Question about Samsung HLN5065W 50" Rear Projection HDTV-Ready Television
No Volume ON the volume menu there is a picture of headphones, no sound. there are no headphones connected and ive checked every button and menu. ive turned it off at the mains, still no sound. whats the crack?
  • Katie Williams Oct 13, 2008
    I have no sound on my Samsung plasma tv, there is a picture of headphones on the volume bar. No headphones have ever been put into the tv.
    Genius:
  • Samsung Master
  • 1,550 Answers
The earphones input are in bad conditions you need to change it,or try put in the earphones and put out until the picture of the earphones go out.
Posted on Aug 17, 2008
Hit a button on my remote and now theres no sound
check the simple things first:
set or a box if used not muted or volume turned low.
In set menu speakers switched ON or OFF?
on remote check for MTS, or SAP, or such.
If set has hookup for external speakers check if set internal or external.
If set has headphone jack does it have sound with headphones?
If a DVD player etc connected to rear inputs has sound--problem is not audio circuit but a setting somewhere on the set or a box if used.
Let me know what you find and if need more help make a comment here.
May 03, 2012 | Coby Televison & Video
Tip
How to Troubleshoot a Mac Computer With No Sound
When troubleshooting sound problems on Macs, you can find thefix quickly if you isolate the possible problems first. Regardless of youroperating system, it will make things easier if you can narrow down thepossible points of failure by momentarily unplugging any sound devices.Following simple change of sound settings and testing internal sound alerts canfix the problem.Instructions<br />1.<span> </span>GeneralTroubleshooting<br /> <ol> <ul> <li>1 </li></ul></ol> Launch iTunes or another media player applicationand have it play continuously to start troubleshooting. Make sure the volume isnot muted or disabled. Move the volume slider on the menu bar up and down. Youcan also use the keyboard's Increase and Decrease volume buttons (usually F4 todecrease and F5 to increase the volume). <ol> <ul> <li>2 </li></ul></ol> Unplug any headphones that might be connected toyour computer's headphones port. If your <a href="http://www.ehow.com/computers/">computer</a> has internal speakers,unplug any external speaker plugged to the audio port to isolate the problem.Check if sound is working properly through the internal speakers. <ol> <ul> <li>3 </li></ul></ol> Go to System Preferences on your Mac menu. Clickon the ''Sound'' icon, under the Hardware section. The Sound settings pagedisplays three main buttons: ''Sound Effects," ''Output" and''Input." Click on the ''Output'' tab. Select the ''Internal Speakers,Built-in Output'' option, and raise the ''Output Volume'' at the bottom of thatwindow. Check if sound is working properly. <ol> <ul> <li>4 </li></ul></ol> Go to the ''Sound Effects'' tab, and make sure the''Alert'' and ''Output'' volumes are up and not muted. Select ''InternalSpeakers'' from the ''Play alerts and sound effects through'' drop-down menu.Click on any of the Alert Sounds in the left column and test to see if theysound as you change from one to the other. Check if sound is working properly.2.<span> </span>GaragebandTroubleshooting<br /> <ol> <ul> <li>1 </li></ul></ol> Launch GarageBand. A default piano track willappear. If it doesn't appear, click on the ''Track'' Menu and select ''NewTrack''. Choose a Software Instrument from the dialog box, and then choose aPiano from the selection of Instruments. <ol> <ul> <li>2 </li></ul></ol> Click on "Menu." Select ''Preferences''and click on the Audio/MIDI tab. For Audio Output, and Input select thecorresponding ''Built-In Output'' and ''Built-In Input'' from the drop-downmenus. Confirm the action. <ol> <ul> <li>3 </li></ul></ol> Click on the Piano track. Under the ''Windows''menu bar, select the ''Keyboard'' option, or press [ Command + K ]. A keyboarddisplays. Click on any of the keyboard keys. You should hear sound coming outof your internal speakers.<br />Make sure there is no headphone jack inserted in the computer. If sound doesnot work, try quitting the application and launching it again. <ol> <ul> <li>4 </li></ul></ol> If any of the previous steps do not fix the soundproblem, reboot and try again. <br />If you see a Disabled Volume alert when you try to raise the volume, alsoreboot. This is a known bug in Macs
on Jan 21, 2011 | Computers & Internet
No sound, neither speakers nor headphone jack
Here are a few things to check and try, as suggested from TEAC:
  1. First, make sure the Tape monitor or adapter switch(s) are not accidentally left on.
  2. Check that the speakers and components are connected
    securely.
