Question about Haier HC61FBB Beverage Cooler
Temperature not even and cans freezing and bursting
Hi
I have a Haier Beverage Center-the model is HC125FVS-It always freezes up in the back and has a coating of ice and the temperature inside is very uneven-the cans on the 2nd to bottom rack are the coolest while the others stay "tepid". I have tried many various temperatures from 3-6 with no success. Some of the cans get so cold they actually freeze up and burst while the others stay warm-can you tell me what might be wrong with it?
  • dougschulze Oct 01, 2008
    I have the exact same problem.
  • 236 Answers
SOURCE: Freezer fan is not working
the fan may be jammed due to ice build up. in the first instance i would give the unit a full defrost for 48 hours then see if the fan starts after, if not the fan motor may be u/s.
Posted on Jun 02, 2007
jgwhomeequip
  • 1902 Answers
SOURCE: Temperature gets and stays around 40 degrees then back freezes up
Have you checked the fins in the back to make sure that they are clean and not clogged with dust. If you have or you do not have any then your compressor is bad and you are best just throwing it away. If you have fins back there, use a spray bottle with hot water and put a towel under it and just spray and spray and spray until you can see through it with a flash light
Posted on Feb 08, 2009
jmgldsmth
  • 1906 Answers
SOURCE: MY REFRIGERATOR IS NOT GETTING COLD OR FREEZING LIKE IT'S SUPPOSE
check your evaporator (freezer) fan
Posted on Jun 13, 2009
hunter19_46m
  • 7482 Answers
SOURCE: my refrigerator haier hte21waaww doesn't work, just the frezzer,
1...Check the fan that pushes the air from the freezer to the refrigerator it could be defective, if it is it will cause this type of problem. 2...Check your thermostat and make sure it is on the colder setting. I hope this helped you, Please rate me...Thanks
Posted on Jan 05, 2010
  • 670 Answers
SOURCE: My fridge keeps freezing everything
To raise the temperature of the refrigerator you set it to a higher number.
Posted on Nov 06, 2010
Haier minifridge freezing everything
My mini-fridge did a similar thing, until I realized that managed to put on the wrong temperature knob. It was technically backwards. They may have done this to you. I mean, it is a longshot, but try putting it on the highest setting to see if that helps. If it does not, you're most likely dealing with a faulty knob that's not actually changing the settings on the thermostat.
Apr 10, 2014 | Haier Refrigerators
What kind of light bulb for haier beverage center model hc125fvs
Just take out the bulb and go to Wallmart and match it up. They have a wide variety, long tube bulbs etc.
Apr 08, 2014 | Refrigerators
Need beverage cooler to be colder
it probably has a leak & needs freon. in most cases there are no ports to check the freon level. you will have to add them. if you dont know how to do this it will be cheaper for you to go buy a new one vs. paying somone to fix it.
Oct 15, 2013 | Haier HC125FVS Wine Cooler Beverage Cooler
Refrigerator freezes water and cola drinks inside it
have the thermostat checked as it appears that it has stopped controlling the temperature you set to
Jun 16, 2013 | Haier Refrigerators
I have Model: DM30A which constantly freezes up even though it is on a three foot high table and the temperature never goes below 60 degrees
The unit freezing up doesn't surprise me at all. If the temp in your room is 60 degrees then the temperature of the air will be around 40 degrees and the coil is about 20 degrees. Your expecting to much, the tempature is to cold to work properly.
Jul 08, 2011 | Haier Dehumidifiers
I have a Haier HC125FVS Wine Cooler that has stopped cooling. The compressor hums but will not start. Is the starter #6R8MC a two piece part? I have unpluged the black part with that number, but there is...
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator
Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Feb 25, 2011 | Haier HC125FVS Wine Cooler Beverage Cooler
I am getting frequent frost build-up on the inside back wall. I have been told by RepairClinic.com to check the DEFROST TIMER. Where is it located? I have already checked behind the light cover and on...
llok in the back by compressor . also if the wirign sch is on unit find the wiring and folow to it .. repair clinic is on the right track and when you find it and replace it problem over .. it 's not hard to find . .. mm
Aug 17, 2010 | Haier HC125FVS Wine Cooler Beverage Cooler
I was defrosting my fridge and punctured the tube
might be possible, depending where exactly the puncture is, but if it was repaired it would need
regassing to the correct level, you would need a professional refrigeration engineer,
Dec 12, 2009 | Haier HC125FVS Wine Cooler Beverage Cooler
Is clicking on and off but does not cool or run
Sounds like an "overload and relay" on the compressor. This is the equivalent to a starter on a car. When they go bad, the compressor just does a "buzzzzz.. click" about every 5 to ten minutes. In the worst case, you may have a bad compressor, but this is less common. Hope this helps!
Dec 06, 2009 | Haier HC125FVS Wine Cooler Beverage Cooler
There is a tiny hole in the inside back and the freon gas leaked, is this repairable?
Hi:
It should be repairable. You would need a Heating/ Air Conditioning repair shop to silver solder the hole closed, and possibly sweat on a valve to evacuate and refill the system. I would call around and ask if the shops do this sort of thing. I had a similar repair done on a window air conditioner, and it saved me money!
Nov 17, 2009 | Haier HC125FVS Wine Cooler Beverage Cooler
Haier HC61FBB Beverage Cooler Logo
42 people viewed this question
Top Haier Refrigerators Experts
John Tripp
John Tripp
doggzzz
Level 1 Expert
Vernon Taylor
Are you a Haier Refrigerator Expert? Answer questions, earn points and help others
