Question about Samsung SyncMaster 173P 17" LCD Monitor
Message on monitor screen= "No Connection - Connect Signal Cable"
After turning off the computer and cleaning out the dust in the CPU, we reconnected everything and now the monitor is giving us the above message. We cannot find our manual. What do we need to do to get the monitor up and running again? We would like to use it in digital mode. Thanks.
  • Samsung Master
  • 5,569 Answers
This message is pretty standard and translates into: "I'm fine but your cable or video card isn't."
You may have dislodged the video card while cleaning or possibly bent one of the fine pins of the video connector.
Check the seating of the video card, pulling it up slightly and pushing fimly back into the slot (sometimes the contacts aren't contacting) and then the video output connector.
Pull the latter and examine it carefully for bent pins, not missing ones since not all pin positions are used and those may be empty.
Posted on Aug 17, 2008
SOURCE:
Whats the problem with no picture on the monitor but the cpu is working
Can you observe any LED lights on the monitor panel when you try to turn it on. If no then check your power cables. If you can see the LED lights but screen does not show try to unplug the VGA/HDMI cable and clean it by blowing air through the plug and then reconnect it. Also try to turn on the monitor without connecting it to the monitor as this will verify if the monitor is OK because if it is it should display a message to check the input signal or no input signal is detected. If it does and you are still not having a display then the problem is probably in your CPU and more specifically in the VGA card.
Sep 23, 2013 | Samsung Computers & Internet
Monitor keeps shuting down
what do you mean by "computer starts"????? plz write full detail. first remove your monitor cable from your cpu cabinet. if you are able to see "no signal" message on screen then your monitor is working. if you aren't seeing anything on your screen then there is some problem with your monitor. there also may be problem with your VGA connection (VGA or D-Sub wire). remove and reconnect this wire from both end. first reconnect it from your monitor and then from your video card. if it dosen't fix then you have to check that all led's are glowing on your cpu cabinet or not. if only power led is glowing and other led's always remains off, then there may be problem with your video card or ram or hdd. first open your pc case, then if you have video card, then remove it and put it again. reconnect your hdd sata wire. remove your ram and place it again. if now also not showing anything on your screen, then there is problem with your motherboard bios.
Apr 10, 2013 | Computers & Internet
Screen will not stay on, getting message no input signal
The message input signal means no signal is being feed to the monitor.
Check the cable use to connect the monitor to the video card.. fix and secure the connection.
If the computer is reading and you know its working, check the video card.
Turn off the CPU disconnect the video card from the motherboard and reconnect.
Try to open your CPU and see if it reacts with your monitor. If nothing happens replace your video card
May 18, 2010 | HP Vs17 17" LCD Flat Panel Monitor
The screen will not turn on, i have a blue flashing light, but it seems to be on continuos standby
remove the connection of your monitor from the cpu then wait if some message will appear on the screen it goes like:1. power saving mode check cable, 2. no signal. if this appear better check the cpu.
Sep 09, 2009 | Computers & Internet
Whenever i turn on my pc it says no input signal.i dont know whats wrong with it.is it the motherboard or the hard drive?
When you power up the cpu check your smps is working?
Then check num lock key on key bord if it is on and off when you press numlock then your cpu gives dispaly to monitor ok.
but if it not constant on or off no change when you press num lock key then you have to open cpu cabinet.
Refix RAM memory .
Clean dust from motherbord chipset.
Pull out cmos cell for 15 minutes so bios settings are reset to defaults.
then check.
refix all connection to mothebord like ATX power supply from smps.
Jul 23, 2009 | HP Pavilion a1540n PC Desktop
Monitor beeps when turned on no picture
disconnect signal cable if monitor show massage no signal check signal cable then monitor is ok then open cpu check whether dust is in ram then clean the dust and again fit the ram the problem will be solved if not then disconnect ram listen beep and if contineus beep comes then motherboard is ok if no beep then motherboard is faulty replace it
Nov 26, 2008 | NetTV DTV 34XR 34" CRT Monitor
MONITOR NOT COMING ON . RGB NO INPUT SIGNAL .
You first take post( power on self test) connect power cord & disconnect signal cable you will see massage no signal check siganl cable then problem will be in cpu this problem may be solved by cleaning dust in cpu if montor shows no display then problem will in monitor open it check o/p of smps if not disolder path of eht if o/p comes then eht is faulty replace it
Oct 28, 2008 | Computers & Internet
Screen black
Take the post (power on self test) disconnect vga cable and connect power cable if monitor shows no signal check signal cable massage then monitor is ok fault is in cpu. open it and clean the dust
by vaccum cleaner you will get the display again
Oct 17, 2008 | X2Gen MG19MY 19" LCD Monitor
I have a pavillon a6421 uk hp computer when i turn it on the monitor comes up with no vga signal (i have changed the graphics card and it is still the same) have done all the trouble shooting options...
Hi
First Check the power cable of ur monitor whether power is coming or not..
Then remove signal cable (which is connect the cpu) and then switch one the power, check whether any msg is coming in screen.(like no signal or no connection) if it comes means u want to check the cpu or else their is problem in ur monitor..
Connect the another monitor with ur cpu.Whether ur cpu is working properly..
Sep 19, 2008 | Computers & Internet
Monitor signal cable troubleshooting
hi, there is some loose contact in the connection. Take out the cable end from the VGA socket and check the pins inside the socket for any bend inside the socket. Reconnect it, tight the connector with the socket bolts. If not solved, try for any loose solder or wire breake.
Thank you
Jun 23, 2008 | IBM E74 17" CRT Monitor
Samsung SyncMaster 173P 17" LCD Monitor Logo
175 people viewed this question
Top Samsung Computers & Internet Experts
Ekse
asber
RONALD CARTER JR
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
