Question about Hotpoint Ultima WF840 Front Load Washer / Dryer
Ultima WF840 won't go from wash to rinse cycle
My washing machine starts it's cycle fine and then as it's about to go into rinse mode it just stalls. The digital timer on the front just counts down the minutes and I end up cancelling that cycle and going for the rinse & spin cycle. This cycle is now stalling too with around 15 minutes remaining on the clock and then the timer goes back to 30 minutes - evenutally it works it's way through the cycle after a lot of clock jumping! Also, I've noticed it's leaking underneath and a little from each side at the front. I have taken out the dispenser drawer and thoroughly cleaned it as well as it's compartment. Any more ideas?
  • utah_burbs Feb 21, 2009
    My washer does exactly the same things! Counter goes down to 1 min, but it hasn't rinsed or spun. Then it sits on 1 min forever unless you cancel it and put it on a seperate rinse and spin cycle. Mine is also leaking from the door and the drawer. We have checked and cleaned all the pipes and the door seal looks ok?
  • 24 Answers
The pump is blocked, so the sensor detects that the machine has not emptied in the allocated time, so this will reset the time.... the pause is because it knows there is a probblem getting rid of water.
location: bottom right near the motor. ensure you tip the washer as far forward as you can so you can get a bucket under in order to prevent flooding.
hope this helps
Posted on Apr 18, 2009
I have a hotpoint wf840 everytime i enter a wash cycle it just says test and performs a spin cycle whilst test still comes up on the screen is there anything i can do other than buy a new washing machine
Try the following, may work:
  1. Press the Start/Cancel button together until all the console Led's illuminate
  2. Press both Start/Cancel and On/Off buttons together until 'd off' appears
  3. Default screen should return and you can select a new programme
May 05, 2010 | Hotpoint Ultima WF840 Front Load Washer /...
Code F/o3 keeps coming up at the end of the cycle and machine just stops working
Error code F03 indicates that the wash thermistor is open or short circuit.
Check the connections to the thermistor
Jan 20, 2010 | Hotpoint Ultima WF840 Front Load Washer /...
Hotpoint ultima super silent w f 840 shows fault 03
Code f03 means wash thermistor open circuit, this is normally part of the heating circuit, suggest you test heater and thermistos located in the end of the heater, and replace if necesscary. If heater o/k , then could be bad connection to control module, or broken wire, if still no joy, then call Hotpoint.
Please rate my solution.
Thanks.
May 30, 2009 | Hotpoint Ultima WF840 Front Load Washer /...
My hotpoint ultima super silent displays 'test' but dnt run cycle
its in factory test mode, this can be set by pressing the on and start buttons together. to reset, turn on while pressing the on and start together until dOFF appears
Jan 25, 2009 | Hotpoint Ultima WF860 Front Load Washer
Test on washing machine
yes try pressing the on/off button and start/cancel button at the same time
May 26, 2008 | Hotpoint Ultima WF840 Front Load Washer /...
Hotpoint wf840 displays "test"
Try This - It works for the Washer Dryers so it May work on your Washer.
  1. Press the Start/Cancel button until all the console Led's Illuminate
Hope this Helps.
Mar 12, 2008 | Hotpoint Ultima WF840 Front Load Washer /...
Hotpoint ultima
the code on my hitpoint wf840 this code keep flashing f-01 i dont what this means could you help me please.
Feb 13, 2008 | Hotpoint Ultima WF840 Front Load Washer /...
Displays F-03
NTC fault its electronic and needs engineer
But try this for most electronical faults first switch off mains wait 20secs and switch back on this resets most gadgets and gizmos if it doesn't work it was a free try.
Nov 07, 2007 | Hotpoint Ultima WF840 Front Load Washer /...
Hotpoint Ultima WF840 Front Load Washer / Dryer Logo
224 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
