Question about Pioneer Audio Players & Recorders
No sound at all from poineer vsa-ax10, not even through headphones- have tried the obvious stuff to no avail
    Genius:
  • Pioneer Master
  • 1,550 Answers
The audio amplifier IC maybe are damaged you need to replace him
Posted on Aug 17, 2008
2004 acura tl 6speed standard. VSA light/triangle light/parking brake light come on.
your vsa is vehicle stability assist that works with the abs system, verify brake calipers for proper functioning, sounds like breaks stick and cant return efficiently after breaking, vsa is a traction control light, if both lights remain on without flashing, those systems are disabled due to a problem, scan vehicle for possible abs sensor malfunction
Jan 06, 2017 | Acura Cars & Trucks
IPad stuck on headphone mode
Try power down iPad and see if it reset to default setting if not go to setting icon and go through your setting options.
Sep 01, 2015 | Apple iPad 2 Wifi 16GB
I have a 2008 Honda accord and a yellow light is on that's a triangle with exclamation point in it and a yellow light that says VSA is on what do they mean
2 seconds on any search engine will give you the answer to all of this. Buuuut...VSA:Vehicle Stability Assist.
The indicator light with the triangle staying on permanently is telling you that stability
assist is NOT currently active. It has either been manually disabled via
a button inside the cabin which is probably labeled..."VSA"(real confusing stuff
here), OR the system is malfunctioning due to a mechanical or
electrical problem and therefore is not functional. I also see that your CEL (Check Engine Light) is on. The light on the left, below the other two. See a service shop or the Honda dealer for a diagnosis of the specific problem(s). This could also be a byproduct of a transmission or wheel-speed-sensor issue which many stability control systems need the data from to determine the relative speeds of each wheel and decide the proper action to take to achieve optimal traction. The transmission would obviously be a worst case scenario but I\'ve heard this combination of lights being a symptom of a bad tranny before in a couple Hondas. Best case scenario you or another driver accidentally hit the VSA toggle button. Check the dash for this button and press it. Again, if that does not fix the issue take the vehicle to a reputable technician.
Dec 28, 2012 | Cars & Trucks
Sound card for acertravel mate 530 series
Windows 7Check Control Panel > Hardware and Sound. In Sound > Playback make sure default device is your sound card.
How about the obvious. Volume controls, like mute. Even checking sound with headphones.
Oct 04, 2012 | Acer (54.AA806.001) Sound Card
My vsa system indicator and vsa activation indicator light came on and it will not go off even when I turn off and on my honda- what does that mean?
It's hard to said what it is without a VSA code, but the VSA system monitor the rotation of you tires. Check and make sure you have the same tire size for all four tires. If the tires are not spinning at the same ratio could cause the VSA light to come. It could be a bad sensor or even the VSA modulator itself. It's hard to said. Good luck
Dec 15, 2010 | Honda Odyssey Cars & Trucks
Brand new 2010 Honda odyssey Touring within 40
I can’t be much help on this one (too new for my experience), but your manual will say this (which probably isn’t all that helpful either).
The vehicle stability assist (VSA) system helps to stabilize the vehicle during cornering if the vehicle turns more or less than desired. It also assists you in maintaining traction while accelerating on loose or slippery road surfaces. It does this by regulating the engine’s output and by selectively applying the brakes.
When VSA activates, you may notice that the engine does not respond to the accelerator in the same way it does at other times. There may also be some noise from the VSA hydraulic system. You will also see the VSA activation indicator blink.
The VSA system cannot enhance the vehicle’s driving stability in all situations and does not control your vehicle’s entire braking system. It is still your responsibility to drive and corner at reasonable speeds and to leave a sufficient margin of safety.
On touring models you will also see a ‘‘CHECK VSA SYSTEM’’ message on the multiinformation display if there is a problem with the VSA system.
Without VSA, your vehicle still has normal braking and cornering ability, but it does not have VSA traction and stability enhancement.
The VSA system automatically turns on every time you start the engine, even if you turned it off the last time you drove the vehicle.
I’d get on the Honda people about the problem, especially since you just got the car. I would think that the alarming sounds you are hearing have to do with the unit working the brakes when it shouldn't be, but that's a guess.
Hope this helps some.
Nov 01, 2009 | 2005 Honda Odyssey
Partial Audio Only
Have you checked your Headphones on another device to see whether its OK or not?.......sodeep
May 11, 2009 | Audio Players & Recorders
VSA CHECK ENG LIGHT COMES ON
Take your vehicle to a parts store and have them run a diagnostic on it. It will tell you what code came up and that will give you a good start.
Mar 22, 2009 | 2003 Acura 3.2TL
Laptop sound distort / scratchy
have you tried connect external speakers and see what happens ?
Mar 30, 2008 | Sony VAIO VGN-N130G/W Notebook
148 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
