Problem with a HP Laptop. When switched on, the screen stays black and after about a minute, the computer restarts itself (screen remains black). It just continues doing this. After a few days, the computer started working again, but this time it has not. It has done this about 3 or 4 times. Have you any ideas as to what the problem may be?
  • 144 Answers
If you are a technician, please take it to the service center. This may be a fault because of failing power supply section in your laptop/ faulty, loose RAM.
Posted on Aug 17, 2008
Why my laptop is failing to restart?
you have sleepsettings set to start button, set it to shut down.
Feb 28, 2015 | Lenovo G585 Laptop
Why does my hp laptop screen remain black when I turn it on
It may be a couple of things, inverter, backlighting, the switch that controls the display when you open and close the lid. Here is a video to help you troubleshoot the issue: http://www.youtube.com/watch?v=2Yi6GNFcP3w Have you cleaned the fan, vents, heatsink recently? Take a look at this: http://www.techradar.com/us/news/mobile-computing/laptops/how-to-clean-your-laptop-of-dust-and-dirt-942783
May 08, 2013 | Computers & Internet
Screen won't turn on/Power stays on
To do a power reset, unplug your laptop, remove the battery and hold the power switch down for 30 seconds.
otherwise it may be problem with your screen back light...
Apr 10, 2013 | HP G60-535 Laptop Notebook Netbook...
My hp laptop screen goes black after being on for a few minutes
The problem could be the backlight or its inverter is bad. IF picture remains but lights only go out. Also it is normal for the screen to go black if the laptop is not used.
If the picture itself remains on the display but it just goes dim, try turning up the brightness, if noting happens, most likely the backlight of the screen or its inverter is or has gone bad.
Would need to be confirmed in person.
If the picture does not remain on the screen and the laptop shuts off, your charger might not be working, and your battery is low.
Would need to be inspected in person.
Jun 11, 2012 | HP Computers & Internet
My HP dv6119us just started rebooting itself. Sometimes 10 or more times. The screen remains black. Once in a while Windows XP will start and everything is fine. But, most of the time when I turn it on it...
Hi
Please can you try the following
1) Switch on Laptop
2) Immediatley press the F8 key continuoulsy until a advanced start up menu is presented
3) Choose safe mode
4) Once in safe mode click Start>Run and type in msconfig
5) click the start up tab and remove all the ticks and then click ok and let the Laptop restart and see if this goes into windows
Regards
Shauqat
Sep 29, 2010 | HP Compaq nx8220 Notebook
My hp Pavillion DV6000 laptop starts up fine and after a few minutes the screen turns black. I can still see the desktop image in the background but barely. If I reboot the screen looks normal again but...
Well are 2 reasons for this behaviour of your notebook...first it can be an issue with the graphics card installed on the motheboard or its an issue with the Monitor cable which is connected between the motherboard and the LCD.
Following are the steps that you can try to resolve the problem:
At first we need to check whether its a hardware problem or not.
1.Restart the computer and tap on the F10 key for a while which would take us to the BIOS SET UP UTILITY...
2.Now we need to wait for sometime in this screen so that we can check the status of the screen whether the screen goes dim or it remains normal..
3.If the screen remains normal for around 10 minutes then its not a problem with the cable,
4.Now we need to get back to the windows screen and try installing the graphics driver for the notebook.
Let me provide you a couple of drivers for the notebook.
I am providing you the drivers assuming Windows Vista installed on the system
if you have an ATI card installed, the install the below mentioned driver:
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=us&swItem=ob-60201-1&jumpid=reg_R1002_USEN
if you have an NVIDIA card install the below mentioned driver:
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=us&swItem=vc-77961-1&jumpid=reg_R1002_USEN
or you can install the drivers directly from the manufacturers website..
Hope this works.
Regards
KEN
May 10, 2010 | HP Pavilion dv4000 Notebook
Screen goes black on my hp pavilion dv4000 notebook
Try connecting an external monitor to the laptop, power up the monitor first then boot up the laptop. The video data will switch to the monitor automatically, check if the monitor dislays a normal image and see if the image stays on the monitor.
Also press and hold the Fn key and press the F4 key, these keys toggle the video output between the LCD screen and the video port.
Test to see if this functions correctly.
Get back to me with the results of the tests.
Jun 03, 2009 | HP Pavilion dv4000 Notebook
Hp dv 2000 my screen stays black when switched on.
Check all you cables etc.. If this does not correct the problem it is most likely the video card integrated on the motherboard.
I had a dv1000 do the same thing. The bad news is the motherboard will have to be replaced.
Dec 11, 2008 | HP Pavilion dv2000t 14.1" Notebook Laptop...
Black Screen / Computer Stays in Standby Mode
Completely remove the battery and unplug the power cord for a few minutes. Reinsert battery and power up. You can also hit F8 when starting and see if you can boot into safe mode.
Sep 06, 2007 | HP Compaq Presario V2000 Notebook
Open Questions:
Toshiba Customer Care And Toll Free Number ' Dataalign 'Call +1888784-9316 Toshiba Corporation is a Japanese multinational company that is headquartered in Tokyo. It produces products and services like information technology, communications equipment and systems, electronic components and materials, power systems etc. Toshiba products are innovative and cost efficient which provides best solutions for home or business use. Toshiba has become the world's seventh largest IT Company which launched its first laptop in 1985. All Toshiba products have the best qualities like high efficiency in very affordable pricing, innovation at its best, ultra- portability with faster working laptops and desktops. As known by everyone, every Toshiba user require good Toshiba Customer Care and thus requires a good customer support. Likewise, Toshiba laptops also require a reliable support for the proper working of Toshiba laptops and desktops over a longer period of time. Dataalign provides best in class Toshiba Tech Support exclusively for the Toshiba customers. Dataalign tech support is provided by the highly knowledgeable and expert technicians who have years of working experience in this field and these tech support engineers have been particularly trained to be able to solve the issues related to Toshiba products. Toshiba Support of Dataalign has following features: 1. Slow speed issues are resolved. 2. Toshiba support technicians of Dataalign analyze the issue very carefully and follow proper trouble shooting steps to get to the real cause of issue for properly suitable resolution. 3. Blue screen of ***** and other errors are resolved. 4. Issues like virus, malware, spyware is resolved accurately. 5. Tech support experts providing Toshiba Support to the Dataalign customers have years of experience in the field of providing helpful assistance to customers with accuracy. 6. Dedicated staff with lots of knowledge makes the support team of Dataalign the best. 7. Customer satisfaction is taken care of every time. 8. Highest productivity is ensured after services to Toshiba laptops. 9. Resolution is provided over remote access so that Toshiba customers can witness the issue and the overall process of resolution applied. 10. Toshiba Customer of Dataalign works 24/7 and 365 days a year. For any kind of help in Toshiba products contact on the Toshiba Tech support number of Dataalign :- +1888784-9316
Jun 22, 2018 | Toshiba Computers & Internet
Computers & Internet Logo
37 people viewed this question
David Payne
David Payne
