Boxlight cp-310t won't display image
I dropped my projector accidentally a few weeks ago, but everything has been fine until today. The projector turns on and projects, but it doesn't display anything - not even the menu when I press the menu button. I just got a new lamp, and I'm not sure but the projector may not be projecting as bright an image as it was before. I can't tell, though, because it's just projecting black. This morning the projector worked fine, so I don't know what's up. Thanks for your advice! My projector does not display anything except for orangish screen without menu or any kind of display. please help!
  • 2,237 Answers
Loose connection
Posted on Dec 23, 2009
I bought the compressor about two years ago and used it only a few times. It ran fine a few weeks ago but today it will not start. It is as though it is not plugged in even though the outlet works for...
Is it possible that you didn't drain the air out of it after you used it a couple of weeks ago? If the pressure in the tank is somewhere around 100psi, the compressor won't run until it drops lower. If there is no pressure in the tank you might see if you can wiggle the pressure lever that makes the switch move to turn on the motor - it might be stuck.
Aug 04, 2010 | Air Tools & Compressors
Replaced the projector lamp 3 weeks ago. Reset
If the lamp is working it should be fairly obvious but stand to one side of the lens and see whether there is any light coming from the projector. If there is you know that it's an input problem. If there isn't either a fuse has gone, the bulb has blown or the filters might need cleaning. If the bulb has blown it's probably because you handled the bulb. It's vital not to touch these bulbs with your fingers. If you do wipe it with methylated spirits.
Aug 21, 2009 | Sharp Office Equipment & Supplies
Red keeps going out but there is a new bulb in place.
red light keeps blinking on and off but the tv isnt turning on
Jun 02, 2009 | Toshiba TN61X81 61" Rear Projection...
GE 52 " rearprojection flat screen picture bowing 3d effect
Thats usually a very easy repair by replacing FL231, DL231 and CL230 total parts are about 11.00 at the following link and they provide free instructions. The components are all listed under RCA parts category.
http://servicemanuals.vstore.ca/
May 16, 2009 | GE D52GW12 52" Rear Projection HDTV-Ready...
EIKI EIP 5200 won't display anything
it's overheating. clean it out with canned air. dust keeps in the heat that the projector is trying to expell. it also decreases the air flow.
Apr 28, 2009 | Eiki EIP-10V Multimedia Projector
Optoma HD70 "Fan Failure" message, PLEASE HELP!
Simply just navigate the meny system until you find the high altitude option, the switch it on
The projector should work fine now.
If you experience problems with your Optoma projector after onle 3 mnths, assuming it was new when you bought it you still have 9 months of warranty you know, you shouldnt hesitate to bother the seller
Apr 02, 2009 | Optoma HD70 DLP Projector
loose connection. possible crack on main board. needs to be sent in to have a look at.
Aug 16, 2008 | Boxlight CP 310t Multimedia Projector
Tv will not turn on
your tv needs to be repair again power supply problem or circuit.good luck.
Apr 04, 2007 | Toshiba 37HLX95 37 in. LCD TV/DVD Combo
135 people viewed this question
jasbo
jasbo
