Question about Sony VAIO PCG-K23 Notebook
System won't boot
When I am trying to boot, it just freezes with the Windows sign and dosen't do anything. I can see the cursor, and the fan are running. It will boot in Safe Mode but won't restore to an earlier time? I am Navy in Iraq and do not have the option of a repair store. Thanks
    President:
  • 2,961 Answers
Get into safe mode, but this time use last known good configuration, as it seems it cannot find the boot.ini file to start windows
Posted on Aug 17, 2008
What would cause an e machine to freeze at the e logo, cursor just spins.
Possibly attempting to boot from a nonbootable device. Remove any USB devices or periferals and try again.
Jun 24, 2014 | E-Machines Computers & Internet
Acer Aspire One Netbook Freezes Constantly Playing Video
ive got a kav60 netbook and the video and audio freezes, makes a nasty buzzing sound. i also have a problem with my mouse, it goes crazy, or sometimes doesnt respond unless i apply pressure to one side of the netbook (slightly bending). tried disconnecting the touchpad, and applying an external usb mouse, but it sometimes freezes the cursor,or the cursor does its own thing. please help
Aug 23, 2012 | Computers & Internet
I need to reset the bios as it gets to the black screen and the flashin cursor in top left but then just freezes after that and doesn't do anything. Please help
You need to run the Check Disk Utility. You've got a missing or corrupt boot or system file.
To run the check disk utility you will need a repair disc or a operating system disc. Put the disc in the cd drive and boot from it. You want to get to the Dos Command Prompt (Black screen with white letters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice the percentages going from high to low, this is normal. Let it run to completion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows. Try doing a Repair Install that way you don't loose your data, documents, music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair when the options appear.
In Vista and Windows 7 you want to get to the recovery console and look down at the bottom of the window for the Dos Command.
May 12, 2012 | Foxconn A74ML-K Motherboard AMD Socket...
GX620 Dell, will not boot, 3 green steady lights and power lite, usb light....when i power on, it looks at the hard drive, then stops. monitor has blinking cursor...no bios comes up, and cannot access...
Does anything ever post to the lcd screen when you press the power button to boot it? Does it every show you things like which key to hit to get into the Bios or System Setup?
I think you have a corrupt or missing boot file or system file. The blinking cursor is indicative of that. Try running the Check Disk Utility from your XP CD.
To run the check disk utility you will need a repair disc ora operating system disc. Put the disc in the cd drive and boot fromit. You want to get to the Dos Command Prompt (Black screen with whiteletters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice thepercentages going from high to low, this is normal. Let it run tocompletion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows.Try doing a Repair Install that way you don't loose your data, documents,music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair whenthe options appear.
In Vista and Windows 7 you want to get to the recoveryconsole and look down at the bottom of the window for the Dos Command.
May 04, 2012 | Computers & Internet
When turning on cd recorder it don't go past welcome, it freezes there, it a Tascam 222 cd recorder,What's wrong with it
try holding f8key be for it says windows and then either reboot or go to last go running go figuretion
Nov 09, 2011 | Tascam CC-222mkIII CD Player / Recorder
I have a program which has jammed up my computer. Once windows boots up, the cursor freezes. When I boot up in safe mode, I can use the cursor, but can not uninstall a program in safe mode--help!
If you are using Microsoft OS then after booting :-
Start > Run > MSCONFIG
Untich the program which is causing the program. Apply and OK.
Restart your machine once.
Please post your feedback and Vote if the problem resolved as per your satisfaction
Sep 23, 2010 | HP Compaq Presario R4000 Notebook
Cursor is frozen in microsoft windows 2007 , i can't type
First of all provide detail when does the cursor freezes after booting to the desktop or before and if after are you able to use it after booting to the desktop?
Try to boot in safe mode and check if it works fine then problem is either with your hardware or one of the third party applications or start up items assuming Microsoft and Computer first and second party
Oct 26, 2009 | Acer Aspire 5100 Notebook
The laptop loads up, lets me sign in, then goes blank, no icons
Try booting to the safe mode (F8 at boot) and see if you can log in via the safe mode. If you can't, try booting to your Windows CD, go to recovery console and run CHKDSK /R
If you still can't log in, try running diags see if the hard drive lists a failure.
if no hardware failure found, there and none of those solutions work, then re-installing windows will likely be the final resolution
Oct 06, 2009 | Dell Vostro 1500 Notebook
Curser freezes
When you said your cursor freeze, does the computer still respond or the whole computer froze. If the computer froze, then it could be anything from, memory, hard drive, cpu, or mainboard. Does the keyboard works, if just the cursor freeze, try using a usb mouse.
Nov 07, 2008 | IBM ThinkPad T40 2373 Notebook
Computer not booting to Windows and sometimes freezes
hiya
this cud be many causes, a corrupt driver or overheating
try booting into safe mode to find out if it is a driver or software issue, if it does not then i wud suggest checking your cpu fan is working as you say it shuts itself off.....as new cpu's have a thermal protection built into them to stop the from cooking.....
let me know if you have any joy
Sep 12, 2008 | Sony VAIO PCV-V200G PC Desktop
Sony VAIO PCG-K23 Notebook Logo
75 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
