www.dealtime.com/xPF-Asrock-Asrock-P4I65G-skt-478-i865G-800FSB-dual-ch-DDR400-8x-AGP-64MB-on-board-VGA-SATA-RAID-LAN-USB2-0
Asrock P4S61
http://www.dealtime.com/xPF-Asrock-ASRock-P4S61-P4-SIS-661FX-DDR400-Motherboard
This is ASRock's web site for the P4i65G
http://www.asrock.com/mb/overview.asp?Model=P4I65G
If I can be of more service, just post back & let me know how thing go.
Mike
Apr 28, 2008 | Asrock P4S61 Motherboard
Asrock 775i65GV Motherboard Logo
177 people viewed this question
Top Asrock Computers & Internet Experts
David
David
Computer Links
Iqbal Husain
Iqbal Husain
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