  3. Adjust the volume by turning the VOLUME knob.
  4. Check the operation of the connected component.
  5. Select the proper source using the SOURCE button.
  6. Pull out the headphones plug from PHONES jack.
  7. Speaker impedance may be less than prescribed for this unit.
  8. Turn the power off and reduce the volume.
  9. If muting is on, press the MUTING button.
  10. Another solution for you would be to take it to a service shop for a repair cost estimate.
Feb 23, 2011 | Teac Audio Players & Recorders
The screen is working perfectly fine, you can the see the image & all the channels, but the thing is that you can't hear anything at all. what should i do?
some tvs have a stick like button at the back.. check if yours have it and move it to the opposite side..
its hard to help when you dont have model number..
Oct 23, 2010 | Craig Televison & Video
The speakers wont work no sound
This article contains tips for resolving sound related issues in Windows XP.
No Sound From all speakers
  • Check that the speakers are powered on.
  • Check that the speakers are connected to the correct ports on the PC. This is particularly important If the customer has both integrated sound and a sound card.
  • If the speakers have a volume control button - ensure that this is turned up.
  • Check that the Windows Audio service is running. If this is not running then many of the subsequent troubleshooting steps will not work. Go to Start->Run and type services.msc. Double cliick on Windows Audio. Select Start if possible and check that the Startup Type is Automatic. Click OK.
  • If the speakers are digital speakers then try forcing the sound card to use digital. Go to Start->Control Panel->Sound and Audio Devices.. On the Volume tab, click the Advanced button in the Device Volume section. In the Volume Control window, below the Play Control Volume slider, click Advanced. If this does not show select Advanced Controls from the Options menu. Select Digital Output Only
  • If possible try an external audio source like a Walkman, CD, or MP3 player (connect the speakers to the headphone jack)
  • Check that the volume control in Windows isn't muted or turned too low. See the screen shots below. Go to Start->Control Panel and double click on Sounds and Audio Devices.
Aug 10, 2010 | Logitech V20 Computer Speakers
Very low volume
Change your audio settings to headphones :)
Mar 08, 2010 | Skull Candy Lowrider Headphones
I can't get the sound to come on. When I mash the volume button i
You gave no brand and model, but some general possibilities. Check the menu in the audio/sound options. Be sure the speakers are "ON" as sometimes they get inadvertently switched off. Some models have a manual speaker switch in the back. Also if this has a headphone jack this could possibly be causing the prob. The jack on some combos can go bad. Plug in a headphone and see if you have audio. Turn down the level, however, to avoid hurting your hearing. If you have audio with phones then unplug the headphones and it may bring the sound back. If not the jack may need replacing.
Nov 25, 2009 | Televison & Video
Volume problems on my Apple MacBook
Hi, Sorry you are having problems,
If I understand you correctly, you have your headphones plugged into the MacBook and are expecting sound to come out of your speekers ?
Well, if that is the case, you must know that the mac will automatically cut the signal to the speekers as soon as headphones are connected.
Now if you are saying that you connected the headphones to test it and found that whe you changed the volume, you could hear the change on the headphones, but when you unplug your head phones, you do not notice any sound difference on the speakers.
SO let's say that is the problem. First thing to always do, of course, is a full shut down and a clean start up with no headphones installed. Once you have booted up, try it again....
If it still does not work, go into your sound preferece pane in the system preferences and change some of the settings, like muting the sound and clicking the button that allows for showing volume in menu bar, unclick options go into the tabs go clicking and unclicking things... then quit and then go back into the sound preferences and set it the way you want, sometimes shaking it up a bit gets it back on track...
Good luck.
Apr 02, 2009 | Apple aluminum 13-inch MacBook laptop-...
No sound_RCA_model L23W10_Only Ear Phone Jack Provides Sound
Hello... I found the following in the user manual for this TV. Also, some RCA models have a speaker switch on the back of the TV. If none of this solves the problem, your TV may need service. I hope this helps...
Sound problems, picture okay
• Maybe the sound is muted. Try pressing the volume up button to restore sound.
• If using S-Video or Y Pb Pr, remember to also connect the component's left and right audio output jacks to the TV's AUDIO jacks.
• Make sure the Volume option in the Sound menu is turned up.
• Make sure headphones aren't connected to the headphones jack.
Nov 17, 2017 | RCA L23W10 23 in. LCD Television
No sound when on pc mode
Check if your PC can play audio on some other speakers or headphone. If yes, check your monitor audio cable connections. If no something's wrong with your PC audio drivers. Try re-installing them or could be a hardware issue with your PC. Get it checked.
Sep 29, 2007 | Samsung SyncMaster 940MW 19" LCD Monitor
Samsung HLN5065W 50" Rear Projection HDTV-Ready Television Logo
57 people viewed this question
Jerry Greenberg
Jerry Greenberg
