Question about Onkyo Audio Players & Recorders
Im having trouble setting up the onkyo surround sound system i bought, i think i have it mostly correct, but there is no sound coming out
  • 682 Answers
1-make sure that digital input source is selected.
2-make sure all audio connections are firmly inserted in.
3-all polarity of speakers is correct and no connection of bare wire with metal part of the receiver.
4-check volume control in good level.
5-check for muting indicator and cancel it.
6-headphone is not connected.
7-check the digital audio output setting on the connected device.and make it on.
Posted on Aug 17, 2008
Using HDMI cant get video from ps3
Check your ps3's audio settings. They come under the settings tab, 7th from the top i guess, not sure. Just play around with the settings until you think the sound problem is fixed.
Jan 02, 2014 | Sony Playstation 3 (PS3) Console
I have just set up my onkyo 5305 i only have sound to front speakers have checked connection but im lost now in the settings
Onkyo are known for having 2 seperate connections for the rear speakers. 1 set for a surround sound, channel "A", and 1 set for seperate set a speakers, channel "B". check for the second set of connections. Also, your only gonna get sound out of the rear speakers thru surround sound mode when the unit actually sends singal. The sound is determined buy what setting you have the receiver set to.
Mar 06, 2011 | Onkyo HTP-102 System
I just bought a Blue Ray player but my surround sound has a dvd player built in and only one input which I have my new Sharp TV plugged into. How can I hook up my Blue Ray . I have the HDMI cables
Depending on if your surround system has a hdmi input or not. if it does you can connect the blu-ray player to it. If it doesn't have an hdmi input you will have to run the hdmi cable from the blu-ray to the tv then run a set of rca cables (red and white plugs) from the tv audio out to the surround systems' audio input jacks to get sound through the surround system. Most surround systems don't have an auxiliary input for another video device.
Nov 21, 2009 | Onkyo TX-SR606 Receiver
No sound from Surround speakers of my onkyo reciever
Check speaker wireing make sure all positive and negative connections are correct. What cable are you running from tv or DVD player.check to see that wireing is correct on receiver for sorround speakers. Run audysee sound calibrator set up. Make sure correct settings for sorround sound in bluray player/DVD player
Sep 13, 2009 | Onkyo HT-S990THX System
Surround Speakers will not work
Perhaps you have the live wire in the wrong connector from the speakers? They should be color coded. I would check that first. And if you have moved, they are most likely in different positions, you'll have to rerun the audio setup for the surround sound. You should have a separate microphone to use for that that plugs in to the system.
Aug 31, 2009 | Onkyo HTR500 Receiver
ONKYO HT-S780 B SPEAKERS
Your symptom sounds as though you may have to turn off any surround sound settings that you have selected in the other modes.
Most amplifiers use the surround portion of the amplifier to power the B channel speakers.
Since you have sound when using the radio portion, I would try turning off the surround mode. For example try turning the amplifier to just stereo and see if that gets the B channel speakers to work
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. (Two Thumbs Up) If you cant rate this post with the highest rating, then please comment to this post and I will try to help you further.
Jun 22, 2009 | Onkyo HT-S780 System
Onkyo digital reciever has poping noise when in dolby sound
I have the same reciever, and had the same problem.  Contact Onkyo, this is a known issue where defective DSP chips were used and manifest problems with a popping / clicking sound when using surround settings.  These receivers also have a Dolby Digital input issue that can cause audio dropouts when watching cable or SAT broadcasts that encode DD using a 'newer' broadcast encoding methods.  Onkyo is covering the cost of that repair for me now, even though the receiver is 5 years old now....
Jan 02, 2009 | Onkyo TX-DS797 Receiver
No sound from rear speakers
Hello, the setting must be "Not Activated" That is for zone 2 setup. If you are setting up 5 speakers the rear speakers should be connected to surround not surround back. Thank you Onkyo USA.
Mar 25, 2017 | Onkyo TX-DS898 Receiver
Hi We are setting up our new Onkyo TX SR606 receiver but are having trouble with the automatic speaker set-up. The 2 front speakers, centre and the back right speaker are ok, but there is an error...
Hi there. If you are running a 5.1 speaker system, make sure your surround speakers are on the surround terminal NOT ON THE SURROUND BACK. the surround back is only for the 7.1 speaker system.
Sep 13, 2008 | Onkyo TX-SR606 Receiver
NO surround sound coming from our harmon/kardon speakers when set up to our onkyo tx-sr601 receiver. wires connected in correct areas, front left, right and center speakers work, subwoofer works. setup for...
So your saying that you have no rear channel. Some recivers use a single stereo output ic for both sides on the rear speakers. you could have a defect with this IC . Anther thing Im sure you check3ed the obvious ie : the switch is on suround sound? If there is a front to rear fader is it in the middle? Good Luck
Jun 04, 2006 | Onkyo TX-SR601 Receiver
61 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
