Question about Nokia N95 Cellular Phone
N95 8g hi h r u 2day???i have a big problem whith my phone i cant call anyone and no one can call me it said call barring activated call restriction how can i get that password from u guys its really very bad ive been use dis phone only 1 and half month only if u can help me plzzzzzz 10x anyay
    Sergeant:
    Champion:
  • 281 Answers
You have to know that you have the warranty for it for 1 full year.
Posted on Aug 18, 2008
SOURCE:
Call barring password for Nokia 2730
Hi,call barring - Enables you to restrict or bar certain or all types of calls to and from your mobile phone, i.e. outgoing calls, outgoing international calls, incoming calls. Barring is activated with a personal code.
Call barring is a mobile phone feature that allows the user to set certain prohibitions on incoming or outgoing calls. This is an effective means to prevent the phone being used to make expensive international or premium rate calls, particularly when the phone is to be used by people other than the subscriber.
Many companies that provide handsets for business use now employ call barring as a security measure, to control their use and restrict calls to pre-approved numbers. The user's personal code must be used to activate this feature.
How do I get it?
Contact your local Service Provider. You will need a four digit barring code. Initially this will be 0000. You should create a personal barring code for security. Please consult your cellphone's instruction manual.
What does it cost?
This service is free.
Also you can deactivate it from your cell phone..
Different cell phones have different setting functions,
You can try these out. It's the general way to deactivate call barring (NOKIA) .
Follow the below instruction:
Go to Menu,
Enter settings,
Scroll to Security,
You will see call barring on that list,
Click on it,and scroll to last option and you will see cancel call barring.
Your cell phone might not be the same with these functions,but the procedure are aways the same..
Good luck.
Jul 18, 2011 | Nokia Cell Phones
Cant receive a call from my motorola e8
Hi try this steps..go to menu of yuor phone..select phone setting.Call barring must be NO.or deactivated..Call Barring means restricting an incoming or outgoing calls..
Jun 19, 2011 | Motorola Mobility ROKR E8 Cellular Phone
Call restriction activated on incoming and outgoing calls how to lift call restriction
Try this
Go to Settings>Calling>Call Barring
Press Option and select deactivate all barrings
But a notification will appear to contact your service provider.
You can ask them the barring code or let them deactivate it
Apr 27, 2011 | Nokia 5800 XpressMusic Smartphone
I have a nokia 2730c, my number is currently barred, do you know what the code for cancelling the barring? Thank You
hi,
Before you can activate these barring services you will need a barring code from your service provider. Call Barring can not be activated if Call Forwarding diverts are already in use.
To Activate: * 330 * BARRING CODE # [SEND]
To Cancel: # 330 * BARRING CODE # [SEND]
To Check: * # 330 # [SEND]
All Outgoing Calls
To Activate: * 333 * BARRING CODE # [SEND]
To Cancel: # 333 * BARRING CODE # [SEND]
To Check: * # 333 # [SEND]
All Incoming Calls
To Activate: * 353 * BARRING CODE # [SEND]
To Cancel: # 353 * BARRING CODE # [SEND]
To Check: * # 353 # [SEND]
All Outgoing Calls
To Activate: * 33 * BARRING CODE# [SEND]
To Cancel: # 33 * BARRING CODE # [SEND]
To Check: * # 33 # [SEND]
All Outgoing International Calls
To Activate: * 331 * BARRING CODE# [SEND]
To Cancel: # 331 * BARRING CODE # [SEND]
To Check: * # 331 # [SEND]
All Outgoing International Calls Except To Home Country
To Activate: * 332 * BARRING CODE# [SEND]
To Cancel: # 332 * BARRING CODE # [SEND]
To Check: * # 332 # [SEND]
All Incoming Calls
To Activate: * 35 * BARRING CODE # [SEND]
To Cancel: # 35 * BARRING CODE # [SEND]
To Check: * # 35 # [SEND]
All Incoming Calls When Outside Home Country
To Activate: * 351 * BARRING CODE # [SEND]
To Cancel: # 351 * BARRING CODE # [SEND]
To Check: * # 351 # [SEND]
Canceling All Call Barring # 330 * BARRING CODE # [SEND]
i hope it will help you...
Apr 13, 2011 | Nokia 2730 Cell Phone
Call barring on my blackberry 8900 is saying barring not available how can i fix it?
there is a way to stop the call barring.When call bearing is activated on the phone, it restricts all out going calls on the phone but you can receive calls.
You need to deactivate it so that you can be able to make out going calls.
Type in the code to deactivate call barring #33#0000# to deactivate.But if you want to activate it back for some one else not to make use of the call credit on your phone you can activate it by dialing this code *33*0000#.
Take care.
Mar 15, 2010 | Cell Phones
Hi, i have purchased a nokia E71 on Ebay which was described as unlocked.After recieving phone i put in a Vodaphone prepaid sim only to find call barring was activated.I then contacted seller to find he...
Hi
the default is 0000 or 1919 or 1234
Call barring
Call barring (network service) allows you to restrict the calls that you make and receive with your phone. To change the settings, you need the barring password from your service provider.
  1. Select Menu > Tools > Settings > Call barring.
  2. Scroll to the desired barring option, and to request the network to set call restriction on, select Options > Activate. To set the selected call restriction off, select Cancel. To check whether the calls are barred, select Check status. To change the barring password, select Edit barrings passw.. To cancel all active call barrings, select Cancel all barrings.
So try contacting your Vodaphone customer service and ask for the call barring code, see if it opens up with a code that they give.
Aug 30, 2009 | Cell Phones
DONT EVER BUY CECT A88 IPHONE!! hi, can anyone help me to to deactivate all of my call barring. i bought a cect a88 few months ago. i've had this problem twice now, i cant make a call out nor receive any...
It's possible if you are on a limited call monthly contract thatwhen you run out of call time it bars your calls and when your contract renews every month you have call time so the barring lifts. If this is the case then it is nothing to do with the phone. call your network and see if you can add an option to make extra calls that are added to your bill.
Jul 07, 2009 | Dual Electronics CECT P168 Cellular Phone
N95 8 g
you will need to master reset the phone to take that feature off....or just take it into a mobile service center to have it done for you.
Aug 18, 2008 | Nokia N95 Cellular Phone
Gprs settings
Have you Enabled the GPS by Clicking the main Tool bar at your Home screen
Jun 29, 2008 | Motorola Mobility MOTOROKR E6
How di remove call barring from nokia 5500d
Call barring
1 Select Menu > Tools > Settings > Call barring.
2 Scroll to the desired barring option, and to request the
Call barring and call diverting cannot be active at the same
time.
When calls are barred, calls still may be possible to certain
official emergency numbers.
Apr 09, 2008 | Nokia 6288 Cellular Phone
Nokia N95 Cellular Phone Logo
32 people viewed this question
Top Nokia Cell Phones Experts
jonathan mariano
jonathan mariano
Ekse
