So far this service sucks!!!! - Computers & Internet
  • LouieLiuag Aug 17, 2008
    Why am I required to sign on after the three steps have been activated for sign on from previous sign on?
  • andrew pester
    andrew pester May 11, 2010
    why,what is your post relating to?
    President:
  • 2,961 Answers
Sorry can't comment, i'm on the recieving end from you
Posted on Aug 18, 2008
Hoover Winddtunnel
We had one of those and it did the same thing, it just stopped. It was a fault with the lead. I had that replaced for $38, cleaned it and gave it to Goodwill. Then we bought a Dyson.
It is very unlikely that it sucking something up would jam it to the point of stopping. Your best bet is to take it in for service. You can remove screws and take things down so far, but I doubt you have the expertise to diagnose an electronic fault. They all have overload and overheat protection.
Apr 28, 2016 | Hoover Vacuums
Can somebody tell me what problems to expect from a faulty cts
CTS , old name is modern name ETC (1996 +)
they can fail 3 ways, and 3 symotoms
so what ask that?
ok ill bite.
1: open, the CEL glows, ecu goes to limphome low power and sucks fuel like mad.
2: shorted, same.
3: is out of calibration called biased.
3a: biased cold , EFI never leaves warmup mode, sucks fuel.
3b: ;biased hot, EFI goes to hot state too soon, and bogs cold.
how is that.?
there is far more, but that far more is all keyed off or
IM HOT , (egr wakes up and lots of things)
or not. like idle controls dead.
Aug 04, 2014 | 1991 Jeep Cherokee Limited
My email return path is not correct... there is a mispelling instead of eircom.net it says eicom.net. how can I fix
Can you try their Customer Service? They would be the ones to help you on this. I know how frustrating not getting your mail back. Another thing you could try, if you're not too far along with this program is go to Yahoo mail. It's free and really nice. It sucks changing addresses, but in the long run you'll be grateful.
Mar 29, 2010 | Computers & Internet
Best HP black cartrige for the money. r the
Don't waste your money on the refills....the electronics on these are only good for about three refills and then the printer will refuse to recognize them and you will be out the cost of refill and not be able to print. Sometimes you get lucky and get one that will last the whole time but that is few and far between. It sucks but new is by far better.....depends on how much you use. The triple pack at Costco is by far the best buy....IMO
Dec 13, 2009 | HP Deskjet F335 All-In-One InkJet Printer
I have a 89 pontiac firebird Trans Am "GTA" 5.7L tuned port injected. About a week or so ago I changed the TPS. I started the car and it was sounding great and then it sounded like something got sucked...
If something did indeed get sucked in, it is probably stuck to the piston, comes loose, gets stuck, comes loose. To check this go to your local parts store and see if they have a bore scope for rent, so you can see into the cylinder from the spark plug hole. If you cannot get the tool, you may have to remove the cylinder head to check.
Sep 11, 2009 | 1989 Pontiac Firebird
Error code f9 on self cleaning range.
I get a f9 message when I turn my oven onto clean and then it shuts off and goes to clock...what's the problem
Oct 01, 2008 | Frigidaire PLEF398AC Electric Kitchen...
I have a dyson that is picking up just fine when on vacuum mode, however when I try to use the suction tube there is no suction at all. It is not blocked and the canister is empty. Help!
Hi, I have an upright DC03, brilliant machine. Mine wouldn't **** and had the following symptoms;
- it sucked ok from the top hole where the canister joins the unit - with the canister the dust didn't spin aroun inside the canister like it normally does and there was no **** at the hose end or brush end. - with the top of the canister attached (the cyclone) but not the bottom it sucked through the cyclone - the small valve on top of the cyclone unit was sucking heaps
this indicated to me the machine was sucking through the cyclone unit but when the canister was put on it was blocked - hence the tremendous sucking through the valve on the top of the cyclone. As far as I could see the cyclone wasn't blocked so I poked some wire down the tube inside the machine that runs from the bottom of the unit (where the hose sits) up to the bottom hole where the canister joins.
The DC03 has 2 holes where the canister attaches, it seems like it sucks air through the top hole, through the cyclone and through the lower hole sucks the dust up this inner tube into the canister. Check that tube, shine a torch from the top hole and you should be able to see the light at the bottom. Make sure you clear it completely.
Mine was very very blocked. I kept poking and removing dust until I could see light at through the tube. Works fine now.
Hopefully this helps someone as it took me awhile to work it out.
Good luck
Aug 12, 2008 | Vacuums
Service required
I seem to have fixed my own question. Thanks to the "silly girl" pressing buttons. On the Epson Stylus Photo RX600 try pressing the stop button, color button, B&W button and the On button all at the same time. It starts up without that fatal red indicator with a message saying the ink tray has been emptied. Press the OK button and things are back to normal, I hope!
Dec 01, 2007 | Epson Stylus Photo RX600 All-In-One InkJet...
HOOVER SPINSCRUB WONT SUCK UP WATER...BLOWING AIR OUT
ITS THE DUCT PIECE ON THE FRONT OF THE DIRTY WATER TANK (DWT). ITS NOT LINED UP.
1. TAKE LID OFF OF DWT
2. SLIDE THE LITTLE SQUARE PIECE (5'X5'X1) (THE DUCT) ON THE FRONT OF THE DWT AS FAR UP AS POSSIBLE AND IF IT BENDS FORWARD FROM THE TOP, DO THAT TOO (SOME MODELS OPEN LIKE A DOOR TOP DOWN, OTHERS JUST SLIDE UP AND OUT COMPLETELY)
3. SLIDE THAT DUCT BACK DOWN AS FAR DOWN AND BACK AS IT WILL GO.
4. PUT THE LID BACK ON BY HINGING THE FRONT LATCHES ON AND THEN SNAPPING THE BACK SIDE DOWN.
5. CHECK TO SEE IF THAT DUCT PIECE ON THE FRONT IS LOOSE BY PUSHING ON IT AND SEEING IF IT MOVES UP AND DOWN.
IF IT IS, THE LID ISNT COMPLETELY ON, GO BACK TO STEP 4.
IF THE DUCT IS SNUG, CONGRATS YOU SHOULD HAVE JUST MADE YOUR STEAM VAC **** UP THE WATER AGAIN
Oct 21, 2007 | Hoover SteamVac F5914-900 SpinScrub...
Filter sucks against top creating low suction
Beckyanneok,
See my post with the same problem (described in painful detail) at:
http://www.fixya.com/support/t329235-no_vacuum
I've no idea why this should happen all of a sudden. But it has. And so far nobody is suggesting anything.
Don.
Apr 30, 2007 | Hoover Floormate H3000 Upright Wet/Dry...
Computers & Internet Logo
Brian Sullivan
Brian Sullivan
David Payne
David Payne
