Question about Electrolux Epic 6500 Vacuum
Bag Full Sensor
I have an Epic 6500 SR and the full bag light will not go out after I changed the bag. Based on another post it sounds like the full bag light switch is sticking. How do I get to that switch ? Thanks
  • stevelaur Apr 30, 2009
    I removed everything as described but what do you do with the sensor valve or sensor?
  • bangjeha
    bangjeha May 11, 2010
    I have the same problem but am having difficulties to open the top of half of the unit after I removed the two side rubbers. Could someone explain in more detailed, how much prying is needed? Thanks.
    bangjeha
Opening The Unit:
Remove the hose, open the door, and remove the bag. Making sure that the door is open wide enough, pull the rubber strip on each side of the canister toward the opening until they are completely removed. With a little shifting, you will now be able to pry open the top cover from the bottom. Remove the obstruction sensor hose so that you can completely separate the halves.
Note: If the strips will not move toward the front, the you will have to slide them off to the rear. You will need two screwdrivers to pry open the top rear of the unit far enough to release the back cover.
Locating The Switch:
The "trip" switch is located on the inside top cover under the power button. The trip switch is activated by the sensor valve next to it.
Posted on Sep 20, 2008
  • 58 Answers
Its a bad controll valve i would take it to a vacuum shop so you don't break your expensive vacuum trying to pry it appart.
Posted on Jul 26, 2009
Epic 6500 Sr. Why does it keep turning on and off?
Electrolux Epic 6500 - Bag Full Indicator Bypass - YouTube
? 0:55
https://www.youtube.com/watch?v=YrMgoUAHcI4
Jun 23, 2013 - Uploaded by easilen
The rear pops off. There's a vac. ... Yeah, keep it. Undo Close ...Electrolux Epic 6500 - Bag Full Indicator ...
Questions and Answers for Electrolux Vacuum Unit
builtinvacuum.com/help/electrolux/qanda/main-central-unit.html
For Electrolux; Central Vacuum Attachment Kits and Hose and Tool Kits for Electrolux Attachment ... With a clean bag in, the unit starts up and immediately shuts off. If you hold ... From what I have read hear, it sounds like the motor is going. ... How can I fixmy electrolux epic 6500 SR vacuum? ..... It keeps cutting off and on.
Electrolux Epic 6500 SR Shuts off when power hose ...
Dec 28, 2015 | Electrolux Vacuums
I have the electrolux epic 6500 sr. when i
As hooton8 stated i have the electrolux epic 6500 sr. as well and when i attempt to vacuum i turn it on and it turns off after about 3 seconds. new bag nothing stuck in tube. I turned dial to the right all the way. Works when hose is not connected..hose is clear.
Dec 05, 2009 | Electrolux Epic 6500 Vacuum
What does the warning light with question mark mean on the Electrolux Epic 6500 SR canister?
It means to check the bag. Your bag is either missing or misaligned and has slipped past the little clear sensor or bag lockout plunger in the corner of the bag chamber at the door.
Remove the bag turn on the vac and push this switch, the vac should start when the switch is depressed. If not the internal switch inside the vac is misaligned or damaged. Please post back to confirm how you make out
Oct 13, 2009 | Electrolux Epic 6500 Vacuum
What size/model bags do I need for my Electrolux Epic 6500 SR vacuum?
You need an Electrolux Cannister bag to fit pre 2001 Series cannisters. You can fin them at a VAC Service center or thru AERUS Electrolux. Buy only a 4 ply bag, nothing thinner.
Sep 08, 2009 | Electrolux Epic 6500 Vacuum
What is the symbol above the "change bag" symbol?
When the bag is full, the "full bag" light will come on and will turn itself off. Replace bag (make sure there is no clog) and try again.
Hope this helps.
Aug 17, 2009 | Electrolux Epic 6500 Vacuum
Vacuum won't stay on
When you open the canister you eill see a little rubber hole that senses when your bag is full. This must be clogged. If you have another vac try to vacume all the dusr from this hole and any other opening inside the vacume that you can reach. I hope this helps. Don't forget to rate this answer.
Feb 07, 2009 | Electrolux Epic 6500 Vacuum
My Electrolux upright worked fine
Are you using the proper bag? There's a kill/reset switch that needs to be pushed down by the rim of the bag before the unit will run.
Jun 22, 2008 | Electrolux Epic 6500 Vacuum
Electrolux Epic 6500SR Full Bag sensor working, Does not Reset properly
The problem was a sticking switch that was not being reset. The vacuum on/off switch mechanism is comprised of two switches. One is the main switch that turns the vacuum on and off. The second is a shut off switch that gets tripped when the full bag sensor is engaged. This second switch is supposed to get reset when you push the on/off switch on the outside of the machine. The full bag shutoff switch was stiff and it, therefore, was taking a couple of presses of the on/off switch to move the shutoff switch back into the running position.
Jun 19, 2008 | Electrolux Epic 6500 Vacuum
Full bag system works properly, but doesn't reset easily
Either there is something wrong with your switch. Which it doesnt sound like it. Take it to your dealer or call another one it sounds like the control valve needs to be replaced. I am a dealer 1-866-966-9350.
Jun 19, 2008 | Electrolux Lux 7000 Bagged Canister Vacuum
Repair my Electrolux 2100 cannister vacuum cleaner
On my 6500, I just disconnected the air line from the switch and now the vaccuum won't sense the bag pressure; I just have to check the bag myself now.
Vacuums Logo
840 people viewed this question
Top Electrolux Vacuums Experts
Chris Nomland
Chris Nomland
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
