Question about RCA F32672SB 32" TV
Rca 32'' tv
No picture, screen totally black, but audio still working
  • RCA Master
  • 1,550 Answers
If you are a technician you can solve the problem if not you need send the device to a repair center,the problem are a coil between the pins of the horizontal output transistor maybe get solder joints cracked you need to resoldered .
Posted on Aug 17, 2008
Rca 32" lcd tv.vertical lines on entire screen,no pix.
? 5:29 25, 2013 - Uploaded by Tampatec I have a LG 42PM4700-UB plasma tv that just went black. The red power .... I have a RCA 32 inch it has no sound or picture !Just a light blue ...
Sep 09, 2015 | RCA L32HD31 32 in. LCD HDTV
"32" rca tv about 3 years old was on & it went black- power light is on"
sounds like the sceen is dead, if you are receiving nothing on screen, then it sounds like either a component and/or screen is gone... however, check the tv input to make sure it wasnt acidentally switched to an input channel with nothing selected... if that does not work, call local tv repair or mfg customer service tech. if under warranty, have repaired or replaced. without physically seeing tv, it is hard to diagnose issue outside of information given. could be simple board replacement or could be screen.. but check input first, if a dvd player plays, then it could be just component or input on wrong selection
Oct 17, 2010 | RCA 32V550T 32" TV
RCA TV. No picture yet has sound.
I unplugged the tv and the cable box and pulled out the battery of controls for 12 hours. When I turn on again, the tv and cable box back to normal.
Jan 24, 2010 | RCA Televison & Video
Digital or not????
You can get the owner's manual at;
You need a converter box.
33.07"W × 25.83"H × 9.09"D
Weight 45.54lbs
Panel Type Active Matrix TFT LCD
Screen Size 32" widescreen (16:9)
Color Range 24 bits (16.7 million colors)
Max. Resolution 1366 × 768
Pixel Pitch 0.51075mm (H) × 0.51075mm (V)
Sync Range Horizontal: 30–80kHz
Vertical: 50–85Hz
Contrast Ratio 800:1
Brightness 500 cd/m2
Viewing Angle Vertical: +/–85°
Horizontal: +/–85°
Response Time 16ms typical
Inputs 2 × progressive scan component video (RCA)
3 × composite video (RCA)
1 × S-Video
6 × stereo audio (RCA)
1 × SVGA (15-pin D-Sub)
1 × stereo audio line in, 0 dBV nominal (1/8" TRS)
Outputs 1 x composite video (RCA)
1 × stereo audio (RCA)
1 × subwoofer (RCA)
1 × headphone (1/8" TRS)
Video Formats Supported SDTV: 480i
EDTV: 480p
HDTV: 720p, 1080i
TV Tuner NTSC-M, CATV, 181 channels
TV Audio Mono, Stereo, SAP
Parental Controls V-Chip (TV PG, MPAA)
Picture-In-Picture PIP, PBP
Closed Captioning CC1–4, TEXT1–4
Speakers 2 × 10W
Plug and Play Compliance VESA DDC1, DDC2B
Power Supply 100–240VAC, 50–60Hz
Power Consumption Operation: 232W
Standby: <3W
Storage Temperature 0 to 60°C
Operating Temperature 5 to 35°C
Apr 08, 2009 | Protron PLTV-32 Television
Using rooftop antenna through converter bos to RCA TV
Turn off the text box function of the closed caption decoder on the tv.
Nov 03, 2008 | RCA F32650 32" TV
RCA 32
this problem may occur due to some drysoldering of some components on the mother board...mostly in the power supply section.
Jul 09, 2008 | RCA F32450 32" TV
Powers on by itself
TV worked FINE for the past 2 yrs---this morning we woke up and the screen is totally BLACK! No sound..nothing. REmote doesn't do anything to the TV. Red light says ON unless we unplug it. Remote won't turn off the TV.
Any advise? Picture tube??
Worked great w/out any problems until we woke up today!
Jun 01, 2008 | RCA 32V420T 32" TV
Usuable signal/blue screen
No picture, just black screen
Check R3414, an SMD chip on the CRT board. There could be invisible bad solder joints
Noisy picture
Replace relay RY481 on S2 board
Picture int disappears leaving snow on screen
Resolder the Xtal in the tuner
Nov 23, 2007 | RCA 32V430T 32" TV
Televison & Video Logo
57 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
