Plug a laptop into just the linksys. Make sure nothing else is connected. Then on the laptop go to start -> run and type cmd. In the black box type ipconfig. This should show you the ip settings on the laptop. There should be one with a default gateway filled in. This will be the lynksys's IP address.
Perform a Linksys reset:
The easiest method of resetting your Linksys router's password is to reset your router back to the default factory settings. This is done by simply holding down the reset button located on the back of the unit for at least 30 seconds. Once the router has been reset, it must be reconfigured. Using your web browser go to URL address http://192.168.1.1. You will then be prompted to login to your router. A log-in screen asking for the password will automatically appear. At this time enter the default password "admin", in lower case letters into the password field. The username field may be left blank at this time. (Note: both the default username and default password are set to "admin" on some of the newer Linksys router models).
Router setup
You do not have to use the cd. Go to the control panel and un-install the program that the cd installed. then:
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
