Question about Acer TravelMate 2300 Notebook
Acer travelmate 2350
On pressing the on button the computer starts, runs for abou 5 seconds then turns off. Any ideas please?
    President:
  • 2,961 Answers
Either your battery is not holding a charge or your processor is faulty
Posted on Aug 17, 2008
Acer Travelmate 6493 not turning ON. It was working fine till i closed the lid and went away for some time. When came back and opened the lid it was not responding and Dead. Tried to reset by pulling...
unplug the power and remove battery.Then press power button to discharge any power left on capacitors.plugg only the power in leave the battery out and try to turn on the laaptop.
May 19, 2017 | Acer TravelMate 6493 Intel Core 2 Wireless...
The USB Ports on my ACER TravelMate 2350 Series Laptop, I have deleted the USB Port files from Device Manager and the machine reinstalled them when I re-started but it didn't change anything. I downloaded...
I'm guessing your USB ports don't work or does it always ask you to install them. If you have your Windows XP license key at hand, please try downloading and installing the following...
Acer TravelMate 2350 XP Chipset Driver
Reboot. It might ask you to do a reactivation, or not.
Please recheck if your USB ports still work. If not, restart your machine, hit F8 continously until you get many options - choose the option "Safe mode" and press Enter. Check if it picks up USB in this Safe mode.
What you can also try, is that you have 3 different USB 2.0 ports on your machine. Try each one separately and see if one of them works. I would also recommend to see if the USB device you are trying to use is actually functional.
May 19, 2010 | Acer TravelMate 2300 Notebook
My acer travelmate 2350 laptop has no sound checked all the vol and mute settings still no sound can yo help
my acer travelmate 2350 laptop has no sound checked all the vol and mute settings still no sound can yo help
Jan 30, 2010 | Acer TravelMate 2300 Notebook
HAVE LOST SOUND ON MY ACER TRAVELMATE 2350
Have you tried using the restore point? Go to start, control panel, performance and maintenance. on the upper left corner click System Restore. Choose the option restore my computer to an earlier time. Click next, Choose a date where you have remembered your computer has a sound. click next then OK. You can change restore point anytime. Else, reinstall your audio driver.
Dec 24, 2008 | Computers & Internet
Acer travelmate C110 & Acer projector X11602
Hi Andrew,
you can try changing the output of the travelmate, to VGA Or External Device.
ensure you have the correct output lead from computer to projecter. Then on your keyboard you should have a button that changes the output. i.e numerical 5-6-7 or 8. usually says LCD/VGA et,c.
failing this try altering the output in the systems bios setup.
you can enter this by pressing F2 Or esc at bootup.
if your unsure, and none of this helps, i,d suggest visiting acers site. and downloading the user manual(s)
Mike @ Compurepair.
May 22, 2008 | Acer TravelMate C110 Tablet PC
Acer travelmate 2350 take time to start (5 t0 30 minutes some times)
This is not any problem. B.coz if u have installed Vista Home Premium its take time after loging to display sacreen as pe your loaded software and drivers.
Mar 03, 2008 | Acer TravelMate 2300 Notebook
Acer travelmate 2350 boot password
Do u know to use Soldering iron...if u know..remove the proccessor from socket then de solder the BIOS batterry and short that two terminals on mother board without connecting the power adapter and battery...do it and re solder the bios battery..this procedure will help u to recover from ur problem..if u dont know then do it with any technician.
Dec 09, 2007 | Acer TravelMate 2300 Notebook
Acer Travelmate 2350
if your cdrom stops installing the operating system, then either the processor is damaged or the hard drive is faulty, as initially the installation files have to be installed to run the main O.S installation
Sep 21, 2007 | Acer TravelMate 2300 Notebook
Keyboard not working on acer travelmate 2350
it could be the sensors are damaged under the keys, but hopefully its just the driver. Right click on my computer icon and click properties and then the hardware tab, then device manager and look down the list for keyboard. Click the + sign and then right click on your keyboard under that and select uninstal. Restart the notebook and it will reinstall itself and hopfully work as it should do, if not then the keyboard itself is damaged in some way.
Sep 04, 2007 | Acer TravelMate 2300 Notebook
Acer travelmate 4000 laptop Big problem
I guess I can assume that you have it plugged into the ac power, so you know its not a power problem. We also know its not a problem with the power switch since the light turns on. So that leaves, motherboard, cpu, and ram possible problems. Ram would unlikely cause such a hault. Even with no ram, I believe the computer would make horrible beeping noises. So if its a problem with the motherboard or cpu, its pretty much trash, unless you want to waste the money on ebay or some place for another cpu to try to swap.
Aug 23, 2007 | Acer TravelMate 2300 Notebook
Computers & Internet Logo
91 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
