Question about Maytag Dishwashers
Three-year old Maytag dishwasher is making terrible buzzing sound while still squirting water. Wondering if disposal on unit is jammed, and if so, how to unjam it.
  • zeldfelder Oct 28, 2008
    2 month old Maytag dishwasher (Quiet Series 300) also started buzzing during wash cycle. Any suggestions?
Got the washer fixed by removing parts until I got down to the chopper, which was jammed by a small, plastic ice cream spoon. Was relatively easy to fix. Keeping the screws with the parts they secured was helpful.
Posted on Aug 18, 2008
Our year old Maytag Dishwasher...Legacy Series...won't drain, which means it won't run another load
If you have a silver air gap on your counter top start there. It will pull off or turn off, make sure it is clean. Check your drain line to the garbage disposal, All ways run the water near your DW until it is hot. Most people do not do this and it amounts to 85 % Of my calls. Hope this helps.
Sep 13, 2010 | Maytag Dishwashers
When starting wash cycle the dishwasher cda cw447 doesnt appear to be getting enough water in and is making a droning / whirring / electrical ? noise. pipes all connected ok inc aquastop water supply unit,...
Try removing the inlet pipe, and refitting, might fix it, else likely that the
Inlet water soleniod failing/failed or tiny mesh filter (it does come out for cleaning) behind the inlet hose clogged. Temporaily bypass the aquastop water stop unit; it might be the culprit!
A replacement solenoid is usually only about £10 from, or ebay sellers (no connection with these but they are very good), fits in minutes (2 or 3 electrical spades ,and a posidrive or two) and usually fixes all water related problems. the noise you can hear is probably the solenoid trying to actuate, will be droning/buzzing sound.
could simply be stuck with some foreign matter in there that's got through the mesh filter but unlikely. they normally fail and sound terrible.
Don't throw your dishwasher away for the sake of a £10 part.
Good luck
Sep 12, 2009 | Dishwashers
I have an old Maytag dishwasher, which came with the home we purchased 20 years ago. i am wondering how water efficient it is; it still works, but I also frequently find it with dirty water which has...
It is as efficient as any dishwasher made today. It is also mechanically better than most made today. Keep it running as long as you can.
Under the sink find the dishwasher drain line,using a piece of wire or string tie the DW hose up under the sink so that there is a rise in the hose from the disposal drain outlet.This way drain water will not go back down the hose.
Aug 24, 2009 | Dishwashers
Maytag MDBTT79AWW dishwasher fills and nothing else. Once filled you hear a click, followed by a humming sound for 3-5 seconds, then silence. This will happen two or three more times, and then unit will...
That sounds like the motor trying to start but being jammed it is shutting off via an internal breaker. Check for something in the bootom of dishwasher that might have gotten down there that could do this. You might have to take the sprayer off and some things below that.
Mar 04, 2009 | Dishwashers
Kenmore elite dishwasher making loud buzzing sound when washing
it sounds like a broken empellar in the pump like there is a piece of it broken off and ratteling around in there... change the empellar
Feb 21, 2009 | Dishwashers
White build-up
this is scale build up you should run a descaler through your unit if you cannot find any viniger works just let it sit in overnight
Dec 10, 2008 | Maytag 24 in. MDB5600A Jetclean II...
Maytag mdb9150
check pump and solonoids click/work, if no mechanical noise, could be the circuit board, but they can be expensive. :(
if the solenoids click, and allows water in, then the pump might be jammed, with grit, clean and reinstall... good luck !
Aug 05, 2008 | Maytag 24 in. MDB9150A Built-in Dishwasher
Top Rack of Kenmore doesn't clean
the chances are the water pipes are blocking in the base. check all the hoses are clear of debris then check things like the spray arm holes are clear and also check on the water level in the cavity.
Jan 20, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwashers Logo
90 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
