Question about Fisher and Paykel 24 in. DD603H W Built-in Dishwasher
Actuator motor down
Hi Master T,
As described previously, the top draw of my DD603ss on night went after a loud clunk and you thought it was the actuator.....could you please send the tech manual, cheers,
Wabbada
  • 770 Answers
Although I am a Guru when it comes to fixing appliances I have not yet completed my Mind reading courses so can you please post your email address to send it to
Posted on Aug 17, 2008
Washer makes loud clunking noise after spin
No that would not be your problem. I assume this is a direct drive system and if it is did you check the motor coupler although what you are describing it sounds like your gear case is going bad. Good Luck!
Jun 02, 2015 | Whirlpool LSQ9549P Top Load Washer
2002 katana wont move in gear after a loud clunk in gear case?
It sounds as if the clutch actuating rod has either failed or is not set up properly. Unless you know the complete history of a new (secondhand ) motor you should treat it as broken until proved otherwise. The problem with this type of bike is that younger riders use them as they are cheap and fast. So, they will go as fast as they can, but without looking after the bike. Probably the reason the engine was available in the first place.
Apr 10, 2013 | 2002 Suzuki GSX 600 F (Katana)
Drawer won't open and get beep code 2 short 1 long
The drawer door seal is locked in. This could be either because the controller has lost power or the seal actuator motor is faulty.
You will have to force open the drawer before you can do anything. (Turn off the mains power when you work on the dishwasher)
Let me know if you can handle electric/ mechanical repairs so that I can guide you further. Otherwise you should call a technician. If you are getting beeps then most likely the door seal system is the problem.
Are you able to use the top drawer?
Jul 26, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
On 2 door dishwasher model DD603 bottom draw is very hard to slide out or in. Can i remove draw to inspect and oil draw runners?
Hi- Most likely the lid is stuck in the down, or partially down position. This is usually caused by the lid actuators (motors) not returning the lid to its full up position and therefore the drawer top is dragging on the lid gasket. Replacing the lid actuators should resolve the problem. You'll need a F/P tech to change those for you. Hope this helps.
Jul 26, 2010 | Fisher and Paykel 23 in. DD-603 Built-in...
Fisher and paykel DD603ss ,bottom draw does not slide out easy,,,,
Apr 17, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher & Paykel M#DD603SS - While not running F1 repair mssg
Actually the part is called a Link Actuator. There is one for the upper drawer and one for the lower. When the drawer is shut, it will actuate and the dishwasher will lift the drawer up against the upper lid. When the actuator is broken, this will trigger the flood switch which inturn triggers the F1 code. In the meantime, when the dishwasher is turned on, the water will shoot over the side walls of the drawer and get down below to damage the terminal block module.
Jun 21, 2009 | Fisher and Paykel DD605SS Stainless Steel...
Switching in to 4wd on the fly get a loud clunk and some grinding
Yeah i get the same thing when im hitting the whoops at 80 miles an hour.What is the deal with this.
Jan 21, 2009 | 2003 GMC Sierra 2500HD
Dryer making loud clunking noise
Make sure the drum is not catching the back panel, and that the fan is not loose on the motor.
Dec 14, 2008 | Kenmore Dryers
Top draw has no power
sounds like the actuator motors are stuck in the open position you can take a putty knike and try to pull the top down manually what is your email I can send you the service guide for the unit
Aug 13, 2008 | Fisher and Paykel 24 in. DD603H W Built-in...
Fisher and Paykel 24 in. DD603H W Built-in Dishwasher Logo
141 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
marley mcelhinney
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
