Question about Refrigerators
The rubber around my refrigerator door has lost the magnetic closure. Can it be replaced and what would an appoximate cost be. Thank you
  • mlli Aug 17, 2008
    Thank You. I will try that. ML
  • Anonymous Mar 14, 2014
    I need a door handle and rubber magnet for my refrigerator.
They sell replacement parts online, depending on the year it should cost you less than to replace it by far
Posted on Aug 17, 2008
Old whirlpool upright freezer. door left slightly ajar.light on inside. Rubber around door warm. won't seal.some things starting to thaw.shut door.should I do anything else
Seal needs to be replaced around door. Make sure magnetic strip is tight against sides of refrigerator, even if you have to cut the outside so it lays flat against the sides.
May 03, 2015 | Whirlpool Freezers
The bottom freezer door has lost its magnetism
Believe it or not you can fix this easily by giving the rubber gasket a good cleaning with a simple solution of baking soda and water.
They tend to lose their "magnetism" over time as they get dirty.
Oct 12, 2009 | Bosch Exxcel KGV35421 Bottom Freezer...
Replace seal
Take the door off. You will find a 1/4" screw every 3" to 5" all the way around the door. Remove every one of them. It amy take a couple trips around to get all of them. Before you attempt to install the gasket, soak it in hot water for about an hour (while you are removing the old gasket). This will soften the rubber so that you can work with it. After you have replaced the gasket and re-installed the door. Take a rag soaked in hot water and wipe it slowly around the gasket. This will warm it again. Now take Vaseline and smear a small amount all around the gasket. Close the door and let sit for 15 to 20 mins. Now take a dollar bill, open the door and close it on the bill so that a end of the bill is sticking out. Now pull the bill out slowly. The gasket should have a snug grip on the dollar. If not re-heat it then close the door so that the magnet will pull and stretch the gasket until it touches the box. Do this all around the door to insure that the rubber of the gasket has expanded and allowed the magnet to reach the fridge case. If you take your time, you should have no problem. Good luck
Please rate solution
Sep 07, 2009 | Candy CPCA270FFK Bottom Freezer...
Fridge Condensation
Check the seal of the rubber gasket, if there are improper seal of the magnet, pour hot water along it to soften the rubber. (be careful when handling hot water). When the rubber is soften, try to stretch it a little by pulling it. close the door and the magnet will keep the seal in place.
May 09, 2009 | LG LRFC25750 Refrigerator French Door
Moisture on the door hinge seal of french door model MF12569VEM.
You can use cooking oil or wd-40 to go around the rubber seal of the door especially near the hinge to make sure it has a tight closure
Dec 10, 2008 | Maytag MFD2560HES Bottom Freezer French...
Door on Monogram ZIR36N won't pull closed and stay shut
The spring is actually a door closure , are the wheels that the bar closure mechanism goes through and attaches to the spring moving freely? It is entirely possible that a bin in the fridge is keeping the door open.
Nov 14, 2008 | GE ZICS360NMRH Monogram® 36" Built-In...
Door not closing
Usually the gasket does not lose its qualities; I would check along the hinge line, to see if the gasket has pulled loose, and is causing the binding. It can be poked back into place, or glued (only on the door side).
Sep 05, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Sub-zero Refrigerator Door
song to me door gasket was not properly installed, We using electric steamers to make rubber softer and good sticking. Right after door seal was replaced. Also, it could be that: a bottom door hinge parts broken /little white plastic cams damaged/,or, fridge not leveled or too heavy load on door shelfs.
________________________________________________
http://www.subzerolosangeles.com
Jun 27, 2008 | Sub-Zero 661/F Side by Side Refrigerator
Refrigerators Logo
135 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
