Question about Hotpoint First Edition FEW12 Front Load Washer
Ginko wires to control switch . what colour goes where
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 24 Answers
Hi, We have just put our Hotpoint few 12 backtogether. If you tell me exactly what you need to know I will take the front panel off and let you know. contact me on suewade5@yahoo.co.uk
Posted on Aug 18, 2008
Wiring a d2 eberspacher diesel night heater up
how much it coast black & decker Heater product model no . or07d
thank you
Dec 22, 2013 | Heating & Cooling
I hav a Diva DV-603PG dimmer switch that has a black wire a red wire and a red wire with a white stripe. What wire is what?
This switch is for a 3 way system (2 switches controlling one light for a stairway or hallway). The black wire goes to the special coloured screw on the old switch (common). The common wire is either the original live wire feeding the 3 way system or it is the final wire that leads to the light fixture in a 3 way system. All 3 way systems have an either or wires called traveller wires that can be swapped from either end of the 3 way system. the red wire and the red wire with the stripe are to go to the 2 remaining wires that were on the old switch. Those are the traveller wires. If you have a green wire it goes to the ground (a screw at the back of the switchbox or any green or bare wire found in the box)
Jun 22, 2013 | Electrical Supplies
Wiring diagram for a vw sharan 2000 x reg wing mirrors
your mirror control switch has 9 wires.,your drivers door mirror has 5 wires color coded .from your mirror control switch to your drivers siide mirror / 0.5 black .0.5 brown. 0.5 brown. 0.5 black. 0.5 black.
your passenger mirror wires are 0.5 blue/black .0.5 blue/grey. 0.5 blue/white. the passenger mirror has a ground cable 0.5 brown.
the passenger mirror wire 0.5 green/white connects to a 5amp fuse/F25 onto F31 5amp to a wire 0.75 green/yellow.back to the mirror control switch.
Sep 11, 2012 | Cars & Trucks
Washer goes through cycle, until around 11 minutes until finished it stops, and goes into dL. Will not finish load. What does this mean?
Hi.
the error F/dL means Door Lock Error
The error is prompted when the door cannot be unlocked.
Here possible causes.
Door Latch mechanism broken
Door Switch Assembly defective
Wire Harness from Central Control Unit to the Door Latch or Switch Assembly broken
Central Control Unit (CCU)
Door Lock or Switch temporary failure (it can be reset disconnecting power)
You will probably need to replace the door lock assembly. Parts must be tested first.
Regards.
Ginko
Apr 28, 2011 | Kenmore HE2 Plus Front Load Washer
The program selector is not functioning and the door will not close properly. are they related and how do i fix, tks
Hi.
If the door does not close properly, the door switch may not close contact to timer circuit, and the machine may not do the cycle for this reason. Additionally, a short in the door switch wiring harness may jam the control module.
Before checking control module have a look at the door switch and at the wiring harness inside the door.
Regards.
Ginko.
Mar 21, 2011 | Belling 24 in. IDW603 Built-in Dishwasher
Seems to over fill the load with water and goes to ol at end of cycle
Hi.
The water level is determined by a pressure switch. The pressure switch is located near to the control module and attached to thin a rubber hose that goes inside the tub. Check the hose attached to the pressure switch for blockage. Blow into the hose and see if the pressure switch is clicking.
If replacing the pressure switch does not help, then problem is either a stuck inlet valve or a defective electronic control module.
A defective pressure switch is the most common fault that will cause this problem.
You can get parts and diagrams for this washer entering the full model number here.
Regards.
Ginko.
Jan 07, 2011 | Kenmore Elite Oasis 27052 Top Load Washer
Installing heating element on whirlpool dryer
The easiest way to get to the heating element would probably be to take off the front panel. Be sure to disconnect the power first as you may have to disconnect the door switch to give yourself more room. Even by doing that you don't have a full view of the element but taking out and putting in the barrel/barrel belt is a much bigger pain so you may want to try installing the heating element without pulling the entire thing apart.
As far as the wiring goes There should be two wires, one light coloured, and one dark coloured(probably white and black). The dark one usually goes to a small disk-like switch(called the 'limit switch) near the element before connecting to the actual element. The light coloured wire should go to the connector opposite the dark coloured wire.
It really doesn't matter which side of the element you connect it to as long as you don't connect them together.
Mar 23, 2010 | Dryers
Wiring a light switch up
black goes to the coloured screw.
white goes to the silver screw
green goes to the green ground screw.
Mar 02, 2010 | Cooper Wiring Devices 1301-7B GROUNDING...
I changed my 1982 Harley handlebars and controls to 2003 handlebars and softail controls and the wiring colours are different,i need late model wiring diagram to figure out what goes where
You can use an ohm meter to figure it out too. Just take the switch housing halves loose and look at what color wire goes to what switch. No problem.
Other wise you are going to have to find someone with a schematic or purchase a service manual for a late model. Wiring diagrams are difficult to find online. The latest I have is 1994.
Dec 22, 2009 | 2003 Harley Davidson FLSTC Heritage...
How do i wire a potterton programable controller
All you need to do is look at the wiring diagram on the back of the old room stat, you will have the following:
(normally wired with these colours)
OLD COLOUR CODING
Live (sometimes called common) - Red
Neutral - Blue
Switch Live - Yellow
NEW COLOUR CODING
Live - Brown
Neutral - Grey
Switch Live - Black
All you need to do is wire up the new stat with this in mind. (please note: if the wires are not colour coded like this then do not proceed and get an electrician)
Any problems or questions let me know
I hope this helps
Steve
Apr 23, 2009 | Honeywell Programmable Thermostat Heater
Hotpoint First Edition FEW12 Front Load Washer Logo
67 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
