Question about DeLonghi Pinguino PACL90 Portable Air Conditioner
DeLonghi Pinguino PACL90 MODEL
WE BOUGHT THIS PORTABLE UNIT 3 YEARS AGO FROM SAMS CLUB. NO PROBLEMS TIL THIS WEEK. IT WON'T COOL THE ROOM. I'VE EMPTIED THE INTERNAL CIRCUIT OF WATER, WASHED THE DUST FILTER, VACUUMED THE 3m ELECTROSTATIC FILTER. THE VENTS ARE CLEAR AND AIR BLOWS OUT. IT STILL DOESN'T COOL. I DON'T WANT TO ORDER A NEW 3M FILTER SINCE I DON'T KNOW IF THIS IS THE PROBLEM. CAN I TURN THE UNIT ON FOR A WHILE WITHOUT ANY FILTERS IN PLACE, TO SEE IF IT IS THE FILTER BEFORE I ORDER A NEW ONE? I THINK IT'S A DIFFERENT PROBLEM, POSSIBLY THE FREON. PLEASE ADVISE. THANKS JUDY
  • 1,420 Answers
For a short time you can run without filters. I suspect it is low on charge or the metering devise is not working. Check this link out for an owners manual. It may help you.
http://www.manualnguide.com/download/manual-guide/delonghi-pinguino-pac210-portable-air-conditioner-owners-manual.html
Posted on Aug 19, 2008
SOURCE:
Cooling issues (low refridgerant?)
Make sure both the evaporator and condensor coils are clean. After the unit has been off for a couple of hours, start it back up and measure the temperature difference between the air entering into the unit (room air temperature) and the air blowing out of the unit and into your room. You should have approx 20 deg......take this measurement after approx 5 minutes of run time. If the temperature difference less than 15, you may very well have a refrigeration problem. If it is approx 20 degrees, then it could be a dirty coil or an electrical problem.......inspect all of your electrical wires and controls for any signs of overheating.....tighten all connections.
I hope you find this to be very helpful in your diagnosis. :-)
Mar 23, 2010 | DeLonghi Pinguino PACL90 Portable Air...
DeLonghi Pinguino PAC CT90 It is less than a year has quit coolin
Read instructions and see if it says anything about cleaning or filters. A.C units **** air in and there is a filter that probably needs cleaned.Also,while cooling, the vent to the outside should put out warm air. Also, if it is less than a year old, contact the manufacturer and they should help you out. Good luck.
Feb 13, 2010 | DeLonghi Pinguino PACL90 Portable Air...
DeLonghi portable airconditioner leaking water
nbenz ,
Welcome to fixya.
I'm Huuum and happy to assist you,
Portable units are supposed to spray the water on to the hot compressor an evaporate the water!
If it is only 3 weeks old ,you have a 1 year warranty. call service and let them fix it for !
Please remember to leave a rating before you go!
Thank you
Aug 26, 2008 | DeLonghi Pinguino PACL90 Portable Air...
Blows room temperature air
Hello
Welcome to fixya.
The air conditioning
unit works, but does
not cool the room
• window open
• there are heat sources in the room (burner,
lamp, etc)
• the exhaust hose is detached
• air filters clogged
• Inadequate size of the room (too large)
• close the window
• eliminate the heat source
• connect the exhaust hose
• clean or replace the filters
If all this dose not remedy the problem then you need to see service!
Thank you
Jul 13, 2008 | DeLonghi Pinguino PACL90 Portable Air...
Probe Failure
i service the delonghi brand in tampa fl we have seen alot of probe failures. some last years some go out in 4-5 hrs of usage
Jun 19, 2008 | DeLonghi Pinguino PACL90 Portable Air...
Delonghi Pinguino PacL90 replacement hoses
Delonghi Replacement Parts:  800-865-6330
They only open Monday through Friday from 8:30 - 5:00.  Not much help when the unit goes out on a weekend.
Be very familiar with your product before calling.  I dealt with a few incompetent people before I got to someone helpful.
Jun 08, 2008 | DeLonghi Pinguino PACL90 Portable Air...
Delonghi AC problem
suspect a faulty running capacitor.
Apr 24, 2008 | DeLonghi Pinguino PACL90 Portable Air...
Heating & Cooling Logo
684 people viewed this question
Top DeLonghi Heating & Cooling Experts
Paul Carew
Donni Steen
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
