Question about Gateway FPD2275W LCD Monitor
LCD Computer monitor
Computer boots up OK, showing Windows XP setting up, then monitor goes through a variety of colours stating "NO SUPPORT MODE".
  • neilsonagenc Aug 17, 2008
    Thanks for the tip. However, as I have tried connecting the monitor my laptop ( and the laptop display is good ) and the monitor still runs through a series of coloured screens and still gives the warning " No Support Mode",( Same as it does when connected to my PC ) I am thinking the problem is with the settings on the monitor rather than a problem with the card in my PC.
    The usual settings on the monitor don't change things !!
    Still need help !!!!!!!!
This problem may occur due to wrong driver of display card or wrong display settings.
Solution:
1- Start you computer in safe mode.
2- Remove display card driver.
3- Restart you computer.
4- Install display card driver (if it does not pick automatically).
Now it should show default settings. I hope it would solve your problem.
Posted on Aug 17, 2008
My Compaq Presario fall down and its screen gone colourless its not show anything normal when boot windows 7 it's colour goes red colour after booting showing very low quality colour....what I
Check the GPU and motherboard are OK by plugging an external monitor into the VGA socket and then booting. If the external screen is OK, replace the LCD screen.
Oct 09, 2014 | Computers & Internet
The screen is black and a blue box in the middle that states "analog out of range. 67.0kHz/60Hz
Try to see if this works on another computer first, if it does, then it assumes the monitor is ok.
Then as the computer boots up, boot to safe mode by pressing F8 and once in that state, set the display to a mode that the graphics card will support.
If none of the full colour options work, the graphics card may be incompatible, try changing the graphics card.
Jun 13, 2011 | LG FLATRON W2252TQ-PF 22" LCD Monitor
No signal from computer after Windows XP loading screen comes up: when I turn the computer on, there's video signal to the monitor, but once it gets to Windows loading, it stops and goes black.
Does it do the same when you bootup in safe mode (hit f8 key while booting up)? if it is OK in safe mode, then it is software problem, not hardware.
Post back what you find.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Oct 27, 2010 | Acer X233H 23" Monitor
I am using LCD monitor LG, my son changed some settings which i don't know, Presently, the monitor says Out of range 53.6KHZ / 60HZ. What is the problem and How to solve this problem and restoration of my...
He may have changed the display settings on the computer. He may have altered the refresh rate higher than the monitor can handle.
You can try start the computer in safe mode (F8 repeatedly on boot up, till the safe mode option comes up)
This will load basic video drivers, you should be able to check your settings now.
Windows xp / right click on desktop and your settings are there
OR control panel / display
Sep 04, 2010 | Samsung 510N 15" Flat Panel LCD Monitor
Our acer 19in LCD monitor goes blank after initial startup and msg "Input not Supported" appears. Startup msgs are shown but once Windows XP starts, this error appears
Your resolution is set above what the monitor supports.
when computer is first starting up hit f8 to get to boot modes.
choose Enable VGA Mode: This option starts Windows in 640 x 480 mode by using the current video driver (not Vga.sys). This mode is useful if the display is configured for a setting that the monitor cannot display.
When you are booted into windows you can then set your resolution to the highest that the monitor supports which is 1440x900
Let me know if this helps.
Mar 16, 2010 | Acer AL1916W 19" LCD Monitor
LCD is on...seems like backlight is not functional; when external monitor connected, boot-up and bios screen visible. After boot-up, screen goes to "power save" mode and will not return
Use the 'FN' key (blue coloured?) and one of the other blue-coloured keys to "toggle" the video:
1. LCD only
2. external monitor only
3. both LCD & external
After boot-up, Windows defaults to "LCD only", and so the external monitor goes to "sleep".
Dec 11, 2009 | Acer TravelMate 4010 Notebook
Envision L19W761 LCD TV - VGA mode failure.
The resolution or refresh rate of the computer is not compatible with the TV. Before the computer starts loading Windows, start tapping F8 and select "Enable VGA Mode" from the menu that appears, this will set your computer to a very low resolution (640x480). I believe the option is actually called "Enable low resolution video" on Vista, it's VGA mode in XP. Now you should get a picture on the TV, work your way up from there.
Jun 26, 2009 | Envision L19W761 19 in. LCD TV
It is all black, as if off
when starting windows press f8 key before the windows logo shows up > go to safe mode > click start>control panel> display>adapter>list all modes> choose 800x600 x 16 colours > apply > close > reboot to normal xp. OR When f8 key pressed > choose VGA mode. If this does not work then change the VGA Cable (borrow from someone if its TFT to test)
Jan 05, 2009 | Acer AL1717 17" LCD Monitor
It appears that the display resolution set in your display properties is out of the range that the LCD can display.
Try this.
Boot to the ENABLE VGA MODE by pressing F8 to get the Windows Boot Menu. If you can get to the desktop, then go to display properties, and see if you can change the resolution to higher settings and maintain video. (If the video blanks out, then it should revert to the previous setting in 15 seconds)
Aug 03, 2008 | Gateway FPD2275W LCD Monitor
Flatron L1719S
I think your monitor is unstable. Is it showing power saving when you boot your PC? Does it show something when the Windows XP splash appears?
Jun 05, 2007 | LG Flatron L1750S 17" LCD Monitor
Gateway FPD2275W LCD Monitor Logo
96 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
